Noddaz
Noddaz PowerDork
9/18/23 10:52 a.m.
I have found that I can use PVC pipe cement (Oatey, red label is what I used) to reattach plastic tabs and cracks in parts that broken.
It leaves a noticeable glue line, so I would not use this on a trim piece that can be seen.
9/18/23 11:33 a.m.
Also related, in case anyone hasn't seen it yet:
[How to repair plastic trim]
TurboFource
TurboFource HalfDork
12/4/23 7:07 a.m.
I have used a cheap soldering iron and cable ties as filler rod to "weld" it from the backside.....
procainestart
procainestart SuperDork
12/4/23 10:54 a.m.
Good to know about the pipe cement.
I haven't tried this, but I watched a YT video where they heated up a piece of metal window screen and pressed/melted it into the back side of the two pieces to splint them together. Still requires some adhesive at the edge.
knhx48iD3Umg1WkCo63P6jMIw3DbYxK4tlE7lCgQPtxkzUE93b2gbaqgbUyPZZF2
