obsolete
obsolete Reader
6/14/21 1:13 p.m.
I just stumbled upon this and thought other GRMers might find it interesting. Looks like circa 2010, Ford started using sway bar end links on the F-150 with ball joints on both ends. These could be used as an upgrade for the "stack of stuff on a bolt" style of sway bar end links used on a lot of older cars, assuming the length and stud diameter work for whatever application.
The RWD version is 5.30" long: https://www.rockauto.com/en/moreinfo.php?pk=1831540&cc=1444700&pt=7580&jsn=25
The 4WD version is 6.03" long: https://www.rockauto.com/en/moreinfo.php?pk=3445419&cc=1444700&pt=7580&jsn=23
obsolete
obsolete Reader
6/14/21 1:37 p.m.
Turns out there's an aftermarket product like this that already exists: RideTech Posi-Links. The Ford parts have the same benefits (no bushing squish, no binding) and are a lot cheaper, but you lose the adjustability...well, until you take a welder to them, anyway.
Mr_Asa
Mr_Asa UberDork
6/14/21 2:15 p.m.
Interesting.  Now, is there one that has the bolts that go perpindicular from the shaft?
obsolete
obsolete Reader
6/15/21 4:40 p.m.
That's the most common style, from what I've seen. Lots of cars and trucks use that style. Just depends what length and angles you're looking for.
Mr. Peabody
Mr. Peabody UltimaDork
6/15/21 5:33 p.m.
Because of our country roads and long rough driveway, I went the other way on PW's car. Balljoint on the top, and urethane bushes on the bottom. I would have used urethane on both but I'll need to fab some brackets first as the mount is 90 degrees to the link
Barb_Dwyer
Barb_Dwyer New Reader
7/31/21 8:54 a.m.
In reply to obsolete :
That's interesting.  Do you know of a model with bolts that penetrate the shaft perpendicularly?
tYK5iAS9wCYSrbmmNlgfX6rBM4eDcf5Pwy3NAPGzz2Yosx6fxUdeE6OGxjigk4u7
