SkinnyG
SkinnyG UltraDork
1/20/19 1:23 a.m.
Alter it so you can pump air into a cylinder and see where it goes!
I imagine one could probably create a pseudo leak-down tester by incorporating a pressure gauge, but I haven't gotten there yet.
Now, to do this, you need to excuse the fact that I wasn't exactly thinking at the time.
I cut off the dead gauge (not shown), and cut the hose barb ferrule off with a hacksaw so I can get at and remove the check-valve inside.
Now would have been a good time to drill the end out and disembowel the threaded end, but I was excited, and quickly clamped it back together, using two crimp hose connectors to make sure it didn't come loose in the bottom of a spark plug well. I use CV boot pliers.
I happened to have a wee NPT barb, so I put an air fitting on what was formerly the cut end.
So now you have something like this:
This was when I realized I forgot to gut the thing.  Short work with a 1/4" drill bit (probably didn't need to even cut the hose off....), drilling until it feels like you broke through something:
Haven't used it yet, but I'm looking forward to.
Also handy for holding valves up while changing valve springs when the heads are still on.
81EvEVBzSNQlU7Ni2dBzyZwb0qEvMrZOlJOmgJuAx4messDQ3rsYwDG15rkVKsA9
