TurboFource
TurboFource HalfDork
7/10/23 4:21 p.m.
Some may not know you can wrap Teflon tape the wrong way. You should wrap it so that when the part is threaded  in it wants to pull the tape into the tread, not try to unwrap it as you thread it in.
Cousin_Eddie (Forum Supporter)
Cousin_Eddie (Forum Supporter) Dork
7/10/23 4:32 p.m.
Treat yourself to something nice.
TurboFource
7/10/23 5:07 p.m.
Teflon tape was already on hand
Shadeux
Shadeux Dork
7/10/23 5:27 p.m.
In reply to TurboFource :
Yeah, sometimes it's all you have. Knowing the direction to wrap and how many turns are good knowledge.
But if it's on hand, I prefer thread sealant. Although it tends to get on me, the wall, whatever I'm wearing, etc.
TurboFource
7/10/23 6:31 p.m.
That stuff is like never seize in regards to getting everywhere!
madmrak351
madmrak351 Reader
9/16/23 1:41 p.m.
Very true, however at least I don't look like the tin man with thread sealant!
Peabody
Peabody MegaDork
9/16/23 1:49 p.m.
Pro tip. That thread sealant often has a twist type lid that, when you twist it closed, whatever sealant that's left in the dispenser squeezes out.
 To use it, open the lid, squeeze it till  you just see sealant, then twist it closed. That'll be just the right amount of sealant for the threads.
Noddaz
Noddaz PowerDork
9/18/23 10:54 a.m.
Pro tip:
Wrap your brake bleeder screws with Teflon tape and they will never get stuck.
At least not in my history anyway.
If there is a down side to this please let me know.
SV reX
SV reX MegaDork
9/18/23 11:05 a.m.
I always wrap Teflon tape exactly the same way. Hold the fitting in my left hand with threads pointing right, and wrap with my right hand away from me. Always. Exactly the same way. For over 40 years.
Woody (Forum Supportum)
9/18/23 11:11 a.m.
In reply to SV reX :
I've always wondered: Is there an ideal number of wraps for this stuff?
For tapered threads, it shouldn't matter, right?
SV reX
SV reX MegaDork
9/18/23 11:27 a.m.
I forgot...
I also hold the Teflon roll the same way... tape coming off the bottom of the roll toward me.
If you do it the opposite, the roll unrolls at the wrong speed and gets tangled.
SV reX
SV reX MegaDork
9/18/23 11:28 a.m.
I was taught enough rotations to begin to fill the valleys of the threads. That's a different number of wraps depending on the pipe diameter.
gsettle
gsettle New Reader
9/18/23 11:55 a.m.
I put teflon tape on the threads of hole saw arbors to make them easier to take apart.
LF9w7Akb0rfMrOtsPccXyojDx6stobjnBimCsSOjH63eCtvf8HmRWgSWxG2QWBAo
