So, About Evoras
Part of the purpose of this trip was to do an extended test drive of an Evora- ones with sketchy histories are getting into a reasonable price range and they've always seemed like the ultimate version of what I like; mid engine, Toyota powered, great chassis, dog sized back seat, etc. So let's have a bit of a review.
Handling:
This is the Evora's main thing, and it's good at it. The steering is fantastic, the chassis is great, the suspension works well... on smooth roads. The moment things get the least bit bumpy, the front end in particular will skitter all over the place and generally feel very nervous. I blame the 19/20" wheel combo with little rubber band tires, and imagine that downsizing to 18s would help immensely. Otherwise, zero complaints and it may be one of the most capable road cars I've ever driven when the conditions suit it. Nothing caught or passed us on a backroad the entire trip.
Drivetrain:
The engine is good- I love that it's a Toyota and not some weird exotic thing, it makes good power with the supercharger, and in sport mode it sounds great and has appropriate throttle response. The supercharger whine from the vent just behind your ear makes driving with the windows open mandatory any time it's nice enough outside. If I have any complaint, the powerband is so linear as to almost be unexciting, and the chassis could clearly take more power.
The transmission, while geared appropriately for both backroad fun and high speed cruising, hates shifting quickly and feels a little out of place as a result. The torsen diff is perfect though, and makes 2nd gear corner exits fun as you can feel out the rotation with the throttle as you feed power back in.
Brakes:
They're freaking huge and, other than a little fade when we were on very tight downhill sections where they'd never get a chance to cool, seemed bottomless. The ABS is tuned very well and the bias seems appropriate for the car. The pedal feel is weird, which brings me to....
Ergonomics:
The interior is actually really nice, and I don't mind the simplistic dash/hvac scheme at all, but there are some weird choices in this car. The brake pedal has resistance about .5" before anything actually starts happening, making it unnerving to use at first. The clutch throw is really long. The throttle is lighter than it should be for a car with this power/weight ratio, although the pedal spacing is fantastic for heel/toe blips and all that good stuff.
There's a lot of headroom, but weirdly you're forced to use it because the seats are high- I would've been a lot more comfortable with my butt another inch or two closer to the floor; this also meant I had to duck to see under the rearview mirror on right turns. The steering wheel adjustments put it exactly where I wanted it, but that caused it to block the tops of the gauges. Whoever designed the dash didn't think at ALL about reflections either, the carbon cowl over the gauges reflects off the windshield and so do the silly chrome rings around the vents.
Visibility:
You know what, this should get its' own section because there's more than just the mirror in your face or the reflections all over the windshield; those could be solved with some seat bracket tweaks and paint or vinyl, respectively. The side mirrors don't really adjust far enough, and the rearward blindspots are massive- this thing is hard to park, and harder to navigate traffic in since you can fit a whole truck in the blindspots. The fenders will reflect into your eyes when the sun gets low, and the spray from the ocean on the coast had to be wiped off at stops because the giant single wiper is lousy and the windshield sprayer is laughably useless. Some rainx would go a long way, but I don't think the one I drove had ever seen rain.
Then the headlights- honestly I would trade these for a single stock dirtbike headlamp from the 80s, that's how crap they are. Sharp cutoffs to the sides mean you can't see a damn thing, and the sharp cutoff at the top is barely helped when the highbeams are on- this one had a failed DS highbeam, but given how little the other one did I doubt it'd do much. Nearly undriveable at night when you factor all the stuff that reflects off the windshield and that you can't dim the backlight on the row of buttons high on the dash.
Other Interior Stuff:
Cargo capacity is actually great for the sort of car this is- comparable to an SW20 MR2, although lacking a frunk since it's all full of radiator. The seats were good, and heated although the heaters wouldn't be mistaken for something you'd find in a Saab or even a Subaru. The head unit/navigation is pretty useless and I'd probably replace it with something single-din just to get the screen out of there. It was, other than visibility, an easy car to spend a week in. They also did a phenomenal job making it pleasant with the windows down, no wind buffeting or weird noises.
Body:
It looks more expensive than it is- some may like this, I don't, but whatever. The bodywork flaps around a bit when on bumpy roads and I had concerns about its' longevity. The nose is stupid-low, and you have to be really careful not to scrape it on driveways, speed bumps, or even minor dips in the road. Same goes for the diffuser at the back, careful parking!
That Damn Immobilizer:
I'd bypass this immediately if I owned one- not only can it be interfered with by a radio tower, it locks the ignition on you constantly if you just use the car normally and forces you to button mash on the keyfob just to get the thing to start.
But Do I Still Want One?:
Of course I do. The main problems are solvable with a little work, and despite the fact that it's terrible at just plain being a car, the thing is spectacular to drive- it really is just the most perfected V6 MR2 in the world, when you're behind the wheel and ignoring all the visibility issues. I'm not certain I'll ever actually get one, since I do think the fiberglass would be cracking to bits with 30k miles of my usual use, but maybe a sufficiently cheap one will appear and I won't care.
