Changing Our Mini’s Ring and Pinion Gears
Tim
Update by Tim Suddard to the Austin Mini Cooper S project car
Dec 26, 2012
Changing the rack and pinion gears helped us with our final drive ratio.
The pinion gear for the 3.10:1 final drive was physically too large to fit into the retainer.
The retainer was ground down so the pinion gear would not interfere.
While rebuilding our transmission we got into a discussion with the folks at Mini Mania about final driver ratio selection. The standard ratio for the 1275cc Cooper S was 3.44:1. And while our car still had this stock, standard ratio, Mini Mania owner, Don Racine, suggested that if our intended use for the finished car would be some highway use and higher speed, long distance rally work, then we may be happier with a higher (lower numerically) final drive. He pointed out that with the stock 3.44:1 final drive ratio, a Mini Cooper is straining and turning very high rpm at today’s legal highway speeds.
As we had tweaked our head a bit and had a little hotter cam, our engine would be good for another 5-10 percent more horsepower. So we felt we would still be able to come off the line even with the higher final ratio.
Generally, we like to test everything for ourselves, but we had no desire to take apart the gearbox twice, and Racine and his crew have many years of Mini experience, so we trusted them. He recommended a 3.10:1 final drive as a good compromise for overall drivability.
There are a few tricks needed to install the physically larger ring gear, which we will get into when we start our story series in the May issue of Classic Motorsports. You can pick up that issue on newsstands in early April, or subscribe today and guarantee you don’t miss the details on this project car build.
It was an itsy bitsy, teeny-weeny rally-winning project Mini. Subscribe to Classic Motorsports and get them in your mailbox.
GregWClassic
GregWClassic New Reader
1/30/13 11:54 a.m.
You did not remove much more then casting flash did you?
Sponsored by
Mini Mania
Advanced Performance Technology
Performance Racing Oils/Millers Oils
HEpZ4Z3WO40u3u0YwyImjsSS57pt15hnUFqJ0Y73Dzf0s3vttBjFqhv3GOOQnXHj
