Submitted by jamesdhill1 on June 7, 2011
Found a Austin-Healey in Roswell, GA
This is a 1959 AH Bugeye. It was running when it was parked 20 years ago. Since then it has served as home for several cats and a family of rats… after the cats moved out. Everything is there, including the top frame and side screens. Someone has replaced the original engine with an Midget 1275cc and waffle case power train. Condition of the engine to be determined next. The body seems sound but it will need a new floor pan. I pulled the front and rear drums so it could be rolled, bolted on the original steel wheels with new rubber added, and was able to push the car to the garage single-handed. These things are more like cockroaches than frogs… you just can’t kill ‘em!
willie
June 15, 2011, 4:18 p.m.
AT 76 YEARS OLD. / RACED A NEW 58 VOLVO IN 1958. RACED 2 TR SPITFIRES 1966 &1969 AT THE SAME TIME. ALWAY'S LOST EVERY gymkhanas TO a BUGEYE SPRITE in kingston new york. back in 1959 to 1979....rebuilt a 1959 bugeye in . 2000.from vermont......you just can't KILL a a/h bugeye sprite....w.shane ps also started
You'll need to log in or register to comment.
Location map
DwqmuL0yi4S3gSapJ5OGoJUS98jis52MPuvivqMBG0ZuqPW4P3pLoCcA59Js9pvg
