Started on Nov. 29 by Hebephast
1986 Porsche 944 Turbo
13
Euro-spec 944 Turbo: Factory A/C delete, power steering delete, Weltmeister sway bars/Bilstein Cup coilover susp., torsion bar delete, ChromeMoly A arms, Porsche 928 big brake kit, Steam Vent Kit, Guard LSD, Wizard Cooling integrated radiator/oil cooler, Lindsey Racing MAF, NASCAR boom tube exhaust, LR super 65 turbo, LR stage III head, solid lifters, Web Cam 274 grind, torsion bar delete, LR intake, LR header, forged monobloc CCW 11” wheels, Sparco EVO L seats, Sparco 5 pt. harnesses, headlight delete, APR CF wing, GT Racing rear deck @ louvered hood, Carbon fiber dash & sunroof, carbon fiber doors + wide body kit (black), Autometer elector-lum. guages, Cometic, Delrin, Upgraded ‘88 hubs and spindles, SS braided fuel lines, Bosch high flow fuel pump, 72# injectors, fuel pressure gauge, HSD coil, full roll cage (finally), cockpit boost adjust, LR downpipe, LR wastegate, Innovate AFR meter, Spa Technique oil sump temp sensor/boost gauge, new belts/hoses/seals, new water pump, new rings, LR 3 piece crossover member, stage 3 hybrid clutch, dry sump oil (this was, “difficult”), dial bore guaged bottom end 3.0, 2.5, 2.4, 2.5, 2.8, 1/10000 stock crank jounals high to low w/ 64,000 mi., and a partridge in a pear tree…
Latest updates
Sept. 11
Carbon wide body + CCW Wheels
What a lot of work…PITA but I’ve enjoyed the ride. Thanks Rusty + Mikey B.
May 12
Body Complete (mostly)
Finally have all body mods done (for the time being) so I can go racing…VIR …
Add your comment
See more
JcdS4I2sr6kJr4m2KkP1Z75IBDJhCH8ZHernlCMc2BdB4ouTp0YjQTCosRBO2hUc
