Started on July 12 by vr6gtispeed
1984 Volkswagen Rabbit GTI Cup Car
The car was built by Erickson Motorsports in Ca. for the NASA GTI Cup class. I bought the car in Dec. 2009. Specs: Suspension: Neuspeed 25mm Front Sway Bar Neuspeed 28mm Rear Sway Bar Bilstein Shocks Neuspeed Upper Tie Bar Neuspeed Lower Tie Bar Neuspeed Solid Upper Strut Bearings New Dimensions Front and Rear Poly Motor Mount Bushings New Dimensions Steering Rack Bushings New Dimensions A Arm Bushings Motor: 1.8 l 8 Valve Inline 4, Mk-II GTI Throttle Body Autotech Cylinderhead, 286 Cam, Header Scientific Rabbit Stage III Intake Manifold New Dimensions oil Cooler Griffin Radiator Techtonics 2-3/4” Exhaust 020 close ratio 5 speed trans with a Wavetrac LSD. Weight with full tank and driver. LF = 680, RF = 722, LR = 438, RR= 334 Total 2174 LB
Add your comment
See more
DqaUXEC5zxOuefcCEQdF8oh7q8nm9BSi0JVylXqveS4OCV1Yzrz9AIbPtVtuw6q1
