Understanding exhaust back pressure and how to monitor it | Video
https://www.youtube.com/embed/IpzqpjmOSB8
Trying to push the performance of your turbocharged car? You might have some questions about exhaust back pressure.
Thankfully, this video helps explain what exhaust back pressure is, why it happens, and how to manage it–plus what happens when you have too much.
z31maniac
z31maniac MegaDork
3/2/22 2:10 p.m.
Back pressure, you don't want it NA or turbo.
Unfortunately over the years people have confused poor exhaust scavenging through the use of exhaust pipes that are too large (which slows velocity) and think back pressure is good.
Paul_VR6 (Forum Supporter)
3/2/22 3:23 p.m.
A wise man once said, "exhaust backpressure is fine when the valve is closed."
3/2/22 6:48 p.m.
THANK YOU.
Now let's work on the myth of coolant moving too fast to transfer heat smiley
Turbos work just fine with bigger = better, at least after the turbo, because exhaust energy should all be used to spin the turbine, or at least any kinetic energy left in the exhaust after the turbine means nothing to the 20-50-80psi of pressure pre-turbine.
codrus (Forum Supporter)
3/2/22 8:24 p.m.
Not if it blows the valve open!
Opti
Opti Dork
3/3/22 8:55 a.m.
In reply to z31maniac :
Dont take this as an argument because Im genuinely curios. Has "exhaust too large" been proven? Ive looked for examples in the past and havent found anything, and on the platforms im familiar with, they guys with the biggest exhaust generally go faster/make more power. Internet wisdom is always you cant run the bigger headers/or 4 inch exhaust on a stock cube or close to stock motor, but when tested it always seems the larger guys end up making the HP.
Ive never seen anyone do the obvious extreme, which would be interesting.
z31maniac
z31maniac MegaDork
3/3/22 9:50 a.m.
Dont take this as an argument because Im generally curios. Has "exhaust too large" been proven? Ive looked for examples in the past and havent found anything, and on the platforms im familiar with, they guys with the biggest exhaust generally go faster/make more power. Internet wisdom is always you cant run the bigger headers/or 4 inch exhaust on a stock cube or close to stock motor, but when tested it always seems the larger guys end up making the HP.
Of course not, I always want to learn as well!
I honestly don't know if anyone has done something like that. Keith, any insight?
3/3/22 2:49 p.m.
I have never seen a bigger exhaust lose power, maybe not gain any. Totally different for header primary/secondary sizing as that is crucial. After the turbo or collector, infinity diameter is the answer cool other than packaging.
Opti
Opti Dork
3/3/22 8:29 p.m.
In reply to Paul_VR6 (Forum Supporter) :
I've seen collector quality and primary length make a difference, but everything equal I haven't seen larger primaries lose power, but like I said I haven't seen anyone go to the extremes to test it.
So I don't know if the platforms I'm familiar with run primaries too small commonly so when people upsize, they are actually still headed in the right direction or not.
If you've got some testing or info where only primary size goes up and power goes down I'd be real interested in reading about it.
3/3/22 8:35 p.m.
Are we talking peak power, or overall powerband?
Opti
Opti Dork
3/3/22 9:16 p.m.
In reply to Pete. (l33t FS) :
I'm interested in either
You'll need to Log in to post comments.
qgtqwgpxfbBdPekb53e6O7lSyxWHBQxcubRnUzW3X2im3n0pFv74Py0mVQOvWWFw
