10 speed secrets for the amateur vintage racer
Carl
Photography Credit: Chris Tropea
[Editor's Note: This article originally ran in the May 2016 issue of Classic Motorsports, but we feel like these speed tips are timeless.]
Not quite ready to dedicate your entire life to your on-track escapades? How about some tips for the rest of us—those who'd just like to fully enjoy our classics, whether it's slicing through Road Atlanta's esses or traversing our favorite mountain pass? Carl Heideman has gotten intimate with just about every form of classic machinery, from '50s Fords to Britain's best. He knows a bit about what makes our classics tick and has some speed secrets to share.
1. Look at Your Ignition
You don’t need the latest and greatest high-tech ignition system in your car, but you do need one that’s strong and dead-nuts consistent. Hold a timing light on your engine while it’s running at 5000 rpm: If it’s not giving you a super-stable reading, your ignition system could use some work. We usually find that a fully rebuilt distributor–again, that’s rebuilt, not just cleaned up–teamed with a Pertronix ignitor solves a lot of woes.
2. Conjunction Junction
Hoses, lines and wires do fail, but problems usually occur at a junction. Are your systems as simple as they can be, or is your fuel pump actually powered by three wires spliced together? On a related note, how are your grounds?
3. Keep It Simple
Going Fast Doesn't do you any good if the car keeps breaking and can’t finish a race or make it over that pass. Constantly check the car for loose wires, stray cables and simple adjustments that have gone out of spec. For example, does your throttle still open all the way? And is the cable going to last the whole weekend, or is it about to pull out of its stop?
4. Know When to Shift
Just buzzing to the redline before shifting isn’t good enough. If you’ve gone to the dyno, you can figure out your best shift points and put them to use. An illuminated shift light can be your friend here, although a piece of red tape stuck on the face of the tachometer works well, too.
5. Measure Stuff
Get a probe pyrometer to make sure your tire pressures and alignments are correct. Tire temperatures should be even across the tread. Get an infrared pyrometer to make sure your brakes are all about the same temperature. Know exactly where your ignition timing is set. The bottom line is that when you measure things and record that data, you can take an informed, diagnostic approach to speeding up.
6. Organize Your Tools
Call us lazy, but we don’t always like going through our entire toolbox before beginning every repair. Hand tools are relatively inexpensive, so we’ll buy some duplicates and keep them bunched together for specific fixes. For example, we’ll keep together everything needed to bleed the brakes. It makes for less stress when time is short.
7. Get Some Feedback
Talk to the guys who are going faster than you and see if they’ll give you some pointers. If they’re good, they’ll know what works and why they’re passing you. If they’re nice, they’ll tell you. When and how you ask can be important here. After their third beer during the evening social is probably better than while sitting on the grid.
8. Common Sense Rules
Everyone has their theories about why they’re faster or better. Listen to them all, but learn to separate the snake oil from the superstition from the silver bullets. If something doesn’t make sense, it probably doesn’t work. Most factors come down to math, physics, and thermal law. A Ph.D. isn’t necessary–if you understand some basic concepts, your common sense will provide the answers you need.
9. Test, Test, Test
There are now so many testing opportunities out there that it’s silly to not take advantage of them. From local autocrosses to noncompetitive track events, there are plenty of opportunities to shake down a car before that big weekend. Not sure your skills are sharp enough? Hire a seasoned driver for the day.
10. Avoid Slop and Bind
We see two common and opposite problems on race cars. Sometimes things are sloppy–like linkages that have too much free play or wear. Sometimes things are in bind, like an anti-roll bar whose geometry doesn’t match the suspension. Too often we see both at the same time, which can be dangerous. An anti-roll bar that is in bind will wear components, causing slop that will eventually lead to catastrophic failure.
Join Free Join our community to easily find more Vintage Racing and Speed Secrets articles.
dougie
dougie Reader
9/7/17 11:44 p.m.
All very good information, I wish most racers would take note. Yellow flags for mechanical failures burn-up a lot of track time. sad
MadScientistMatt
MadScientistMatt PowerDork
9/8/17 9:52 a.m.
I've fielded a lot of tech support calls that turned out to be something on that list.
wspohn
wspohn Dork
9/9/17 2:08 p.m.
#4 is one that even experienced racers have a hard time learning.  Depending on gear ratios and engine characteristics you can often short shift and land right on the top of the torque peak in the next gear instead winding the nuts off it as a matter of course.
I managed to get one guy to take my suggestion - he claimed a power peak at 7,000 rpm  I asked him to go out and do 3 laps (which I'd time) faithfully doing 6,000, then 3 lps at 6500, then the last 3 at 7,000.
Turned out that regardless of where his actual power peak was, 6500 was just as fast as a 7,000 shift. Probably saved him an early rebuild.
Don't know why some racers are so stubbornly wedded to (sometimes incorrect) theory when it is so simple to just go out and try it and see.
terracer
terracer New Reader
4/10/19 8:47 a.m.
This will probably seem common sense stuff to the serious racers on this board, but the one thing that helped me more than anything was focusing on eliminating any "dead" time in the pedals... What I mean is I should be either on the gas or on the brake, right?  By focusing on doing one or the other ALL the time - and eliminating every milliscond of doing neither - lap times drop....
Dwight
Dwight New Reader
5/17/22 9:33 a.m.
Love it!
'Sumtimz ya hafta slow down ta go faster...........
BimmerMaven
BimmerMaven New Reader
9/24/22 1:28 p.m.
Way back when, my instructor did the same on every lap down the main straight....next to a similar car.   We'd slow down the last 500 rpm in 3rd while the other guy passed us.
Got him to shift sooner, and guess what happened?
BimmerMaven
9/24/22 1:44 p.m.
I love all of these.
I'm obsessed with measuring.
 I chuckled when I once read of a guy who switched from AFM with trap door to hot wire...."I could tell I was going faster because I wasn't pushing down on the gas pedal as far as before..."
And...."Ground"
Seems that many think it's not really doing anything....I.e.  Not as important as  "positive" connections.
The confusion, of course, stems from "chassis common" ground, in the car, where the metal frame is half of the circuit, and "earth" ground, in houses, which serves as a secondary pathway for "stray" electrons to get back home....instead of using your body as a pathway for them.   This "earth" ground normally carries no current;  the exact opposite of "chassis" ground.
We are victims of the endless shortening of technically correct phrases.   May favorite is "Zero Turn Radius" Lawnmower to "Zero Turn" Lawnmower;  its claim to fame is that it only goes in a straight line.
BimmerMaven
9/24/22 1:44 p.m.
And...."Ground"
rookie13
rookie13 None
11/3/23 9:40 p.m.
In reply to terracer :
Amen! We were watching video one Saturday night at the track and one of the fast front runners said while watching my video "there's no coasting in racing". I was faster the next morning.
mcloud
mcloud New Reader
2/1/25 2:21 p.m.
PERTRONIX  Ignitor:  1, 2, or 3?  Number 3 version adds a rev limiter & multi spark ignition system.
Read Randy Pobst's  column (GRM 1/25), especially the part about 'holding the line'.
2cgSRWMBFWJ3iG7WHhMcQhN3FYQQrDJZcmISGjOV0PpwwQ5qLrszDx0QfeYXacDX
