1 2 3 4 5
dyintorace
dyintorace UltimaDork
3/25/24 5:03 p.m.
That is fantastic! The driveshaft being done is a big check mark on the to-do list.
a_florida_man
a_florida_man Dork
3/25/24 7:01 p.m.
In reply to Stampie :
Is that a conversion joint?
If so which one?
Stampie
Stampie MegaDork
3/25/24 7:26 p.m.
In reply to a_florida_man :
Yes.  Moog 372 but the u joint had 350F cast in it.  The yoke used came out of a 99 Silverado 1500.
a_florida_man
a_florida_man Dork
3/25/24 8:15 p.m.
Right
I could see it was a gm yoke by the injection hole
assumed it was an import shaft and was just wondering how that worked out!
Great job!
Stampie
Stampie MegaDork
3/25/24 8:48 p.m.
Hearsay but the driveshaft came out of a C4.
dyintorace
3/29/24 5:32 p.m.
a_florida_man said:
In reply to dyintorace :
You can have them sent here if you like. If the wheels are here I can do it all when the tires are delivered.
Tires will be here Tuesday. May I bring them and the wheels to you that afternoon/evening?
wvumtnbkr
wvumtnbkr PowerDork
3/29/24 6:15 p.m.
Aluminum?  Did it come from me at some point?  I had an Aluminum c4 shaft that I'm pretty sure I gave to a fellow grmer.
Stampie
Stampie MegaDork
3/29/24 8:17 p.m.
In reply to wvumtnbkr :
Yes aluminum but it came from surfshibby07 from when he ran it.
In related news removing this shift cable kicked my shiny today. Some damn engineer put a PITA spring on top of the steering shaft to hold it in place.
3/30/24 8:11 a.m.
On 4/2 or 4/3, post a list of parts / supplies / tools / etc that you need to make the car run and drive and steer and stop and pass tech.
3/30/24 8:23 a.m.
It was me. I did it for my people. Because engineers hate you at least as much as you hate us.
Stampie
Stampie MegaDork
3/30/24 12:22 p.m.
Just wanted to say the Mazda engineers are better. They knew we'd need the perfect size hole for the GM body grommet to fit in.
dyintorace
3/30/24 2:57 p.m.
Making the exhaust fit.
dyintorace
3/30/24 3:22 p.m.
Battery is held down.
RacetruckRon
RacetruckRon SuperDork
3/30/24 5:13 p.m.
Care package from Wisconsin should have arrived earlier this afternoon. Best of luck guys!
wvumtnbkr
wvumtnbkr PowerDork
3/30/24 5:34 p.m.
Make it in some way, or put rubber on it so it doesn't slide and touch both terminals.
dyintorace
3/30/24 8:02 p.m.
We agreed. Made a new hold down bracket from our free wheelbarrow and put a shield on it to protect the terminals.
dyintorace
3/31/24 4:07 p.m.
Stampie
Stampie MegaDork
3/31/24 8:01 p.m.
That was leading up to this.
All needed systems wired up to the panel and basically need to be hooked to the battery and/or fuse panel. Headlights and brake lights working per Challenge rules. Engine not running yet.
dyintorace
4/1/24 9:45 p.m.
Concours prep. You know E36 M3 is getting real when you can convince your spouse to help!
dyintorace
4/1/24 9:46 p.m.
a_florida_man
a_florida_man Dork
4/1/24 11:14 p.m.
You missed a spot.
dyintorace
4/2/24 6:44 a.m.
You missed a spot.
Not just one! 😂
Dusterbd13-michael
Dusterbd13-michael MegaDork
4/2/24 7:00 a.m.
Do i need to bring any parts for you ls wise? Im packing tonight after work
dyintorace
4/2/24 8:03 a.m.
We started a list of things left to do. Here is what we have so far:
Numbers and stickers
Steam vent (ordered)
Coolant overflow
Radiator hoses (have some but need to cut them up and figure out routing)
Fuel pump relay and rewire panel for it (ordered)
Fan relay (ordered)
Headlight relay (ordered)
Power to PCM
Add Oil (have it)
Dipstick (have it - need to put it in)
Add Trans fluid (have it)
Add Water
Add Fuel
Passenger O2 (have it but need to install it after putting starter on)
Shifter (have it but need to figure out how to attach shift cable)
Hood (have it but will have to cut it up to clear engine due to truck parts)
Hood scoop (need to figure out how to attach it to hood - risers?)
Wing (don't have one - would love to find one)
Trans cooler (have it along with hoses - need to plumb and install)
Bumper (have it but need to put it on car)
Alignment (have a string kit that I'll bring with me)
Tires mounted (should happen tonight)
Replace brake union in cabin and go over/bleed brakes (car had a drift brake in the cabin - removed but should improve line union)
Figure out Air Cleaner/MAP
Bolts for battery (have a battery tray built)
Install seat (have it)
Install roll bar (have it)
Install harness (hope to have it today)
Install starter and positive lead to switch panel (have it but need to run a new wire)
Dusterbd13-michael
4/2/24 8:15 a.m.
Ill bring a maf and air cleaner setup to loan you if truck stuff works
1 2 3 4 5
uIfrmbAoAHCrMW3rCoTPUrOob2QT6u6di8JRx3AZzTwKlIW8W9Oaq2h16jUAP04Z
