84FSP wrote: Very nice! What kind of rpms were you turning at highway spped?
Thanks! With the lack of front end alignment, I only brought it up to 55mph / 2800 rpm. According to the Gear Calculator, 70 would be 3500 rpm
SilverFleet wrote: http://bangshift.com/bangshift1320/a-lunatic-is-building-a-small-block-v8-powered-1970-daihatsu-hijet-this-thing-is-off-the-charts-wild/ Just gonna leave this right here...![]()
Great! Thanks so much!
The direct-drive worked out way better than I imagined. I expected you'd end up with a 30mph useable range max, but you have much more than that. How are you planning to work out reverse though?
petegossett wrote: The direct-drive worked out way better than I imagined. I expected you'd end up with a 30mph useable range max, but you have much more than that. How are you planning to work out reverse though?
I have a starter/generator from a gas golf cart connected to the rear axle yoke to provide battery charging and slow electric forward and reverse movement. I don't expect to need it much though. I have been driving my Suzuki Reverse Trike
for two years and you quickly get in the habit of pulling thru parking spaces and finding lots of opportunities to take advantage of gravity for rolling backwards.
The transmissionless Daihatsu also has a Hydraulic Line Lock to hold the clutch in the disengaged position for tuning etc.
Ben_Modified wrote:SilverFleet wrote: http://bangshift.com/bangshift1320/a-lunatic-is-building-a-small-block-v8-powered-1970-daihatsu-hijet-this-thing-is-off-the-charts-wild/ Just gonna leave this right here...Great! Thanks so much!![]()
No problem man. Such a cool little trucklet! And glad to see you got it up and running!
In reply to Ben_Modified:
Cool, I'm not familiar with carts so I had no idea they have one device sharing the duties of the starter & generator...it makes perfect sense though. It seems like it may be subjected to higher RPMs on your build though, do you think it will hold up?
petegossett wrote: In reply to Ben_Modified: Cool, I'm not familiar with carts so I had no idea they have one device sharing the duties of the starter & generator...it makes perfect sense though. It seems like it may be subjected to higher RPMs on your build though, do you think it will hold up?
I am not expecting any real problems from it, but if it does not work out, an automotive generator can be converted to do the same thing.
SilverFleet wrote: You are now "Facebook Famous". BOTH GRM and Bangshift shared your build on there just now!![]()
Cool. Thanks Again!
Installing the Gauges. Being direct drive, with no transmission speedometer output, I will add an extra set of marking on the tach for both functions.
After waiting for a couple of weeks, my rear glass seal/gasket finally came in. Installed the glass and finished up the steering column relocation (to make room for my knees)
Jerry From LA wrote: Any room for a Gear Vendors overdrive or similar?
Not with the stock wheelbase. I could move the rear axle back and make room for one or a shorty powerglide, but as it is, its an grossly overpowered go cart and just doesn't need any gearing changes. Also, I like that it is such a sleeper and don't want an altered wheelbase to give it away.
Parts have come in! Time to install the various pieces to correct a positive camber and insufficient caster front alignment issue. The front axle uses screw-in fasteners to mount and lock in the upper ball joint in the knuckle. By replacing the stock component with this offset one, I can bring the top of the wheel back in to alignment. This piece can also affect the caster, but probably not to the degree needed. I will likely also need to insert a leaf spring shim as the factory configuration was only laying the axle back a single degree. 6 degrees should make it much more stable at speed.
Ben_Modified wrote: Parts have come in! Time to install the various pieces to correct a positive camber and insufficient caster front alignment issue. The front axle uses screw-in fasteners to mount and lock in the upper ball joint in the knuckle. By replacing the stock component with this offset one, I can bring the top of the wheel back in to alignment. This piece can also affect the caster, but probably not to the degree needed. I will likely also need to insert a leaf spring shim as the factory configuration was only laying the axle back a single degree. 6 degrees should make it much more stable at speed.![]()
My Build Blog of Odd Projects
All of the alignment fixes are installed. I took it out for a long ride today and it drives and tracks much better! I had two cars catch up to me at stop lights to find out why this little truck was so fast! As the truck is direct drive, I am using the tach as both a tach and speedometer. I took my gps along to note the relationship between rpms and mphs. Turns out the online gear calculator was exactly right and luckily the mph are exactly twice the rpm. My tach lists the revs as 10, 20, 30 etc….so 20 = 40 mph and so on.
I drove about 20 miles in 85 degree heat. Motor temp in traffic was 180 - 200 degrees. This is with no thermostat and only water in the radiator. My other GrassRoots Build Thread
