Dusterbd13-michael
Dusterbd13-michael MegaDork
5/14/19 2:00 p.m.
Its un-shelf-ed. Fired right up after charging the 5 year old battery.
Gonna go for a drive tonight after work.
Dusterbd13-michael
5/14/19 3:36 p.m.
Well, that was a short drive.
Just around the loop.
Quick fix it list:
Seat stopped moving
Charge ac after reconnecting line and adding oil
Adjust clutch
Check tire pressure
Mount coil permanently
Firewall wiring pass through
Ill chip away after the garage is clean again.
Professor_Brap
Professor_Brap Dork
5/14/19 3:54 p.m.
Burnout video required once done.
Dusterbd13-michael
5/14/19 4:05 p.m.
Still nope. Last one cost WAY too much money
Professor_Brap
Professor_Brap Dork
5/14/19 4:13 p.m.
So what we are saying is the Neon in the back does better burnouts?
Dusterbd13-michael
5/14/19 4:16 p.m.
In reply to Professor_Brap :
Dunno. Haven't tried one in it.
But the truck under the carport does FANTASTIC burnouts .
Oh, mark the coil off the list.
Norma66-Brent
Norma66-Brent Reader
5/14/19 11:11 p.m.
Glad to see it back up and driving. Hopefully close to a lot of leisure enjoyment with not a lot of work!
Dusterbd13-michael
5/15/19 6:56 a.m.
Thanks Brent!
Tonight, I'll adjust the clutch and get the hardware for the firewall plate. Maybe get those knocked out around the lathe stand rebuild and wall repair.
Dusterbd13-michael
1/6/20 10:33 a.m.
Back in the workbay. Time to finally finish it.
Anyone willing to come over for a weekend and help me do drivability tuning with the megasquirt?
Professor_Brap
Professor_Brap Dork
1/6/20 11:32 a.m.
Princess_brap and i have been talking cor a few weeks about taking some time out of ohio
loumash
loumash New Reader
1/7/20 8:10 a.m.
Just read the whole thread.  Great motivation to work on my 66 Barracuda project!  The Duster looks awesome.
AngryCorvair
AngryCorvair MegaDork
1/7/20 9:02 a.m.
this comment made me go back to the start of this thread, and i opened the forabodiesonly.com thread which led me to this tidbit:
dusterbd13 said:
also, i shimmed the weatherstripping using some double sided moulding tape i had left over from my s10. little 1/8 thick tape made an incredible difference.
and i LOL'd because i have:
  • a Sonoma (S10) with terrible wind noise around drivers door
  • a roll of double-sticky foam tape
so thanks to a 10-years-ago post by duster, i'm gonna tackle my wind noise issue tomorrow at lunchtime.
Professor_Brap
Professor_Brap Dork
1/7/20 9:52 a.m.
I spent 10ish hours last week researching and looking for window felts for my omni. I didnt wanna spend $440 three times....
Dusterbd13-michael
1/7/20 2:57 p.m.
My diy window tint job sucked and was bubbly and peeling.
Its fixed now. Look close.....
untchabl
untchabl Reader
1/8/20 8:09 a.m.
Michael, I'd be glad to come by and help on the Duster. I work the next 2 weekends unfortunately but let me know if you don't get it figured out by then.
Dusterbd13-michael
1/10/20 7:50 a.m.
Untouchable and professor; wouldn't turn down the help! I'm in over my head here with tuning. Or at least feel like I am. It already runs almost as good as it ever did with a carb, but it could be TONS better.
Also: the dead power buckets weigh close to 100lbs. Each.
Dusterbd13-michael
1/12/20 4:14 p.m.
The Lincoln buckets are dead. They never quite fit right, weren't that comfortable, and weighed over 100lbs each.
The dead motors make them less than useless.
Meet their replacement
GoLucky
GoLucky Reader
1/12/20 5:19 p.m.
Nice seats. What are they from?
Dusterbd13-michael
1/12/20 5:20 p.m.
2005 neon sxt
$60 for the pair!
Dusterbd13-michael
1/15/20 12:58 p.m.
The side mirrors on this car suck. Wont keep adjustment, and are all but useless due to shape.
So i bought these. New old stock aftermarket pieces that look similar to factory sport mirrors. The have a set screw underneath to lock them in place so they dont change when i put the cover on, or shut the door, or....
I modified the mounting hardware and brackets to ate up with the factory holes (no pics) and installed the passenger side. Since you have to pull the door panels etc, i also went ahead and lubed the windows and such.
Drivers side door needs adjustment and window needs repair. So i will do all that and the mirror at the same time.
Justjim75
Justjim75 Dork
1/15/20 1:17 p.m.
If you hadn't told me i wouldn't know they weren't factory
Dusterbd13-michael
1/15/20 3:09 p.m.
In reply to Justjim75 :
Fantastic! Exactly what I was going for!
Now, back to seat rail rework....
1/8 plate is plenty for seat brackets, right?
TVR Scott
TVR Scott Dork
1/15/20 3:35 p.m.
1/8" Steel Plate?  Should be fine as long as it's a fairly large piece.
Dusterbd13-michael
1/27/20 10:17 a.m.
This is promising! (Had this seat before the black ones. Ill swap the rebuilt tracks over to the black seats later)
Dusterbd13-michael
3/26/20 2:07 p.m.
Megasquirt has failed me for the last time.
The efi has been sold, and a Holley brawler purchased.
QpUt7uUJeIY5jh6g8CMsZz8X8DPl7143DavdQIvYkpeSP3XTaADlCUUKguxUuMF4
