JoeTR6
JoeTR6 Dork
6/3/23 12:44 p.m.
stafford1500 said:
And a simple image of the cars state after the 2023 Challenge. Time to get back on this now that there is room...
You really should paint a Union Jack to match the weld seams.  This is so cool.
stafford1500
stafford1500 Dork
6/3/23 8:35 p.m.
It was white and red along the seams until I redid the hood. Kinda a reverse English flag (not the uk flag).
St Georges cross.
stafford1500
stafford1500 Dork
6/3/23 8:39 p.m.
Hood is off and getting panel work today. Lots of hammer and dolly work, with a little welding and grinding.
Greg Smith (Forum Supporter)
Greg Smith (Forum Supporter) Dork
6/8/23 4:31 p.m.
beautiful work!
stafford1500
stafford1500 Dork
6/8/23 5:06 p.m.
In reply to Greg Smith (Forum Supporter) :
Thanks. I may have to actually go hammer some more this evening with a cold beverage in hand to relax from a day of staring at numbers in a room with no windows. This car has been my stress relief for a very long time. I had planned to document the whole thing way back when, but now it's all stored in my head, even the small detail in the all white wiring loom...
AWSX1686 (Forum Supporter)
AWSX1686 (Forum Supporter) UberDork
10/25/23 1:55 p.m.
Very cool!
stafford1500
stafford1500 Dork
10/25/23 2:53 p.m.
This summer got away from me and I didn't do much. The garage still looks like the picture above except there is a different welding torch on the hood. I should get myself motivated to get back out there...
10/25/23 3:14 p.m.
In reply to stafford1500 :
Beating Monzora is the motivation right?
10/25/23 9:26 p.m.
I'm happy to provide motivation to get people to bring crazy E36 M3 to the challenge!
stafford1500
stafford1500 Dork
2/2/25 4:36 p.m.
Well it's been another long stretch without updates. It seems I prefer working on the car rather than updating the build thread.
Anyway, I spent the past few weeks building the radiator ductwork for a newly fabricated radiator. The new radiator started as a core and I welded tanks inlets and outlets to it to better fit the engines water necks, both near centerline.
It only took a few passes to find/weld the pin holes. Next is fit the assembly to the car and add water, then check for leaks with temp.
Ductwork is fiberglass with foam core for thickness/stiffness. Lots of wet layup and four pieces to make the assembly serviceable. Also ruber to seal around chassis bits.
Next up is an intake duct that houses a filter.
stafford1500
stafford1500 Dork
2/24/25 11:39 a.m.
Spent the past few days getting off my ass to get the car ready to bring to the challenge. If I am successful then it will run in over budget.
Quick overview then pictures...
I need to tear the car down completely and do some finish welding on the chassis and a little on the body. Then reassemble and verify all the systems. Finally tie up the bits that aren't needed for the challnge but will be needed for street legal use.
And now the pictures...
Hood off
Cooling removed
Front suspension subframe removed
Ready for engine removal, then body removal then rear suspension removal, then welding and painting.
I need more space...
stafford1500
stafford1500 Dork
3/1/25 9:20 a.m.
Another week and a little more progress.
Engine, gearbox, wiring harness, interior, fuel system, and rear access tin work removed.
Time for some bodywork welding then I can split the body from the chassis. Chassis work/welding after that.
Reassembly is the reverse of removal...
TurnerX19
TurnerX19 PowerDork
3/1/25 10:11 a.m.
The fact you worked at Swift is blatantly obvious in your suspension. David Bruns was a master. He should have patented the camber shim outboard on the upright.
Dusterbd13
Dusterbd13 MegaDork
3/1/25 1:29 p.m.
You do amazing work sir.
Im looking forward to seeing it in a few weeks. Wish I had time to offer to help.
stafford1500
stafford1500 Dork
3/2/25 12:38 p.m.
Sketch factor...
ALL OF IT
Body separated from the chassis
stafford1500
stafford1500 Dork
3/2/25 1:57 p.m.
Success. After 25 years of slowly adding things to the chassis, mostly with the body fitted, it cam apart with only minimal fight. I guess I did an ok job of thinking through systems integration.
Now I can progress with the interior body welding and final chassis welding before reassembly.
I COULD install the driveline and run it up and down the street without the body, but that would take extra time.
3/2/25 7:16 p.m.
i'll bring tin snips and rivets and skin that center tunnel for you. ;-)
stafford1500
stafford1500 Dork
3/2/25 7:47 p.m.
Done for the night. Only a little more grinding to do on the body. Some of these areas have not been visible since I dragged this project from southern California to North Carolina in 2008.
Had to stop and celebrate a little since I have been dreading this disassembly and clean up. It's not as bad as I thought it was going to be and I can see my learning curve in the work.
La Unica never fails.
stafford1500
stafford1500 Dork
3/2/25 7:48 p.m.
Already done and sitting to the side for now. I appreciate the offer though. If I need help I know how to find you.
a_florida_man
a_florida_man Dork
3/2/25 8:10 p.m.
This is exciting!
Steve, please feel free to continue any needed extra effort at my house if you need, challenge week.
Seeing this run will be epic.
3/2/25 8:34 p.m.
i so get that. not that i'm good now, only that i'm better than when i started.
gumby
gumby SuperDork
3/2/25 10:20 p.m.
Samesies, and probably the biggest reason my truck will always be in my fleet.
Dusterbd13
Dusterbd13 MegaDork
3/3/25 6:02 a.m.
Mary and I will be at the hotel Friday as free range teammates
stafford1500
stafford1500 Dork
3/8/25 6:43 p.m.
Body mostly primed.
Chassis completely stripped and the top/side surfaces ground.
Next up top side finish welding then flip it over and do the bottom side.
I think I am going to get it on high stands tonight to make welding easier on my back. Also easier to flip it over.
stafford1500
stafford1500 Dork
3/9/25 9:03 p.m.
The body is mostly in primer and curing. I got the top side of the chassis done and ran out mig gas. Flipped the chassis over to prep for the bottom welding. Empty bottle is strapped in the back of the truck for a lunchtime visit to the welding supply shop tomorrow.
I have a big hardware order out to mcmaster and that should all arrive Tuesday so I can start reassembly, assuming I am done welding.
I need to put the seat belt anchors in while I have all apart. So that will be the first thing after flipping it back over.
6m2FJ2FDkazl9QtutKh6FknNKjFEaM3E0VNw5bHKvb6F3dwEfEWEmpeSKdWSACHx
