Some stuff came in today, and this weekend is the last gasp of work to make sure everything is working and ready to roll for next weekend (the 18th)!
First, a GRM member hooked me up with a killer deal on a new Spal 14" low-profile puller fan, which came in today. Didn't want to deal with the various mounting brackets, so decided to improvise using the factory shroud (which should also keep some mud, etc out of the fan blades). I used M6 bolts, whose heads fit perfectly in the Spal mounting slots, for main support at top and bottom. Though the fan sits flush against the radiator upper and lower caps, just to be sure I used some zip-ties through the screw-mount holes to secure it even better. A pretty good fit I think. I would have gotten a 16" for a perfect fit, but that would have cost twice as much, and 14 should be fine with an 80 switch and a 71 thermostat.
the fan
mounted up
test-fit on the old radiator. The new radiator should be in tomorrow so I can put everything back together. I may also fab up some plastic panels to "seal" the fan area around the sides of the electric puller, we'll see. Probably not necessary, but could help with the suction.
Also another little project. I said earlier I installed an old CD player of mine and it worked great. Nope. Now I remember the reason I took it out of a previous car in the first place - the LCD screen is wack. Works occasionally, but shows the wrong displays. Other times doesn't work at all. Checked all the face connections and they seemed fine, and eventually just gave it up as a waste of time to try to fix.
Did a bit of research, jumped on Amazon, and picked up a Kenwood "basic" unit. It has the same power as most of the mid-range models (50w x 4 MOSFET), but has only basic features: a CD player, a radio, and a mini-jack for plugging in an iPod. No digital storage, satellite radio, or other techie stuff, just a basic unit. Cost me $50 shipped, and I had a $15 Amazon credit already, so dirt cheap. Installed it (soldered connections) and it works great, and sounds surprisingly good running 2 old speakers. Not as good as my system in the other cars, but pretty damn good for a rallycross beater.
I'll keep the deck keys in the glovebox and pull the unit at events so it doesn't get vibrated to death, lol.
Also looks pretty decent too, though the display is VERY basic. Just fine by me.
Also the brake pads came in for the front. I went with Hawk HPS because I got them pretty cheap and have used them on my last 4 or 5 cars and always liked them. Will get the used front rotors turned tomorow so I have fresh surface, and then the brakes will go back together, skidplate back on, and car back on the ground.
After that, just a few other little things and I think I'll be ready!
