Well it's Friday, so I was out in the garage this morning working on the 996. First up, the oil leak on the drivers side turbo. Here's what it looked like
Seems like it's coming from the rubber gasket that's holding the oil tank onto the turbo itself. Sigh. Ok, well, there are two bolts holding the tank onto the turbo, the one you see outside and another one that's actually inside the oil tank. So you have to remove the oil tank drain plug to access it. When I remove the oil tank drain plug I stare at it for a bit. Then look at the oil tank, then back to the oil drain plug a few times. Umm, there's supposed to be a metal crush washer here on the drain plug, but there isn't. And it's not stuck to the oil tank. Is it really going to be that easy? Put a new drain plug washer on it, torque it to spec. I'll check it again after I'm done with the 5 bar fpr.
Ok, time to install the 5 bar fpr. It's located on the passenger side of the motor, on the top, near the back. Access is really poor, when a dentist says that, listen! This is one of those jobs that while it's not technically difficult, it's totally worth paying someone else to do! Let's put it this way, I hope I never have to do it again!! Start out by removing the airbox, then disconnect the boost hose going to the Y pipe. Now you have to remove 5 10mm bolts, two that hold the SAI pump bracket to the car and 3 that hold the SAI pump to the bracket. Unclip the two harnesses from the SAI pump and undo the hose from the SAI pump itself.
Now push the oil filler tube toward the drivers side of the car and push the SAI pump into the rear right corner of the engine bay. You can now just see the fpr. The clip holding it on is on the bottom from the factory. Using a long set of 90 degree needle nose pliers, grab it and pull down on it to remove it. Do NOT drop it! Now attempt to remove the stock fpr. I ended up grabbing it gently with a set of channel lock pliers and rocking it out. Get ready to board the struggle bus as the new fpr won't want to just pop into place. I lubed the O rings on it several times, didn't matter. I pushed, I twisted, I cursed, nothing. I tried to lever it on with the rubber part of a jack handle, a pry bar, a big screwdriver, a piece of 2x4, nothing. Cursed some more. I then used a combination of the 2x4 and the rubber coated end of my bmw water pump wrench to lever the living heck out of it.
I then stared at it for a bit. Is it really in place? It looks like it is. Will the clip seat? Let's try. This time I put the clip in from the top. First try I didn't get the clip lined up correctly, but the second time I did and it made an extremely satisfying "click" when it dropped into place. O. M. G. Words do not describe my relief at this point. Ok, get the vacuum feed back onto it and snake a few zip ties onto the vacuum feed so it won't pop off.
Now you get to have all sorts of fun getting the SAI pump back into place, bolted onto its bracket and then bolting the bracket to the motor. Make sure to drop the bolt holding the oil feed tube in place down into the depths of the engine bay. Luckily I found it wedged between the exhaust heat shield and the rear firewall. Tighten everything up, go start the car. Happily the car still runs fine and doesn't make any new strange noises. Oil leak seems to have been solved! No more smoke coming off either turbo, so all the PB Blaster etc has burned off.
Looks like the car is ready to get tuned. The local tuner will inspect it and boost leak check it before he puts it on the dyno. He's going to make 3 maps for me, low boost, high boost and valet, I'm going with 91 octane for all of them. E85 is too much of a PITA, I just don't want to deal with it.
I still need to do an oil change, fix the hvac blend doors and then do a brake fluid flush in the Spring. Done with the car for today tho, that was far more work than I expected....
