9 10 11 12 13
4/11/16 7:13 p.m.
Ha! Love it.
Ben_Modified
Ben_Modified Reader
4/13/16 6:36 p.m.
Made up a couple of Stainless caps out old band clamps
My other builds
Ben_Modified
Ben_Modified Reader
4/14/16 4:18 p.m.
Finished up the front turn signals
My other builds
brad131a4
brad131a4 Reader
4/14/16 6:11 p.m.
OHOHOH jesus we have crossed over into crazy town now and I LIKE it.
Ben_Modified
Ben_Modified Reader
4/16/16 11:59 a.m.
brad131a4 wrote: OHOHOH jesus we have crossed over into crazy town now and I LIKE it.
Ha, thanks!
Started building a couple of side scoops. Split a piece of 3" exhaust tubing and went from there.
The back half will quick release for engine compartment access
Rear section is still rough
My Other Builds
Ben_Modified
Ben_Modified Reader
4/19/16 7:07 p.m.
Ben_Modified
Ben_Modified Reader
4/21/16 4:19 p.m.
Ben_Modified
Ben_Modified Reader
4/24/16 6:05 p.m.
Dusterbd13
Dusterbd13 PowerDork
4/24/16 8:00 p.m.
I think the side scoops would also be an awesome hood scoop on something.
Ben_Modified
Ben_Modified Reader
4/26/16 5:34 p.m.
I blocked off the gap along the top of the radiator to prevent hot engine air from getting drawn into the front side of the radiator. Along with the side scoop and swapping the 190 degree thermostat for a 160 my highway operating temp has gone down from 210 to 175.
My Other Builds
jmc14
jmc14 Reader
4/26/16 9:42 p.m.
This build is fantastic. Your creativity and fab skills are inspiring.
Ben_Modified
Ben_Modified Reader
4/27/16 6:58 p.m.
jmc14 wrote: This build is fantastic. Your creativity and fab skills are inspiring.
Thanks so much!
Got started on the Engine Cover/Hood today. The plan is to make it look very similar to the roof on the cab
My Other Projects
NOHOME PowerDork
4/27/16 9:32 p.m.
You need to go into a bit more detail into how you got the shape into the closing panel.
Please.
Ben_Modified
Ben_Modified Reader
4/28/16 9:06 a.m.
NOHOME wrote: You need to go into a bit more detail into how you got the shape into the closing panel. Please.
I have been videoing the process. I will post it once the hood is mostly done.
Did some more work on it this morning. Still need to weld in the corner patches, the underside and smooth.
Ben_Modified
Ben_Modified Reader
4/30/16 2:49 p.m.
Made some more progress on the hood today. Got both of the rear corners welded in, just need smoothing.
My Other Builds
Ben_Modified
Ben_Modified Reader
5/1/16 10:30 a.m.
Tack welds are ground smooth
Clearance for the rear window
My Other Builds
YoloRX7
YoloRX7 New Reader
5/1/16 12:31 p.m.
Wow! I just found this thread. I am not really much of a old school VW fan but this thing is wicked awesome. I'll be following the rest of this build for sure. Good job Ben.
Ben_Modified
Ben_Modified Reader
5/2/16 6:02 p.m.
YoloRX7 wrote: Wow! I just found this thread. I am not really much of a old school VW fan but this thing is wicked awesome. I'll be following the rest of this build for sure. Good job Ben.
Great, glad you like it.
Wheeled the other end cap today
My Other Builds
Ben_Modified
Ben_Modified Reader
5/5/16 5:43 a.m.
Hood is nearly done. Still need to run thru the english wheel to smooth and crown
Found these intricate bmw hood hinges at the self serve salvage yard for $5
My Other Builds
Ben_Modified
Ben_Modified Reader
5/5/16 5:22 p.m.
Setting up the hinges. This should allow the hood to hinge at the front and open fully without hitting the back of the cab
My Other Builds / Youtube page
brad131a4
brad131a4 Reader
5/6/16 11:28 a.m.
Sweet!! got to love repurposing good designed parts from other makes to accomplice things you need.
Ben_Modified
Ben_Modified Reader
5/6/16 8:13 p.m.
brad131a4 wrote: Sweet!! got to love repurposing good designed parts from other makes to accomplice things you need.
Absolutely!
Todays progress.....Completely installed the hood hinges and fabricated a framework to sandwich between the hinges and hood for strength.
Ben_Modified
Ben_Modified Reader
5/7/16 6:12 p.m.
Ben_Modified
Ben_Modified Reader
5/8/16 9:39 p.m.
Here you go!
Part 13 of the Build
Ben_Modified
Ben_Modified Reader
5/10/16 6:38 p.m.
The hood and the remote latch are mostly done.
My YouTube Page
9 10 11 12 13
rKZhleGWztjtwUZvz8bMbrM7HrzGHt9PpsKr7DYALxHCg2bfYCmSV4R8wywL9E5d
