1 2 3 4 5
VWguyBruce
VWguyBruce Dork
3/10/15 5:57 p.m.
This is quite a bit of wow. You're really making me think about what to do next with my automotive want list.
84FSP
84FSP Reader
3/10/15 6:00 p.m.
Seems like it will be quite rowdy. Curious to see what you have in mind for interior..
Ben_Modified
Ben_Modified Reader
3/11/15 6:38 p.m.
Progress on the motor and trans mounts. Everything is at least tacked. Still need to plate everything and finish weld.
My Other Projects
Ben_Modified
Ben_Modified Reader
3/12/15 12:58 p.m.
bgkast
bgkast UltraDork
3/12/15 2:55 p.m.
is the front of the engine cradle/rear suspension only supported by the spring? What's to stop fore/aft movement of the assembly, or to prevent it from hitting the frame when the weight is taken off of the wheels?
Ben_Modified
Ben_Modified New Reader
3/12/15 3:50 p.m.
bgkast wrote: is the front of the engine cradle/rear suspension only supported by the spring? What's to stop fore/aft movement of the assembly, or to prevent it from hitting the frame when the weight is taken off of the wheels?
Yes, the spring does support the front of the cradle. It also acts as a flexible joint/pivot. The rear of the cradle is connected directly to the rear axle housing. The stock Explorer leaf springs are still in place which support the main frame and prevent the fore/aft movement of the cradle with the exception of the slight fore/aft movement of the cradle which is caused by compression of the rear leaf springs. There is a slip joint built in to the front spring assembly which allows for this movement.
84FSP
84FSP Reader
3/12/15 3:51 p.m.
Maybe I missed it, gas tank goes where?
Ben_Modified
Ben_Modified Reader
3/13/15 5:12 p.m.
84FSP wrote: Maybe I missed it, gas tank goes where?
Under the bed and behind the axle
Ben_Modified
Ben_Modified Reader
3/13/15 5:16 p.m.
Drivetrain is in and connected to rear axle
Ongoing Projects
hobiercr
hobiercr Dork
3/13/15 6:59 p.m.
Ben, where are you located? Looks like FL or somewhere similarly tropical.
84FSP
84FSP Reader
3/13/15 10:01 p.m.
Nicely done sir.
Ben_Modified
3/17/15 6:32 p.m.
Fuel tank is in and plumbed to the fuel pump.
Ben_Modified
Ben_Modified Reader
3/17/15 6:38 p.m.
Steering box is in process.
Fitting the cab at the same time to make sure everything works together.
Gutted the swiss cheese floor to make way for a new raised floor.
Plan on reusing the original parking brake handle
My Site
Lof8
Lof8 Reader
3/17/15 7:19 p.m.
This is cool!
Ben_Modified
3/17/15 7:22 p.m.
Cab still needs to drop another 8 to 10 inches.
Ben_Modified
3/18/15 5:54 p.m.
Relocating the Headlight Buckets
Removed much more floor to lower cab further
Cab needs one more inch of drop
Everything below the blue tape on the cab and doors will go.
My Build Site
Ben_Modified
Ben_Modified Reader
3/20/15 6:22 p.m.
Part 4 of the Video Build Series
The Cab is in its final location, just need to trim off the bottom of the doors.
My Build Blog (multiple projects)
Ben_Modified
3/20/15 6:23 p.m.
hobiercr wrote: Ben, where are you located? Looks like FL or somewhere similarly tropical.
SE Georgia
Ben_Modified
3/20/15 6:27 p.m.
84FSP wrote: Seems like it will be quite rowdy. Curious to see what you have in mind for interior..
Spray-on Bed Liner inside and out. If its not Black, its Chrome. Stock bench seat with new cover and seat heaters with an A/C unit hidden under the seat. Chrome safaris front and back. And, of course, I tractor steering wheel.
Ben_Modified
Ben_Modified Reader
3/21/15 12:43 p.m.
Putting metal and strength back in.
My Build Blog
Ben_Modified
3/23/15 5:56 p.m.
Started on the integrated roll cage/body mount system for the Cab today. (Lower part of the picture, the part in the middle is temporary bracing)
Ben_Modified
Ben_Modified Reader
3/28/15 3:23 p.m.
The main Cab Mounts are done. Still have a lot a cage tubing to go.
My Other Projects
Ben_Modified
Ben_Modified Reader
3/30/15 8:43 p.m.
More tubing
My Other Projects
Ben_Modified
Ben_Modified Reader
3/31/15 6:06 p.m.
Started building a compartment to fill this void in the frame under the seat. It will house an A/C-Heat unit.
Started with a sheet of 18 Gauge
Unfortunately, my electric metals shears broke a few days ago. Had to make due with tin snips
With any luck, this will be a rectangular under seat compartment in a day or two.
My Build Blog
Ben_Modified
Ben_Modified Reader
4/1/15 1:48 p.m.
https://lh4.googleusercontent.com/-KfD-0N9NaQE/VRw7kPR_LPI/AAAAAAAABDE/fHURgwnTGmE/s512/20150401_115330.jpg
1 2 3 4 5
I38RZbYG4doSkluxXmMgV3BZ8pYd3FtiEYUMoJF6TH2ZarqRKiu8zWR1Zn3sFDyY
