Chadeux
Chadeux Reader
5/21/16 3:52 p.m.
Welp, guess I need to learn how to engineer a gantry.
Also the seats weren't bolted down and what was left of the dashboard sort of fell off after I looked at it hard.
EDIT: after some googling, I think we could make this work with a bit of creative rigging on the engine hoist. This cab /probably/ doesn't weigh much more than a 440/727, and nobody died when we lifted that.
Chadeux
Chadeux Reader
5/23/16 2:07 p.m.
The 5(!?) layers of floor coverings are out, and the rust is actually not as bad as I expected, and instead of viewing this as being terrible at pre-purchase inspections, I'm going to view this as an opportunity to try sheet metal work on a vehicle that nobody is going to miss if I screw it up. I'll get pictures after I charge my phone.
EDIT:
Upon closer inspection, I think it's exactly as bad as I thought it was. There's a rubber coating of some sort glued to the metal that I think is still hiding the worst of it.
Chadeux
Chadeux Reader
5/24/16 4:48 p.m.
Started taking the front of the truck apart to get the V6 out. When I pulled the radiator hoses, some nasty smelling rusty water poured out, and then I pulled the trans cooler lines, nothing came out. I feel like neither is a good sign.
mazdeuce
mazdeuce UltimaDork
5/24/16 4:53 p.m.
If the V6 is dead it's not a HUGE deal is it? It just means you're not getting money back from it.
As for the rust repair, if it were me, I'd take this as a sign that you need to do a body drop. No use putting metal back in the same place.
Chadeux
Chadeux Reader
5/24/16 4:54 p.m.
I had just talked myself out of the body drop, and I really wasn't that worried about the v6. I was hoping the reuse the trans at least for a little while though.
EDIT: We were thinking about doing a cab swap, but I might actually just shift focus back to fixing my red truck for a bit, then once that one is reliable again, I'll go ahead and go crazy on this one.
mazdeuce
mazdeuce UltimaDork
5/24/16 5:00 p.m.
One broken truck at a time is good form.
Chadeux
Chadeux Reader
5/24/16 5:04 p.m.
Yeah if I was smart I wouldn't have bought this one but at the time it looked like I could put together quick and have a cheaper to run beater while I put the red one together how I wanted. As soon as I saw it knew that wasn't happening, but I had just driven 4 hours and figured it would still be a good cheap project,so I bought it anyway.
Chadeux
Chadeux Reader
7/21/16 9:17 a.m.
So it's been decided that the donor truck is somehow still too nice to cut up. So I'm considering plan...G, probably G.
IndyJoe
IndyJoe Dork
7/21/16 9:34 a.m.
Oooooh, YES!
Vette Kart.... er, I mean Ram Kart
Chadeux
Chadeux Reader
7/21/16 9:39 a.m.
Thinking about going and taking the cab/bed off so I can see how short the chassis can be if not limited by wheel openings.
Dusterbd13
Dusterbd13 PowerDork
7/21/16 10:36 a.m.
Do it!!!!!!!!!
edizzle89
edizzle89 Dork
7/21/16 12:06 p.m.
Chadeux wrote: So it's been decided that the donor truck is somehow still too nice to cut up. So I'm considering plan...G, probably G.
this seems like the only reasonable solution
Chadeux
Chadeux Reader
7/22/16 12:22 p.m.
I thought about this more while at work, I think the best way to do it would be to leave the cab floor and firewall. Just so I then don't have to come up with a new place to mount the brake master cylinder and steering column too.
edizzle89
edizzle89 Dork
7/22/16 1:19 p.m.
Chadeux wrote: I thought about this more while at work, I think the best way to do it would be to leave the cab floor and firewall. Just so I then don't have to come up with a new place to mount the brake master cylinder and steering column too.
thats what I would do, it also retains seat mounts, pedals, gauges, and the dash if you want to retain it. I have similar plans for a crown vic and decides keeping the firewall/floor (atleast the front half of the floor) would not be as pretty, but save a lot of headaches.
Chadeux
Chadeux Reader
7/22/16 11:18 p.m.
Most of the dash is gone already, but the dash support bar thing is also the upper steering column mount, it probably stays.
Chadeux
Chadeux Dork
1/30/17 3:26 p.m.
So does anyone want the worst possible start for a Challenge truck? Otherwise I'm going to try to pull the tool boxes and wheels off of this thing and haul it to the scrap yard soon.
K24Dy6luBW067V5Dyxwfnj9Fzxi3IW3Swv0HXkzrmTFTqAZoeCaiScogIls6cjX9
