Me jealous. I got my drugithome to make big fat sparks but when I had the plugs out to flush the cylinders out, the vapor that came out did not smell like gasoline as we know it. Spinning the (not tightened down) distributor around only gets me backfires through the intake and out the exhaust, but never any actual cylinder firing.
CIS + junk fuel = uuuuuuugh.
EvanB
PowerDork
4/2/13 12:03 a.m.
I don't envy you there, CIS and I don't get along.
EvanB
PowerDork
4/8/13 9:13 p.m.
Went for a drive the other day and it started getting a bit hot and knocking under load. I think I have some air in the cooling system. If I bleed that out it should take care of the running hot, Not sure what it's up with the knocking.
Honestly there could be carbon build up, you may need to run premium if your timing is correct. My dad had to do that a while on his Corvair until he rebuilt the engine.
EvanB
PowerDork
4/8/13 9:36 p.m.
Yea I was thinking of that, it only started knocking after driving it for awhile and it got warm. I'll have to double check the timing. It also burns quite a bit of oil, especially while cold, possibly rings aren't seated?
Needs an Italian tune up!
Run premium for a few tanks, MMO in the fuel and the crankcase in small quantities.
You mention the rings not being seated, is it a new bottom end? If not then the rings should be seated. Adjusted the valves on it?
EvanB
PowerDork
4/10/13 2:34 p.m.
It isn't a new bottom end, it was just sitting for 5 years. I didn't know if that would cause any issues.
Do these have valve stem seals? They might have dried out in that time. Italian tune up gets som fresh oil up the head and might freshen it up.
EvanB
PowerDork
4/10/13 3:58 p.m.
I put some octane booster and a bit of MMO oil in the tank then topped it off with 93 octane (1/4 tank). It seems to be running a bit better but still bogs down when starting off and doesn't idle without the choke pulled out a bit. I'll have to fiddle with it some more and keep driving it.
EvanB
PowerDork
4/10/13 4:00 p.m.
I just thought of another thing...the oil fill cap is vented and may be clogged. I ran into that problem with my 1098 Midget. I'll have to check it out next time I take it out for a drive.
Knurled
UltraDork
4/10/13 4:59 p.m.
You used to have a Midget? Dang, the Miata must be like having a big block Impala in comparison...
EvanB
PowerDork
4/10/13 8:28 p.m.
In reply to Knurled:
Yep, even the stock 1.6 I had at the same time as the Midget.
EvanB
PowerDork
4/10/13 10:29 p.m.
A picture of the Midget for fun.
EvanB
PowerDork
4/12/13 2:14 p.m.
Well it doesn't seem to be the oil cap. I took it off and it still runs rough and bogs down.
EvanB
PowerDork
4/18/13 7:00 a.m.
Drove the mini to work today and didn't know if I would make it. It started running very hot and was misfiring a bit. Still knocking under load.
Held a timing light to it?
Ian F
PowerDork
4/18/13 10:24 a.m.
Is the advance working correctly?
EvanB
PowerDork
4/18/13 11:31 a.m.
The advance moves slightly when I suck on the hose but it feels a bit stiff. How freely should it move? I'll have to check the advance with a timing light when I get home.
EvanB
PowerDork
4/29/13 6:50 p.m.
I boiled the thermostat and it opened around 195, seems a bit high. The radiator doesn't look bad and the coolant was fresh, the water pump impeller seems to still be attached as it agitates the coolant when spun.
195 is an acceptable temp for that thermostat, see if there are lower ranges out there for that motor though.
EvanB
PowerDork
4/29/13 8:52 p.m.
There are 165, 180 and 190 thermostats available. The gauge was pegged though so I think I may need more than just a cooler thermostat.
EvanB
PowerDork
4/29/13 8:53 p.m.
It was running fine and staying cool until one day when I was driving and it started getting hotter and knocking...it has just ran hotter and hotter since then.
EvanB
PowerDork
4/29/13 9:18 p.m.
Not with it running yet, would that still affect it at idle and low revs?
