3 4 5
10/2/24 10:25 p.m.
Finally got my calendar meshed with my trusted independent repair guy and retrieved the Saab this evening. Most of the clunks are gone. Time will tell if these pads make less dust than the previous ones. This service included:
  • new front lower control arm assemblies
  • new outer tie rod ends
  • new rear upper lateral link bushings
  • new right rear shock and upper mount
  • new front pads and rotors
  • new rear pads and rotors
  • new Falken Sincera tires all around
AK1 drove me out in the SS and I followed her home in the Saab. 174k and counting. AK1 is a big fan of the 415 hp / manual trans combo. 3BABY9 for life!
EDIT: WTF rotated pic?!?! Is this a feature of the new server?
10/2/24 10:33 p.m.
Here i rotated the original 270° CCW and it posted in that orientation, vs the previous post it was right side up portrait style and posted with a 90° CCW rotation.
John Welsh
John Welsh Mod Squad
10/3/24 12:31 p.m.
Falken Sincera tires....
The 201s have been my go-to for fleet Prius.  Not a high tech winter tire but a very good all-arounder.  Wear mileage has been very good on these 65k rated tires.  The 250s are rated for 75-80k.
Smooth, quiet and remain true, wearing evenly.  I very much like them.  They used to be really inexpensive (but what is anymore?)
10/3/24 11:59 p.m.
In reply to John Welsh :
I've got a guy at Falken, so I get a healthy discount. I drove it home about 30 miles and I can say they are quiet and seem grippy enough. AW drove the Saab to the airport today and reports "This is such a nice little car to drive." Prior to today, she had not driven the Saab since the Rowdy Audi arrived back in May.
10/7/24 4:15 p.m.
After replacing front LCAs and outer tie rod ends, the steering wheel was a little off-center and she pulled a little right. So, this morning I dropped the Saab at my local Belle Tire for a 4-wheel alignment. They turned it around in under 2 hours, and all is well. Dude said "are you aware of the rust in the front subframe?" So I explained that I was not yet done patching it up.
174k and counting. AW loves this car.
11/9/24 5:56 p.m.
Spent some quality time on the Saab today. goal was to patch the hole on the back of the subframe on passenger side (pic from a few months ago):
as well as bridge over the exhaust to replace some of the lost vertical strength in this section. Started with a trip to The Future Hammer Store for a finger sander, then dragged out the CAD and the plasma cutter (V2 shown):
The finger sander allowed me to get down to clean metal for welding:
and that's where I ran out of daylight. I will make a similar bridge piece for the forward section, then tie them together across the bottom. It won't be as good as OE, but it will be better than it was yesterday.
note: doing this E36 M3 on my back on the cold concrete driveway was not nearly as fun as many other things I've done, but I appreciate having the tools and the ability to do such things.
paul_s0
paul_s0 Reader
11/9/24 7:03 p.m.
Good work AC, and the fun comment reminds me of lying on my back, on the driveway, in the snow, in the dark, welding up my then rally car (TR7)- DEFINITELY not fun, but appreciated that I could do it!
11/23/24 10:29 a.m.
A few days ago a close family friend asked if I had any loaners in the fleet. Not knowing if I had any bike rides or junkyard runs in my near future, I elected to keep Ody at home and loan out the Saab. This car has been the gift that keeps on giving. She's due for oil change and ATF spill'n'fill, plus a fresh set of winters because there's no berkeleying way those loud-ass Sumitomos are going on again.
11/30/24 7:27 p.m.
World's Loudest Winter Tires have been scrapped. New Blizzak WS90s installed today. 175k and counting. Still love this car.
12/29/24 9:26 p.m.
Oil and filter change today:
plus installed the resistor packs to stop the aftermarket LED headlight bulbs from flashing when the BCM checks for burned bulbs.
The packs are pretty nice, it's a little box with a slotted mounting tab and an IN and OUT pigtail with "OEM-like" connectors. Pulled the bumper and the headlights:
drilled a 1/8" hole in bottom of housing:
used an aluminum pop rivet plus a couple of aluminum washers to distribute the force:
and added a dab of black RTV to seal the rivet to the housing:
result: no more flashing. Can't call it great success though, as the message center still displays Left and Right low beam faults on key up. Regardless, at 176k we still dig this car.
1/20/25 7:03 p.m.
Added a free-standing touchscreen that plugs in to OE audio via AUX and lets AW have wireless CarPlay. It's attached via magnetic phone mount in the CD slot. It drops connection occasionally, and doesn't always recognize her phone when she gets in the car, but it connects to mine every time. Maybe because I was it's first.
3/11/25 6:14 p.m.
Last time I had front wheels off, I noticed the LF coil spring was broken at the bottom, and I decided to roll the dice. This AM, after what was no doubt a sweet Bo and Luke moment, AW texted me "there's a new noise from LF of Saab." Local-ish U-Pull has a plethora of 9-3's in the yard (5, to be exact), so I grabbed some tools and headed out. The first 3 also had broken springs. Cars 4 and 5 seemed viable, but one still had Saab parts tags and the other had KYB, so I grabbed the KYBs.
The gods of rust belt corrosion had mercy on me, and I harvested both in a leisurely 90 minutes. It was a beautiful day here, and what better place to spend it than a JY I've never been to.
4/4/25 3:18 p.m.
Pure Michigan. IYKYK
dj06482 (Forum Supporter)
dj06482 (Forum Supporter) UberDork
4/4/25 5:35 p.m.
CT does that, too!  And yes, that's a broken spring sitting on the top of the end link.  Supposedly the rubber sleeves on the bottom of the spring trapped moisture, and caused the springs to break.  The fix is a galvanized metal piece that the spring rests on.
3 4 5
kfYQWxp4Asi7SBAYIFM30JobVzx5hNAYddXl5Zl6hihi4s4NPETGtFxAzzZw2Byh
