Day 1 of wiring
First Up
- Red Band - Needs to be connected to 12v power through a fuse. Recommend a 30A fuse. Some users have gotten away with a 20A fuse, but OEM was 30A so that’s what I use.
- Orange Band - Same as the red banded wire. Needs its own 20-30A fuse. 30A recommended.
I routed these up an udder in into the cowl to protect them from the engine. A few zip ties to secure them out of the way of the wiper motors. Drill a hole to drop back in before the cowl gets thick and use a grommet. Both ran to the Battery terminal on the fuse box by the battery. I used inline 30A fuses for these. I may extend the routing or try to hide it in the fuse box eventually, but it works for now. I'm not happy with how professional it looks, but its functional.
- Yellow Band - Needs to be connected to switched (key on) 12v power through a 5A fuse. This needs to be switched power, or the ABS unit will drain your battery when the car is off.
This used the same cowl routing. I have an inline fuse for it, but haven't determined a source yet. I assume one is there in the fuse box.
- Blue Band - This is the brake pedal/light switch signal. This tells the ABS module when the brake pedal is depressed and ABS should be enabled. This needs to be connected to ground when the brake pedal is pressed and an open circuit when not pressed. This is backwards from most cars (most cars are ground when not pressed and open circuit when pressed). Check your existing brake switch output and if it does exhibit the above behavior, you lucked out and you can just splice into the OEM brake pedal switch. If not, don’t fret; there are quite a few ways to do this, below are a few of the most common -
- Add an additional brake pedal switch. Using normally closed switch like one side of the the Painless 80176 and connect using the normally closed part of the switch. Connect to ground on one pin and the Blue Band wire of the ABS harness on the other.
- Add a brake pressure switch. Add this inline to one of the brake lines from the master cylinder to the ABS module. One pin should connect to ground and the other to the Blue Band wire of the ABS harness.
- Using a standard automotive relay to convert the signal from the OEM brake signal to the signal required by the MK60.
- Connect Pin 87 to Chassis Ground.
- Connect Pin 86 to OEM Brake light switch ‘hot when pressed’ wire
- Connect Pin 85 to Chassis Ground.
- Connect Pin 30 to the Blue Band wire of the ABS harness
- Connect a Zener Diode between Pin 86 and Pin 85 of the relay with the Band end at pin 86 to protect the switch from back EMF when power is removed
I ran this into the cabin through a hole I drilled next to where the hood release cables enter. Its right next to the ABS mount. I didn't get to hooking it up today, but I did find that my c5 has a brake switch with an extra set of contact. These are closed when the pedal is up and open when the pedal is down. Wire one to ground and one to the ABS and it should work. If you have a c5 that uses the 2nd set, I found a brake switch with a 3rd set of the terminals. ACDelco GM Original Equipment D1541D. Unfortunately I don't have the plug. I also ordered a relay so I can just pick up the brake light wire if needed.
- Green Band - Connect to the positive side of the fault light (MIL). This is a 12v signal so ensure you’re using a 12v rated light
- Black Band - Connect to the negative side of the fault light (MIL)
I ordered a light https://www.amazon.com/dp/B0B28376HL?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 but its already a few days late and won't be here until too late. Luckily my first event is just an autocross so NBD if it fails and I don't notice it.
YAW/ REAR BRAKES
The Yaw harness I ran inside the same hole I made for the brakes above. I drilled a 1" hole so I could pass the whole connector as well as the rear brake speed sensors wires here.
Here's the loom coming out of the ABS and zip tied to the support
Next up the hole from the outside of the car
On the inside I used a bit of butyl rubber to stabilize, but there is a grommet as well. Its just above the dead pedal and fairly easy to drill from this side.
Then its just zip tied above the pedal box until I can stuff it under the center console trim on the other side
When I got the the padded armrest bin I needed to cut a channel for the yaw and two brake sensors here. I'll probably come back with some slit wire sleeve here soon.
The Yaw will be mounted at the rear of this console. It should be out of the way. I designed a mount in fusion 360. I'm printing it now. The Brake sensors continue into the cargo area. I drilled another 1" hole at the corners of the side bins. That drops the wire right in the corner of the wheel wells. I chose to go through the car to keep the wire more protected. Otherwise it would have been near the headers.
When I got the the wheel wells I entered the factory wire management as soon as possible.
I matched the length, cut the factory wire and then reused the back half of the factory clip. They hold onto the wiring loom really well and it clips into all the wire management. This is it done.
Both sides are slightly different, but similar strategy. Enter the factory wire protection early. Wrap the wires in tape to get them more wear resistance. Use the factory coverings, wire management and plug clips.
FRONT BRAKES
They come up by the washer tank. and run down the factory wiring to where the ABS used to be.
I joint the factory wiring loom as soon as possible. The routing is a little different right near the steering rack, but I reused as much of the factory loom protection as possible.
It was really hard to get shots of the routing so I made a short video to talk about it.
Other stuff
- Put the fans back in
- Went back to water + water wetter for coolant. I boiled it while waiting for the thermostat to open. Opps.
- Hooked the front sway bar back up
- Any of the exposed wire I'm going to come back with some split loom and get it protected soon.
