Doc Brown
Doc Brown Dork
8/7/19 5:43 a.m.
In reply to 84FSP :
The only obstacle encountered with the bottom seat skin was the power seat switches, other than that they are a snap to replace.
Doc Brown
Doc Brown Dork
8/9/19 10:17 p.m.
The last part........
Whelp, it was time to swap in the last part in this mechanical odyssey.  The door lock...
In this day and age of key fobs, it would be easy to ignore the door lock.... but I'm old school and using a key to unlock the door is engrained in my DNA.    Changing the lock cylinder was straight forward and without drama.
The warm and inviting cabin trimmed in rich leather is not too shabby for a $510.00 hooptie.
.......and done!
ShawneeCreek
ShawneeCreek HalfDork
8/10/19 4:18 p.m.
Nice work. That was a pretty quick turn around given all the work needed.
wheelsmithy
wheelsmithy SuperDork
8/10/19 5:52 p.m.
Great work. That generation Caddy rules.
Doc Brown
Doc Brown Dork
8/10/19 5:57 p.m.
In reply to ShawneeCreek :
Thanks!
My motivation for getting this done ASAP was the amount of space all the parts occupied.  Today I'm sorting through the extra junk and getting ready to scrap the parts car.
As you know this was a massive nuts and bolts project,  The only real problem solving was trying to figure out how to move all the big parts
 To give an idea how extensive this project was, this tiny A/C bracket is the only original part under the hood of the car.
759NRNG
759NRNG UltraDork
8/10/19 8:18 p.m.
Catching my breathe here boss, wow that was quick.....great job!! and you really changed the rear susp's using a floor jack and jack stands....woof . Unfortunately ,I'm looking at a similar exercise with annoying 'popping' noises emanating from the left rear susp and a fuel leak(wetish) from the top of the tank making me not too happy......sure wish I had that two arm lift........sad
Doc Brown
Doc Brown Dork
8/21/19 6:39 p.m.
In reply to 759NRNG :
The rear subframe with the suspension is of course very heavy but is really easy to lower with a single floor jack under the differential.  The hardest part of the whole job is disconnecting the parking brake and the hydraulic brake lines.
Doc Brown
Doc Brown Dork
8/21/19 7:00 p.m.
Pretty much self explanatory......wink
Pretty much self explanatory sad
   According to OBDII Wan Kenobi there is a disturbance in the force.... Let's take a look.
I'm betting the spark plugs are the cause, but just in case I'll also move the coils. If this code comes back on a different cylinder then we will know for sure.
Changing the plugs on one of these engines is a lot of work for a typical Cadillac owner. There are half ass short cuts that can be done, but the proper way is to face the situation and do it right
The issue that scares a lot of folks is the upper intake manifold needs to be pulled to gain access to the plugs, however it ain't that simple. The intake manifold won't come off unless you remove a bunch or other stuff. Since I pretty much know this car inside and out, this will be a walk in the park.
This took about a half hour to disassemble
This cartoon looking box actually contains spark plugs. I'm not a big fan of gimmicky spark plugs and these may be a little over the top.   Word on the street is the 2.8 will run better on platinum so nix the Iridium's.
New plugs are set to Richard Petty 43 thousands. The old plugs looked OK but were well past 50 thou on the gap.
New  plenum gaskets were installed.  Interestingly enough the genuine GM gaskets were less money than aftermarket.
Wishful thinking?... perhaps....   Anyway a week after replacing the plugs and the check engine light has not come back.laugh
Stay tuned!
Agent98
Agent98 Reader
8/22/19 1:01 p.m.
Now a non-hooptie! Great job Doc.
Doc Brown
Doc Brown Dork
8/22/19 7:47 p.m.
In reply to Agent98 :
Thanks!
Indeed, the Caddy is no longer a hooptie... it's actually a somewhat respectable car.
GCrites80s
GCrites80s Reader
8/23/19 1:21 p.m.
That spark plug box looks like the background from a magazine ad from 1999 for something like Prolong or Slick 50. "Rev Up the Action in Your Car with Slick 50!"
That Petty picture is too fun.
759NRNG
759NRNG UltraDork
8/28/19 2:32 p.m.
Doc B.....looking at removing the entire dash in the 'V' to gain access to the mode actuator that resides behind the magnesium wall of 'pain'.  In this thread you mentioned you had help with this rascal.....is that due to the sharp edges only or is weight/sharp edges when aligning for reinstall the deciding factor ? Any info is much appreciated before I disconnect the neg cable on the battery (SIR).....thanks
Doc Brown
Doc Brown Dork
8/28/19 4:34 p.m.
Oh my,
Unfortunately the best way to get behind the  magnesium wall of pain to to pull the whole dash.
The air conditioning and heater pipes pass through the firewall and to avoid damaging them it takes two people to pull the dash.
I didn't take many pictures of the dash procedure, but  getting the dash stripped to this point is ideal before pulling the dash.
Something to consider.... The magnesium dash is split and riveted together near the HVAC assembly.  It looks like you might be able to drill out the rivets and  pull the right side of the dash, thus exposing the HVAC thingy.    I have NOT done this and it is only speculation.    I still have the old magnesium dash and I could drill out the rivets to see what happens.
If you have to pull the whole dash, then this picture shows the firewall side of the procedure.   The spike circled in red is what aligns the magnesium dash to the firewall.  The gold panel that the green arrow points to has to be pulled with dash.
You will need to pull the steering column, disconnect the parking brake, purge the Air conditioning remove the heater hoses,  unbolt the master cylinder ( leave the hydraulic hoses connected)  and pull the brake booster.  The brake booster has a locking tab that needs to be pushed in and the booster is then rotated counter clockwise to be released from the firewall.
759NRNG
759NRNG UltraDork
8/28/19 8:25 p.m.
DocB thanks for your response, from what I can discern thru alldatdiy I'm ONLY looking at disconnecting the steering column,releasing the clutch pedal assembly....and then the wall of pain.....where upon the MODE actuator should be somewhat 'visible'.....all $47 worth from gmpartsdirect (excl S&H)......can't even imagine (yes I can) what the local dealer would charge...does $1200 sound about right?
Doc Brown
Doc Brown Dork
8/29/19 5:11 a.m.
I reckon $1200 is about right, possibly on the low side.
I'm not a big fan of alldata.   They claim the clutch pedal can be removed, however it is impossible.... I spent a whole day trying.
Anyway, I had a look at the 2003 dash yesterday afternoon and it appears that the actuators can be removed without pulling the magnesium wall of pain.   If you can wait till this afternoon, I'll shoot some pictures.
ebonyandivory
ebonyandivory PowerDork
8/29/19 5:29 a.m.
You’re a much better man than I. I long for the days of my carbureted Samurai’s and their MB-3A simplicity.
759NRNG
759NRNG UltraDork
8/29/19 8:44 a.m.
Many thanks Doc....I have plenty of time..awaiting your reply .
759NRNG
759NRNG UltraDork
8/29/19 8:48 a.m.
Having the center console out of the 'V' to tighten the pinch bolt on the shifter awhile ago, I was hoping for a procedure with a little less drama.....that and I'm a cheap ba$tardwink
Doc Brown
Doc Brown Dork
8/29/19 5:26 p.m.
In reply to ebonyandivory :
When I started this project, I was way outside of my comfort zone.  This car has too many gizmos and whatnot.  The good news is it has a manual transmission so I don't have to worry about all the automatic trans BS.
Doc Brown
Doc Brown Dork
8/29/19 5:43 p.m.
The HVAC motors.......
I started taking a lot of pictures, but then had a brilliant idea.... why not make a video. laugh  Grab a beverage and some popcorn and enjoy!...
759NRNG
759NRNG UltraDork
8/29/19 7:47 p.m.
Doc B watched most of your vid thank you so very much.....if the wall of pain was left in place,could one actually remove the mode actuator ...the one closest to you with a little jiggle or am i'm looking at the full monty....wall of pain, yadda yadda....gimme some hope BRAH!!! better yet text ate3twofour6fiveone2twosix....late and mucho thanks!!!!
Doc Brown
Doc Brown Dork
8/29/19 8:00 p.m.
I'm not sure what motor is the mode motor, however it looks like all the motors can be replaced without pulling the wall of pain.   There will be some blood, but nothing a band-aid can't fix. smiley
759NRNG
759NRNG UltraDork
8/29/19 8:38 p.m.
when facing the dash it is the module just right of the the center stack .....the one you fiddled with briefly first .....what had me wigged out was this whole mess  'out of the car' floating around in your garage.....so if the wall remains in place....in your opinion, i can retrieve this cursed mod actuator..but not without some 'skin' in the game wink????
Doc Brown
Doc Brown Dork
8/29/19 9:09 p.m.
With the dash in the car all the motors are accessible.  The motors right of the stack are the easiest to get too.   You will need to remove the glove box to gain access to those motors.
removing the glove box.... well that is a bit of a pain.   I'll have to shoot a picture tomorrow to explain.
759NRNG
759NRNG UltraDork
8/30/19 8:26 a.m.
waiting patiently.....thanks
8vo4nOrJZvy2xAf8fQBd9ZINPeNGTCBeU1JEDNNYOu4Zuv6R7ugWsJv8Qstjf1VJ
