jakeb
jakeb HalfDork
4/12/16 6:33 a.m.
This project has been in progress or a bit but I am working on getting back to build threads and sharing more what we do. A little history...
1975 2002 with early bumpers Orignally an automatic but swapping to a turbo M42 and a bunch of other fun stuff. This build is one where nothing is being held back. If metal needs to be cut to make something fit better then it is being done.
The car
Original M10
Pull everything from the interior.
Even the sound deadening.
Some rust hiding in there.
Rear subframe out
Out comes the engine
Break down the front suspension
New front struts, H&R sports and billy sports
Reinforce front subframe.
Coated front subframe
Semi boxed rear trailing arms.
UGH rust...
Bottom side in the back cleaned and then re undercoated.
A lot more has been done already but we will leave it there for today. Will continue to update.
jakeb
jakeb HalfDork
4/12/16 6:33 a.m.
So yeah there was some rust in the floors and firewall.....but just got cut it out and weld in new.
drivers side
passenger side
Fit and tack
Getting there...
The firewall was pretty rusty too....again cut and replace.
weld it in
connect the dots
grind grind grind
This is getting a turbo M42 and we are pushing it back a little further than our standard m42 installs.
It's real intake and manifold
mounts (drivers side)
Hard to get a pic of the passenger but anyway....
More to come
RossD
RossD UltimaDork
4/12/16 8:21 a.m.
I love your projects and you do excellent work!
2K4Kcsq
2K4Kcsq HalfDork
4/12/16 8:47 a.m.
I like what you did there, (all of it) carry on.
BMWGeoff
BMWGeoff New Reader
4/12/16 8:56 a.m.
So much win right here
T.J.
T.J. UltimaDork
4/12/16 9:08 a.m.
That will make an absolutely wonderful car.
Jumper K. Balls
Jumper K. Balls UberDork
4/12/16 9:26 a.m.
I'm in for this one
java230
java230 HalfDork
4/12/16 10:27 a.m.
Oh yes this will be good.
BlueInGreen44
BlueInGreen44 Dork
4/12/16 10:31 a.m.
Ooh, this looks like good fun.
oldtin
oldtin PowerDork
4/12/16 10:38 a.m.
Good progress and at least no rotted out rear subframe mounts
jakeb
jakeb HalfDork
4/12/16 1:54 p.m.
oldtin wrote: Good progress and at least no rotted out rear subframe mounts
Nope those areas are very solid.
jimbob_racing
jimbob_racing Dork
4/12/16 3:04 p.m.
Wow. I love it. You do great work.
Lof8
Lof8 HalfDork
4/12/16 3:13 p.m.
I'm in to watch this one too!
jakeb
jakeb HalfDork
4/14/16 6:30 a.m.
These little guys are to mount the intercooler at the top. I am trying to make things as hidden as possible so they weld to the underside of the core support.
Terrible picture and not pretty welds but you get the idea...
Some welded in captive nuts at the bottom.
Then bingo a pretty big intercooler in a 2002. (for those 02 guys...you can see there has been a little bit of cutting that took place here to fit things how we wanted)
This car is getting AC as well so next up we need to fit a condenser.
Sandwiched in there
Then pulled out so you can see the upper/lower brackets for the condenser captive nuts to bolt the condenser in.
We are running a disco potato on this build...so Garrett GT28RS (dual ball bearings, blah blah blah)
Time to make it fit...
Enough for now...more coming soon.
jakeb
jakeb HalfDork
4/19/16 7:09 a.m.
Building the turbo manifold
Adding the wastegate connection
All welded up for the most part
Welded the port side..
Sometime on the belt sander
jakeb
jakeb HalfDork
7/21/16 1:14 p.m.
It's hot and humid in the shop today so it's time to spend some time in the AC office and update build threads. It's hard to find time to do everything....gotta try and keep up on them and share. Pictures are a little out of order but will show them by job...
Made these little mounts for the e30 m42 lower radiator bumpers.
Welded in. Notches are to help clear the bottom of the radiator
sits pretty nice
upper radiator mount in progress
I wanted to use an OEM fan from something. This happens to be from a 2010 mini cooper and should fit the bill nicely.
made a shroud to mount it to the m42 radiator.
A little cad work
Some time at the band saw and you end up with these guys
Some welding and more cad...
and...
Will then be powder coated!!
jakeb
jakeb HalfDork
7/21/16 1:36 p.m.
Continuing on...working on the intercooler plumbing
Made this tool to be able to put a bead on the IC piping.
Short one from the turbo to the IC
I'm getting better and better an aluminum....
From IC to Throttle Body
Pulled back a bit
BOV placement
BOV flange welded on
Air filter setup...
This car will have AC so it needed a spot for a drier. Using a e30 drier as it is easy to replace if needed. Small bracket..cad first
then metal
welded in and drier fitted with lower AC line mocked up
Then making other AC lines... had to weld to the 318 compressor fitting and add a crimp connector.
on the car (mock up compressor)
low side mocked up
and welded
Line from drier to evap in car. Fill port comes up from down low.
Low side...this was later changed a bit.
hold downs for everything
All the lines mocked up
Crimped and painted
Inside the car
crimper
crimped
installed
jakeb
jakeb HalfDork
7/21/16 1:44 p.m.
We are using an updated HVAC unit in this car and it required some sheet metal work to make it all fit....
Cut a hole in the firewall (this is where the old fan would have popped out)
Fitting better
Made a mount for it
Mount with box out
tunnel was cut a bit too
Remaking the tunnel to fit
had to make a box to cover up the hole... Start with some cad...
test fit
Then made from metal
Billy_Bottle_Caps
Billy_Bottle_Caps Dork
7/21/16 4:11 p.m.
Amazing work
Dusterbd13
Dusterbd13 PowerDork
7/21/16 4:34 p.m.
What hvac unit is that?
T.J.
T.J. UltimaDork
7/21/16 5:38 p.m.
I hope to someday own another 2002. Looks like a great project so far.
ihayes
ihayes New Reader
7/21/16 11:53 p.m.
Very nice!
jakeb
jakeb HalfDork
7/22/16 6:04 a.m.
Billy_Bottle_Caps wrote: Amazing work
Hurricane by old air products http://www.oldairproducts.com/catalog/custom-street-rod-ac-units/hurricane-ac-systems-c-1_32000000_120131979.html
vRkB47RLlwacgwlGPrSegz7cbvt2flBZ0GCawnsjLvRgZ70gXcqg9wcLodal7SNC
