6 7 8 9
EricM
EricM UltraDork
11/24/24 5:01 p.m.
WE just need to stop getting distracted.....
It's the donor for the Volvo swap.  2006 GTO with a six speed manual.  It has a lot of miles, but runs and drives fine.
OK NOW we can get back to the Dragon.......
EricM
EricM UltraDork
11/30/24 6:56 p.m.
Well, I ordered parts fo the Dragon today.  A short shifter and a new linkage for the transmission.
I also ordered Bilstein B6 shocks for th car.  They are green, I guess.
EricM
EricM UltraDork
11/30/24 8:14 p.m.
OK so we had to do some stuff on the GTO, which is the drivable donor for the Volvo.
We changed the transmission fluid, and though it is a Manual transmission, it takes automatic transmission fluid.
We had a check engine light and the throttle response was super slow.  We had ordered a K&N cold (warm) air intake to replace the monstrosity that was the current intake.
It had the MAF sensor directly attached to the throttle body with the worst air filter ever n vented and never changed.
Look how bad the MAV screen is covered with filth and pieces of the air filter.
The K&N kit moved MAF back to closer where it was when there was a factory air box.
I cleaned the MAF with MAF cleaner and go t all the crap off it.   The check engine light is gone without us having to reset the computer, so that is nice.  And for some reason the ABS light is out now too, Maybe something to do with vacuum?  We noticed that the vacuum line was attached super sketchy to the hose before we moved it to the K&N pipe.  Now we only have an airbag light on.
The car's throttle response is very good now and low rpm power seems stronger.
Good times.  OK, so maybe now we can get to work on the Dragon.... LOL
EricM
EricM UltraDork
11/30/24 8:19 p.m.
The GTO is the 6.0 LS2 with a 6 speed manual transmission.  Like I mentioned, it is the drivable donor for the Volvo, AFTER we finish the Dragon.
EricM
EricM UltraDork
12/7/24 4:01 p.m.
broke down the rear calipers. Ordered complete rebuild kit as these pistons look to be shot.  One stuck in the other stuck out.
I'll clean them up and paint them.
These bushings appear to be polyurethane one thing that won't need replacing.
EricM
EricM UltraDork
12/7/24 4:29 p.m.
Mail delivered 😊
EricM
EricM UltraDork
12/8/24 12:37 p.m.
power washing
EricM
EricM UltraDork
12/8/24 4:53 p.m.
citrus cleaner and a power washer
EricM
EricM UltraDork
12/8/24 4:56 p.m.
Painting the engine bay with rustolium high heat glossy and a high heat clear coat
EricM
EricM UltraDork
12/10/24 4:08 p.m.
More deliveries
EricM
EricM UltraDork
12/14/24 11:45 a.m.
Ok last time. Honestly
EricM
EricM UltraDork
12/14/24 2:26 p.m.
We can't keep getting away with this
we needed glass and a non-coffin hood and round headlights
EricM
EricM UltraDork
12/15/24 2:06 p.m.
Actual Primary project parts, lol
Also, US Mail delivered on a Sunday?  O.K. I guess.
Rear brake caliper rebuild kit.
EricM
EricM UltraDork
12/15/24 5:51 p.m.
Three cars into one
the round headlight and flat front pieces and misc trail from the dark blue car. Ls2 and transmission from the gto
EricM
EricM UltraDork
12/16/24 3:23 p.m.
Got the pistons out, all it took was destroying a Wiha screw driver.
Punched at it from the back
EricM
EricM UltraDork
12/17/24 10:28 p.m.
Front brake conversion has started
EricM
EricM UltraDork
12/22/24 3:55 p.m.
Golly they are pretty big
EricM
EricM UltraDork
12/28/24 4:21 p.m.
found some rustolium in the basement, no one in the house is sure where or when we got it.  The color is "Lagoon".
i used it to paint the torque tube, you can't see the torque tube so color doesn't really matter here.
in between coats I cleaned the new to us brake calipers
in the casting of the caliper is the word "brembo". So we got that going for us.
EricM
EricM UltraDork
12/28/24 4:23 p.m.
The pads look pretty thick, ok to use those?  We will get new rotors.
also took all the hoses off the steering rack, I guess some get lengthens for hydro boost brakes
EricM
EricM UltraDork
1/2/25 4:40 p.m.
Rustolium owes me a kickback.
Twenty minutes per spindle with the wire wheel and two coats of paint
EricM
EricM UltraDork
1/2/25 4:42 p.m.
Also used the makeshift paint booth to paint the rear brake calipers with high heat rustolium
EricM
EricM UltraDork
1/3/25 6:21 p.m.
Today we won the wrestling match.  The fuel tank is out.  That is the last of the major components.  Fuel lines and Brake lines are all that is left on the car.
We have to slide everything out from under the car to work on it.
EricM
EricM UltraDork
3/17/25 9:22 p.m.
It gets really cold here in the midwest.
But it has gotten warm enough to be on a cement garage floor.
Tree people CAN lift an aluminum LS into the back of a pick up truck.
EricM
EricM UltraDork
3/17/25 9:24 p.m.
So, guess what weare missing?
a Flywheel
We swear we got one, we just can't find it.   We have another LS swap project waiting in the wings (LS into a Volvo 240) so we would need a second one anyway.  We just ordered one today and are having it delivered tomorrow (Over nighted from Nippan)
EricM
EricM UltraDork
3/17/25 9:29 p.m.
While we are waiting we moved over the mounting brackets for the trans axle.  The 1984 uses two wing like things, and the 1988 used the single center mount, we moved the wings over to the 1988 LSD trans axle
We also installed the Only944 short shifter kit and the spherical bearing kit as it is much easier to do when it is out of the car.
6 7 8 9
NXpfAD3rEYUCft6gFaHtM88udbb7qCRNc4bjLY1HXTO3EZLVnpfv8KboVmVZW7qE
