1 2 3 4 5
jakeb
jakeb Reader
4/3/13 8:52 p.m.
Broke apart the rear axles. They will get cleaned...painted...new grease and boots.
old grease
First clean...everything will get cleaned again before going back together
New boots outer
inner
jakeb
jakeb Reader
4/4/13 7:21 p.m.
Wheels showed up today! Tires will be 265/30/18 in the front and a 285/30/18 in the rear. To fit a tire that wide it with get e46 fender flares grafted in.
Just pics of one of the rears and specs on front and back.
Will run a 15mm spacer in the front.
xflowgolf
xflowgolf HalfDork
4/4/13 7:39 p.m.
Can't wait to see flares
jakeb
jakeb Reader
4/7/13 4:14 p.m.
New rear suspension going in. not a very good picture...
New grease in the axles
Two fresh axles ready to go in
Engine is coming back out tomorrow to make the new shifter carrier. I will probably also hang the rear trailing arms too.
jakeb
jakeb Reader
4/8/13 8:13 p.m.
Engine back out so I can make the New Shifter carrier. Also got a 2010 camaro short shifter from LSR Performance. Has an adjustable height level too (not attached in the pics)
Here is where it needs to go. Round part will come up through the hole in the body.
Something like this will attach from the trans up to the carrier.....out of metal not wood sticks :)
I have to make a bushing that will fit in the spot on the trans and use the stock rubber insulator.
Debating if the carrier back mount should hook to the trans tunnel (like stock) or mount to the trans.
cdowd
cdowd Reader
4/9/13 8:35 a.m.
What an awesome build. You have some mad skills sir.
Chris
jakeb
jakeb Reader
4/10/13 8:38 p.m.
thanks
jakeb
jakeb Reader
4/11/13 8:02 p.m.
Hung the rear trailing arms....sure is nice bolting up new parts.
jakeb
jakeb Reader
4/15/13 7:29 p.m.
Made "bushings" for the shifter carrier to hook to.
Template out of paper
I will make the same thing on 1/4" steel and weld to the carrier and bushings. There will be a matching one on the other side. I am still not sure if the rear of the carrier will mount direct to the trans or the bottom of the trans tunnel. Stock it is to the trans tunnel but everything might be more solid connected direct to the trans.
Does anyone have any suggestions going either way?
ransom
ransom UltraDork
4/15/13 7:37 p.m.
I've wondered about this, and all I've got is to ponder what each way gives you... seems like all-to-the-trans could be a little more direct... OTOH, half trans/half tunnel should halve how much the shifter moves around with motor mount deflection?
jakeb
jakeb Reader
4/15/13 8:27 p.m.
Yeah I'm really not sure why it is done both ways.... The rear mount would be able to slide in the rubber mount. Just like BMW did it and how the stock camaro setup is.
Huhmanbeing
Huhmanbeing New Reader
4/16/13 12:53 a.m.
Just read through your thread...
Not really sure what to say that hasn't been said. Just awesome. All the way around.
Any chance you have an extra room and want someone to come sweep the floors? I really need to figure out somewhere I can work/intern where I'll learn stuff like this. I'm really into the fabrication and customization side of everything, I just don't have any experience with it.
From your semi-professional (fully professional? I saw you said you were a teacher by day) opinion, what's the best way to learn, basically, how to do what you're doing?
daytonaer
daytonaer HalfDork
4/16/13 1:03 a.m.
I have a Tr6060 in my dodge and would recommend any and all steps to "firm" up the mounting. It is a great transmission. The aftermarket shift kits with a stiffer rear bushing tend to make noise, as reported on the net, I have no first hand experience.
I enjoy your documentation and following this!
jakeb
jakeb Reader
4/16/13 6:57 a.m.
Huhmanbeing wrote: Just read through your thread... Not really sure what to say that hasn't been said. Just awesome. All the way around. Any chance you have an extra room and want someone to come sweep the floors? I really need to figure out somewhere I can work/intern where I'll learn stuff like this. I'm really into the fabrication and customization side of everything, I just don't have any experience with it. From your semi-professional (fully professional? I saw you said you were a teacher by day) opinion, what's the best way to learn, basically, how to do what you're doing?
many thanks! I grew up working on cars with my dad so that is really where I got my start. From there I have learned it all from just doing it pretty much....along with reading, research, planning, etc.
By day I am a K-12 music teacher but I do have a couple years of Engineering schooling too (EE) so I have bit of an engineering brain.
The best way to learn is just dive it.
daytonaer wrote: I have a Tr6060 in my dodge and would recommend any and all steps to "firm" up the mounting. It is a great transmission. The aftermarket shift kits with a stiffer rear bushing tend to make noise, as reported on the net, I have no first hand experience. I enjoy your documentation and following this!
I already eliminated the rubber mounting at the trans. That is direct metal to metal. At this point I am unsure if the rear mount should go to the trans tunnel like stock or mount off the trans itself. I would expect shifts would be more direct with it mounted right to the trans but it also might transmit more vibration. But that really would only be noticeable when shifting. The t56 in my car has the shifter direct and there really is very little noticeable vibration.
daytonaer
daytonaer HalfDork
4/16/13 12:38 p.m.
jakeb wrote: I already eliminated the rubber mounting at the trans. That is direct metal to metal. At this point I am unsure if the rear mount should go to the trans tunnel like stock or mount off the trans itself. I would expect shifts would be more direct with it mounted right to the trans but it also might transmit more vibration. But that really would only be noticeable when shifting. The t56 in my car has the shifter direct and there really is very little noticeable vibration.
I would imagine directly mounted to the trans would be idea. I get vibration and movement in a stock dodge challenger but I have the giant soft engine mounts. I am assuming you are going to use good engine/trans mounts, so I don't think you will have much movement. Stock body mount with soft bushings like in my dodge results in allot of movement and slop.
It is the rear mount rubber that has a reputation of being noisy if firmed up.
I would also imagine mounting the rear shifter mount on the body would create an extra link for noise and vibration. Using the shifter linkage to join the trans and body seems like an unnecessary point of vibration that could be eliminated.
Either way, good job!
jakeb
jakeb Reader
4/16/13 7:12 p.m.
Turn cardboard into metal...
Rear will mount off the trans... something like this
This piece of metal will be cut where the line is after I drill a hole on each side of the big hole going up from the bottom. Then I will tap the upper half so it is easier to take the entire assembly in and out.
The entire thing will be powder coated.
Harvey
Harvey New Reader
4/18/13 3:40 p.m.
Great attention to detail on this one. This must cost whoever is getting it an arm and a leg.
jakeb
jakeb Reader
4/18/13 7:58 p.m.
It's not a low budget build but my labor costs are pretty low considering all the work. I really enjoy doing them so...
Cut down the back mount to make the entire shifter easy to remove.
Before cutting it apart i drilled holes. These will be drilled bigger and tapped to m6.
How it will fit
Removed the linkage that hooks to the shifter rod and then drilled a hole through it.
That way the rod will go through the linkage end
About where it will end up
Excess will get cut off and then the two pieces will be welded together. I might have a one piece linkage cut out on the water jet. Will see how the modded one turns out first.
jakeb
jakeb Reader
4/19/13 8:36 p.m.
Shifter all done (needs to be cleaned up a little bit and then coated) - Only tacked in the pics
https://www.youtube.com/watch?v=E4ic_SmDbpg
Inside the car
old shifter knob.... This shows 3rd gear. The shifter is height adjustable. It is at it's lowest point right now.
Trans mount (needs to be fully welded and a gusset or two added)
Flaming river Ujoints / Borgeson DD sliding steering shaft...next to the stock one
Starting work on the headers. New little tool to make sure the cut is across the radius.
I posted a pic of a converted wood saw to cut metal but I wasn't happy with it so it got returned after I found this big ole machine on craigslist. Made in 1937...made to cut only metal. Makes cutting stainless U bends easier. Not to mention old machines like this are cool.
Passenger side header started
Pan to subframe clearance..
jakeb
jakeb Reader
4/23/13 7:16 p.m.
A little bit of work on the passenger side header.
jakeb
jakeb Reader
4/25/13 7:47 p.m.
a little more on the passenger side header
Collector will be about like this..
Lof8
Lof8 New Reader
4/26/13 12:22 p.m.
In reply to jakeb:
So many awesome details. An LSX e36 has got to be an awesome track toy!
jakeb
jakeb Reader
4/27/13 10:48 p.m.
This will mostly be a DD for the owner but it will see some time on the track as well.
Drivers side header is a bit more work...but making progress none the less. It is a puzzle....that I sure enjoy solving.
jakeb
jakeb Reader
4/29/13 10:05 p.m.
I was actually able to install the header from the top. Not sure how that will be once all the runners are on but...we will see.
Started on one runner...
It's hard to get a picture of how it routes...
Where the collector will go..
From farther away
Another angle
Collector could still go a couple different ways....
Harvey
Harvey New Reader
5/1/13 10:37 a.m.
I was impressed with the cleanup and now the custom fab work is pretty nice too.
If you don't mind my asking, what will the total bill for something like this come out to?
1 2 3 4 5
LCfQOPR3ePLt8YCfHdgElvBe7YuEwmKrXXB8onopOjpJ4X7kyTyX0wDjd7vFkNsv
