5 6 7 8 9
MichaelYount
MichaelYount Reader
7/12/13 4:55 p.m.
OM.....OM......OM........OM...... Pretty work.
Mr_Clutch42
Mr_Clutch42 New Reader
7/15/13 12:21 a.m.
Really good work. You're putting me to shame when I'm struggling a little bit on my stuck exhaust manifold nuts
jakeb
jakeb Reader
7/15/13 7:18 p.m.
Mr_Clutch42 wrote: Really good work. You're putting me to shame when I'm struggling a little bit on my stuck exhaust manifold nuts
Stuck exhaust manifold nuts suck! Most of the work I do is all brand new so...
And another update...
Center section all welded
Entire system put together and hangers added
Tips
Entire thing off the car...few joints to weld up
Remote clutch bleeder
Fuel pressure filter/regulator (still needs hose clamps)
Top ring on the shifter carrier is to hold the shifter lever in place.
jakeb
jakeb Reader
7/16/13 3:54 p.m.
It's a big time heat wave here but I have a couple of AC units in the shop and it keeps it workable but temps still climb.
The list is getting shorter. Engine will be back in for the last time tomorrow...suspension will get finished up. Shooting to start it Tomorrow or Thursday (more likely)
Header on for the last time, subframe on loosely.
Clutch line off tr6060
Clutch connection from BMW hardline
Front right flare needs one more sanding and then some finishing filler before primer
Right rear flare really close as well.
jakeb
jakeb Reader
7/17/13 3:30 p.m.
ABS Pump in place... etending the wires in progress
Done
Last time it will have an empty bay
Engine In
Front suspension all on
Brakes going on
Had to put a wheel/tire on just to see how they fill them
This is will full negative camber...won't run like this but wanted to see what it looked like.
Finish filler on the left front flare
Right rear flare just about ready too.
yamaha
yamaha UberDork
7/17/13 3:49 p.m.
You're making us all look bad......
jakeb
jakeb Reader
7/18/13 7:46 p.m.
Was hoping to fire it today but with the temps at 95 and 85 in the shop it's hard to work very fast...either way still progress.
All the brakes/lines/etc are all hooked up. And more flare work.
Shifter in
Shifter linkage
Under car pictures...just because everyone likes pictures.
How the AC compressor came out...you can also see the trans cooler lines in there and the battery cable.
ransom
ransom UltraDork
7/18/13 7:52 p.m.
Bonus karma motivation points for jakeb; I was sitting here getting Internetted, but now I'm jumping up to go work on the garage!
jakeb
jakeb Reader
7/22/13 7:45 p.m.
Not fired yet...waiting on intake pipe. The one I had was a bit too big to fit. It's ordered and in route...very very very soon!
Exhaust all bolted up, heat shield on, driveshaft in, etc
Suspension is all tightened up... Set it down on the ground.
Front nose isn't tightened.
Will be wiring the LSx harness into the BMW x20 tomorrow and will power everything up to program the PCM.
G8MikeGXP
G8MikeGXP New Reader
7/22/13 9:58 p.m.
I love this car! Awesome build.
jakeb
jakeb Reader
7/23/13 7:45 p.m.
I used a PSI harness on this one. Connecting everything to the BMW x20.
From above
Reading the PCM
Trans cooler just showed up. It will go about here.
MichaelYount
MichaelYount Reader
7/24/13 6:01 a.m.
Any way to mount the tranny cooler low and have the heat rejected go under the car instead of back into the coolant? Tranny cooler, not an oil cooler? Manual transmission, right? Hmmm....
jakeb
jakeb Reader
7/24/13 8:35 p.m.
Yeah I might be able to mount it low rather than up high. The cooling fan and bumper take up a bit of space down there too so it's hard to say. I'll take a look for sure.
Yup it is a trans cooler. The TR6060 has a fluid pump of some sort and it has cooler. Kinda wild...
jakeb
jakeb Reader
7/25/13 8:08 p.m.
Running wires to the gas pedal. Through the pocket where the PCM will live above the glove box.
While I had the glove box all apart I replaced the cabin filter....man they get dirty.
New one in and vacuumed the box all out. Much Better
Made a bracket for the gas pedal
Angle iron piece is welded to the firewall and tapped to bolt the flat piece that the pedal is bolted to.
Pedal is about the same spot as the stock one. Feels really good.
Trans cooler..still need to finish the bracket...just weld with vise grips here.
The plan was to have it running today but the intake pipe showed up at the end of the day and didn't have time to finish it.
It has to be extended a little bit at the throttle body.
The LS3 uses a cassette style MAF and a little flange has to be welded to an aluminum intake pipe.
The flange
I am not comfortable welding aluminum yet (to the quality I like) so I will have to take it to a local welding shop to weld up.
jpnovak
jpnovak New Reader
7/26/13 10:51 a.m.
This is such a great build. Thanks for the thorough documentation.
MichaelYount
MichaelYount Reader
7/26/13 8:05 p.m.
Jakeb - the new gas pedal looks to be quite a bit further to the right than the stocker -- will that mess up heel/toe relationship? It's not really 'heel/toe' so much as hitting the right side of the brake pedal with the left side of your foot and having the gas pedal be at the right height/distance away so that under heavy braking a simple roll of the foot causes a throttle blip. In all my time in 3-series (3 of them over 20 years) that was one of the most satisfying aspects of the car.
reiernumans
reiernumans None
7/27/13 4:41 a.m.
Wow, your work is incredible! I read through the entire thread yesterday and wow. Just wow..!
jakeb
jakeb Reader
7/27/13 12:20 p.m.
Michael...that is possible. The pedal is only tacked in in one spot right now and I will wait to drive the car a little before I commit to it. That picture makes it looks a little weird because with the stock pedal there it is almost in the same spot. When looking direct at it and not off to the side like the picture is. Also if it is any more to the left the bottom of the pedal gets in the way when applying the brake. I might trim the gas pedal a little bit at the bottom to stop that.
jakeb
jakeb Reader
7/27/13 12:20 p.m.
Intake pipe all welded up
Went to start it yesterday but didn't have much luck. Fuel pump was running, good fuel pressure but the plugs were bone dry. A little digging and asking some people and I found out I needed to disable a starter diag in the tune. Changed that did a write entire on the tune....and bamn!!
Start up videos!
http://www.youtube.com/watch?v=Ijf8zhL7dMo http://www.youtube.com/watch?v=Yg9htTLEnsI
There is a slight exhaust leak at one of the vbands off the header. Just needs to be tightened up a bit more.
MichaelYount
MichaelYount Reader
7/27/13 8:20 p.m.
nice!
jakeb
jakeb Reader
7/30/13 8:16 p.m.
Wrapping up little things before it's first drive.
Made a front and rear strut brace and had it coated.
Had the intake pipe coated
Bleeding the brakes and clutch today took hours......just lots of air to get out. But all is working now as it should.
My little guy was out in the garage and wanted to check out the beast. He had some wrenches in his hand but it was hard to get a pic as he moves quickly.
jakeb
jakeb Reader
7/31/13 7:39 p.m.
The plan was to drive it today but it has been raining ALL day here. The flares don't have paint on them so I really don't want to get water all over the flares before paint. Hoping it stops tomorrow so I can drive it. Even just around the block.
Still worked on some things...the little jobs take time as well. Installed a volvo pusher fan in the BMW shroud. Pushes a TON of air.
Mounted the trans cooler for good. Bracket back from power coating.
Clearance between the bracket and fan.
I had the BMW coolant temp sensor turned down from the stock M14 size to M12 to fit in the LSx head.
Where it lives....there is a BMW 2 pin connector that goes on the sensor. Just not connected in the pic.
I wasn't very happy with how the caster was ending up with the bimmerworld fcabs...they are set inside and it was pushing the wheel too far forward. While it was clearing everything it just wasn't right. So I switched from the offset bimmerworld fcabs to a centered bushing from condor speed.
Fitment before...
After...much better
Been also doing finish work on the flares. I'll snap some pictures tomorrow of them.
Harvey
Harvey New Reader
8/1/13 10:27 a.m.
jakeb wrote: Wrapping up little things before it's first drive. Made a front and rear strut brace and had it coated. Had the intake pipe coated Bleeding the brakes and clutch today took hours......just lots of air to get out. But all is working now as it should. My little guy was out in the garage and wanted to check out the beast. He had some wrenches in his hand but it was hard to get a pic as he moves quickly.
Hee hee. I have a two year old. She has not seen daddy wrenching quite yet.
jakeb
jakeb Reader
8/1/13 9:13 p.m.
My son is 17 months old. I was putting a new trailing wiring connector on my truck today and my son was out with my wife wanting to help me. "dad dad" he says... picking up wire and other tools.
I tell everyone welding by 5...maybe it will be sooner.
Slippery
Slippery Reader
8/1/13 9:21 p.m.
The car is coming out great. The wheels and flares work really well together.
5 6 7 8 9
4xg0JDXz8Tr3PALKkLGvI87EAwcgVihbwnOwWf43iEsdyi6BSmsvlY5y9TIkdCmK
