5 6 7 8 9
ElectricSuperCar
ElectricSuperCar Reader
11/8/20 9:32 a.m.
Driver side fender
https://youtu.be/1qMqfGMIjTs
ElectricSuperCar
11/15/20 9:41 a.m.
Starting on some headlights
https://youtu.be/lXaiCBBLLjM
ElectricSuperCar
11/22/20 9:45 a.m.
Starting work on th efront lip and taillights
https://youtu.be/55BS2qDHOiY
11/22/20 12:22 p.m.
Fenders and lights are looking good, the cutouts in the fenders could look good if they follow the contours of the taillight opening, but they might get very close to your tires.
Not digging the front grille surround/lip though, I think the car looks better without it. I'd be tempted to try a simple sheet plastic cover over the depressed area under the radiator opening and attaching the mesh inside the opening somewhere. I think the mesh will pop out at higher speeds if you try to stick it in with sealant, you definitely want some proper mechanical retention using small bolts or hidden zip ties - auto manufacturers tend to use plastic clips for holding mesh in.
ElectricSuperCar
11/23/20 10:25 a.m.
Thanks for the comment.  There were many that shared your concerns and suggested mechanical connection.  I will see what I can come up with.
ElectricSuperCar
11/29/20 9:28 a.m.
Modifying the rear fender and making my first fiberglass mold
https://youtu.be/OTO0QG6DAqA
ElectricSuperCar
12/6/20 9:41 a.m.
Matching fiberglass molds and doing some electrical testing.
https://youtu.be/vROlbjjjGq0
12/6/20 10:44 a.m.
Great work on the taillight shape, looks like they could've been that way from the factory!
ElectricSuperCar
12/7/20 11:30 p.m.
Thanks Friend!
ElectricSuperCar
12/13/20 11:11 a.m.
First part from fiberglass mold
https://youtu.be/_paJKVsR-_I
ElectricSuperCar
12/20/20 11:10 a.m.
Stripping down to solve those pesky electrical problem
https://youtu.be/KUeK_37Cck8
ElectricSuperCar
12/27/20 11:16 a.m.
I joined my first fiberglass piece
https://youtu.be/n7kv04dl-o8
ElectricSuperCar
1/3/21 11:05 a.m.
Homemade DIY Widebody Fender is Mounted
https://youtu.be/b5V7C77fb_4
ElectricSuperCar
1/10/21 9:27 a.m.
Homemade DIY Widebody Complete!
https://youtu.be/_xd8YgW1nM0
ElectricSuperCar
1/17/21 11:10 a.m.
Controller is Back!
https://youtu.be/PLBC89qmtrw
ElectricSuperCar
1/24/21 9:48 a.m.
Installing 5 point racing harness
https://youtu.be/lwsDryFS6wI
ElectricSuperCar
1/31/21 10:39 a.m.
Charging Circuit is Working!
https://youtu.be/J4LSbphxMeI
ElectricSuperCar
2/7/21 10:25 a.m.
On the Road Again!
https://youtu.be/edmmytvjusA
ElectricSuperCar
2/14/21 9:38 a.m.
Electric Supercar Build Review – Everything to catch you up, build in 15 Minutes
https://youtu.be/Dh7HCNi86cs
ElectricSuperCar
2/21/21 9:27 a.m.
Time for some panel fitting
https://youtu.be/IExhT8lmQ1o
ElectricSuperCar
2/28/21 12:44 p.m.
Meeting with JerryRigEverything
https://youtu.be/asQ3Erxl6gE
ElectricSuperCar
3/7/21 10:03 a.m.
Working on windshield wipers
https://youtu.be/p9Fm8BPYt3E
ElectricSuperCar
3/14/21 10:52 a.m.
Working on the rear diffuser. Also starting the cost challenge.
https://youtu.be/fDRwKZMtO2c
ElectricSuperCar
3/21/21 9:56 a.m.
Cost of my build is paper bag embarrassing.
https://youtu.be/YMcKzEb2Va8
ElectricSuperCar
3/28/21 11:14 a.m.
Not Moving and Moving
https://youtu.be/aHSKyMTPhbo
5 6 7 8 9
KmMjMqQPmptlbAduf3OdNYNMqh98zKFkEjnVm9p2hJogU8cEvKJmDA0KpqNoiaYS
