6 7 8 9 10
AxeHealey
AxeHealey SuperDork
3/16/25 8:35 p.m.
Not much more to report from this weekend. I cleaned up the surface rust around the upper hinge bolt holes, laid down some converter, primer and color.
There are wheel well liners made from plastic barrels and one of the two supports  on the front passenger side was completely rusted through. While the various layers were drying I made up a new one.
AxeHealey
AxeHealey SuperDork
3/17/25 1:16 p.m.
Door mounted. It needs some fine tuning at the moment but I expect it to change once the new weather stripping is in place so I'm not going to mess with it until then.
AxeHealey
AxeHealey SuperDork
3/21/25 4:45 p.m.
I have been very busy in real life but had a couple minutes today to wrench. The front liner mount was so nasty I just couldn't put it back in that bad.
It's still really bad but it'll do for a temporary (permanent) fix.
Darkrider
Darkrider New Reader
3/22/25 1:25 p.m.
So glad I went back in and started reading this thread again. On the one hand, it has me wishing I had not sold my '69 F250 last winter but on the other hand, it does help me feel better about tackling the various issues I will need to face on my '84 C10.
AxeHealey
AxeHealey SuperDork
3/26/25 5:50 p.m.
In reply to Darkrider :
Get after it! The hardest part is starting. As I've shown it's clearly not always cake walk after that but momentum is your friend.
Back in town with a busy day of work but everyone needs a break, right? The passenger door now has all new channel seals and anti-rattle strips. Fancy and also shmancy.
AxeHealey
AxeHealey SuperDork
3/29/25 4:10 p.m.
I've been keeping half an eye out for a ZF5 at a good price local to me and one popped up Thursday. After confirming the data tag, I gave the guy my low offer and after some thinking he took it!
Other than the fact that it was literally sitting in mud, it's in extremely good shape and has very little evidence of leaking. He showed me pictures of the 133k mile truck it came out of. It was very clean and the condition of the rubber mount attached to it indicates it was well maintained. The shifting feel is really nice with no slop. Inside the bell housing is a bit chewed up and there's this stuff.
It smells like clutch and looks like it could be what's left of clutch material so I'm thinking this truck was sold to scrapper because the clutch exploded.
I spent more time trying to bleed the power steering. It's better but still not there. I may need a new method.
AxeHealey
AxeHealey SuperDork
4/9/25 3:00 p.m.
I've been spending time with Elmore here and there when I have bits of availability. Now the driver's door has all new window channels and anti-rattle strips. I've been putting off taking the seat out to repaint the floor until my wife (or someone else) is available to help me but today I realized I could easily handle it myself if I separate the back from the bottom.
Many years of dirt, etc.
My wife has been on me for years now to get the middle seat belt working - the receiver is broken. So I think now is the perfect time to get them replaced. Turns out these belts are from a 79. Likely the same truck the rest of all the other parts came from.
I also ordered the horn contact I have been missing since putting this steering wheel on and installed that so now I can beep at all the people who cut me off when I'm driving my old truck. It was the same deal in my C10 back in the day. I legitimately think that people see an old truck and blindly assume it is moving very slowly.
I'm being very patient with the power steering but as of the last start up and test, it's still not fully bled. Elmore has been living in the garage with his front end way up off the ground and most every time I walk by I slowly turn the wheels from lock to lock a few times. Eventually I'll get there...I think.
budget_bandit
budget_bandit HalfDork
4/9/25 3:02 p.m.
In reply to AxeHealey :
what is your method? I've always had luck by starting with the engine off, jacking the front end up and going lock to lock a bunch of times until i don't see many bubbles being generated in the reservior. Then i start the engine off and go lock to lock a few times and make sure it isn't making any more bubbles and call that done
Recon1342
Recon1342 UltraDork
4/9/25 3:59 p.m.
ZF-5 FTW!!!
Awesome score!
AxeHealey
AxeHealey SuperDork
4/9/25 6:50 p.m.
In reply to budget_bandit :
That's what I've been doing. I think I put myself in a whole though because initially I just filled the reservoir way up and started the truck working to bleed it that way filling it up every couple cycles. I'd never started with a totally dry system before and clearly I should have begun with the engine off.
Darkrider
4/9/25 7:05 p.m.
ZF-5 FTW!!!
Awesome score!
Agreed, I was seriously contemplating this route had i kept my '69 F250.
AxeHealey
AxeHealey SuperDork
4/12/25 7:35 a.m.
There's been a good bit of wire brushing, vacuuming and more wire brushing as of late. Luckily I have only found a little bit of scary stuff but there's no time for that snowball right now with racing right around the corner.
I cleaned up the worst if it, hit it with rust converter and laid in some seam sealer.
I think I've heard a phrase that goes something like... If you know the right way to do it, you can do it the wrong way.
Hopefully I have time to at least get the whole floor primed and ready for the bed liner by the end of the weekend.
AxeHealey
AxeHealey SuperDork
4/13/25 8:10 p.m.
Goal achieved.
And, yes, that's two different primers.
Then I set out to repaint the trans tunnel cover black but had an idea... My wife told me to go for it.
Other than the fact that the blue shows how many damn holes have been drilled in the thing over the years, I think it'll be a cool little accent. We shall see. I've got yet another very busy week ahead of me but there is a small chance I will have time to roll the bed liner on tomorrow. We'll see.
4/14/25 11:53 a.m.
Fancy and also shmancy.  that's Sir Elmore to you ruffians!
AxeHealey
AxeHealey SuperDork
4/14/25 1:12 p.m.
Mmm. Indubitably, yes.
Well, I'm waiting to pass judgment until there are a few more coats on but so far I'm a bit unimpressed with this bed liner. Hopefully each coat builds on the last nicely and it becomes what I was imagining.
AxeHealey
AxeHealey SuperDork
4/14/25 8:58 p.m.
Ok. Three coats in and I'm starting to feel much better about this.
More imperfections show through than I expected but it's alright. It may be done after one more coat but I'm expecting two more. I'd like that last coat to be in the daylight, too.
Crackers (Forum Supporter)
Crackers (Forum Supporter) SuperDork
4/14/25 9:51 p.m.
Nice job on the patch work.
I had similar feelings about bedliner and coverage/hiding when I did my flatbed with Rust-Oleum bedliner. What actual product are you using? Seems like Rhino Liner or other similar stuff that's applied with a Shutz gun are the only type that's any good at hiding sub-optimal surface finish.
AxeHealey
AxeHealey SuperDork
4/15/25 9:40 a.m.
Thanks.
Rust-Oleum is what I'm using also. It seemed to be one of the only readily available bed liners with a tan tint. Hiding the surface finish is exactly what I was most disappointed with after the first coat. It's definitely getting better with each coat but I would have spent much more time finishing the patches if I knew it wouldn't cover up as much.
AxeHealey
AxeHealey SuperDork
4/17/25 5:50 a.m.
How about another, almost identical picture? 5 coats on anything that will be seen and I'm calling it. For those curious this was the entirety of one quart.
Recon1342
Recon1342 UltraDork
4/17/25 8:02 a.m.
Looks better than my truck's floors, Axe...
Nicely done.
budget_bandit
4/17/25 9:12 a.m.
That looks plenty good enough for the girls I go out with...
AxeHealey
AxeHealey SuperDork
4/22/25 8:16 p.m.
I'm so frustrated that I'm actually calm. The past two days I've been struggling to get the door seals to stick. I've been using the 3M stuff and painters tape. The goo doesn't hold and the painters tape doesn't stick to the bed liner.
This morning I decided I had to try Gorilla tape. I slathered an entire tube of the goo on, taped it in place and shut the door. Well, it's still not really stuck and...
Yep. The tape pulled up a few spots of the bed liner and the fresh blue paint below. That's royally annoying but it's not why I'm so angry.
Here's why.
That's one of the brand new screws for the brand new trim plate that broke off. I had to drill a new hole here and, by hand, snapped the screw off in there. I'm guessing I'll be able to pull the trim plate off and unscrew it with vice grips but come on! What the hell.
4/22/25 8:36 p.m.
I bet I know where that screw was made
4/22/25 11:46 p.m.
Yeah, I'd have probably thrown something. Was the hole in a weld bead, or maybe undersized? I've done both with similar results. Are they stainless screws? For me it's always the stainless screws.
I chose not to share my experience with that bedliner peeling. 😬 For me it's not a big deal, the initial application was always temporary I just didn't want the eyesore of the rusting steel anymore. But next time I'll be paying closer attention to surface prep and see how that goes.
akylekoz
akylekoz UberDork
4/23/25 6:59 a.m.
To bleed the power steering on the ole 5.0 I turned it to full lock, let is set over night to let the bubbles pop then full lock the other way rest and repeat.
6 7 8 9 10
v6KlOY3bLLH1LcVkSn0Vs8R8PfI6Y918l8VMH9exnm7aU1Mapbg5wXq8LzskqKjc
