keithedwards
keithedwards Reader
12/15/19 3:52 p.m.
My experience with eggshell campers is limited, but I attended the Tearstock gathering in 2017 on the Outerbanks, NC, which was co-hosted with the Eggshell group. They seem to be a fun, welcoming bunch.
I have a Little Guy Rascal teardrop trailer, that I tow with a MINI or 2. Mine was not the only British tow vehicle that weekend. https://tearstock.com/wp-content/uploads/2017/11/IMG_4821.jpg
Here's a link for the 2017 Tearstock/Eggshellls on the OBX meet https://tearstock.com/galleries/tearstock-2017/
Here's a link to the Eggshells OBX meets.https://jeanninepatane.com/rv-compass/rallies/obx/
Tim Baxter
Tim Baxter UltimaDork
12/16/19 7:35 a.m.
Interestingly there was a rarer, larger, less cute 17' version that could be had with a shower and toilet.
I think that's probably the a 17' Boler you're thinking of. As far as I can tell Eco only had the 13s and only made them for a few years. You can get a modern 16' Scamp or a 16' or 17' Casita with the same construction and a wet bath.
What are you plans to keep the cabinets and drawers closed while towing? There are simple catches that do the job and release easily.
Still pondering that. On the small cabinets, the spring-loaded "self-closing" hinges I used have enough tension to keep them closed. On the big cabinet, though, it will swing open when towing. I'm currently thinking a simple baby latch would do it, but I'm also considering some of the little push-botton RV cabinet latches, like these https://www.amazon.com/dp/B07MZQ8QY8/ref=twister_B07MZQ3LX6
But nowadays both of us prefer something more self-contained. Like a bathroom with shower.
You should definitely look at the bigger Casitas and Scamps. They have a bathroom/shower and are still about 2200, fully loaded.
Could the 4" holes have been for a heater? We have a Propex that I put in the Vanagon that uses inlet and outlets about that size.
Maybe, but after 50 years, who knows. It has a propane heater under the sink, but there's no telling what people were thinking. I was just happy to be able to re-use so much of someone else's effort and make it all work.
I am assuming that the sink is glued on, and those little screws with washers are just for alignment?
The sink actually sits sandwiched between the old carved-up fiberglass countertop and my new wood countertop. On page one you can see a pic with the original sink hole (and a hole for the now-removed stove). The new sink sits on top of the fiberglass but below the wood, and yeah, the screws are really just for alignment and extra stability. There were just too many holes cut into the original countertop to reuse it without a ton of work, and it was easier to just make a new wood top.
Tim Baxter
12/16/19 7:40 a.m.
So how common is it to find a fiberglass shell trailer like that with really bad fiberglass?  Other than cosmetics, they seem like they are pretty darned robust.
The shells, from what I've seen, are the last thing to go. They have two main failure points, and the shell isn't one.
1. The frames were flimsy trash even when they were new.  Honestly, if I'd had the resources and location to do it I'd pull the shell and have the frame rebuilt and reinforced. I still may, I'd just have to farm it out. They were just seriously under-specced, either in an effort to keep weight down, costs down, or both. Or maybe they were just dumb. Anyways, if they're not rusty, they're probably cracked. If they're not cracked, they're probably bent. Mine supposedly checks out, but I still have doubts.
2. The floors are wood, or a wood/glass layup, and either way if water gets back there, it's bad. Anyone with a saw can replace them, but it's a lot of work.
Tim Baxter
1/7/20 4:18 p.m.
Upholstery is back. This is the couch side:
And this is the dinette side:
That leaves connecting the plumbing as the last halfway significant project. The plumbing's in place, I just need to connect it. But I don't want to put water into it until spring. Other than that, it's down to fine tuning and fixing little things that aren't quite right.
I do have some plans to take a raspberry Pi and do some interesting things with it, though.
1/8/20 8:52 a.m.
Rad. Thanks for sharing--and welcome back. smiley
Adrian_Thompson
Adrian_Thompson MegaDork
1/8/20 9:56 a.m.
Awesome, missed this before Christmas when it started.
I love these little things and often spend time cruising for cheap ones for restoration.  If I could find a project for less than $1k It's one of the few things I would consider begging forgiveness rather than asking permission from SWMBO.
alfadriver
alfadriver MegaDork
1/8/20 10:00 a.m.
In reply to Adrian_Thompson :
Me too- if you find a pair, you know how to reach me.
Tim Baxter
1/9/20 7:50 a.m.
1k would be tough, even for a basket case. I managed to get mine for Challenge money, though, so maybe?
Stefan
Stefan MegaDork
1/9/20 12:19 p.m.
I was expecting:
but this is still quite cool and welcome back!
1/9/20 1:09 p.m.
That's a very cool camper!  I go past a Scamp once a week that hasn't moved in a while, maybe I'll stop in.
I have no interest, but will pass info along.
2boC4yCZzOn28P6RJ5u7hdeaSembiUVGsO0wEKuUvgdQ2UMwpCxoJHZrZMzZU9ih
