Stampie
Stampie MegaDork
9/13/21 9:22 p.m.
maj75 (Forum Supporter) said:
It's not redneck when you use the ratchet portion.  It's redneck when you put the car in gear and use the car's power to do the work.  When doing it this way, I advise a log chain, not a strap.  Don't ask...
I've done it with the project car strapped to a trailer and using the tow vehicle to pull.  Is that redneck?
9/14/21 11:21 a.m.
In reply to Stampie :
That puts you pretty solidly into overalls-over-bare-skin territory.
9/14/21 11:21 a.m.
And let's be honest, that's really the Stampie we want.
Stampie
Stampie MegaDork
9/14/21 12:13 p.m.
Sometimes I'm amazed at how attractive you find me.
Robbie (Forum Supporter)
9/14/21 12:15 p.m.
He sees your inner beauty. As in, whats under the overalls.
9/14/21 12:29 p.m.
you shouldn't be
russian
russian Reader
12/24/21 7:51 p.m.
MrRobogoat (Forum Supporter) said:
RusEFI has an ECU board project that is designed to fit into that case if you wanted to go standalone. IIRC, the 02 sensors are a wideband Bosch unit, so you may be able to DIY a controller to get readings saving $100 or so.
That Hellen121VAG board has on-board wideband controller but at the moment on only supports 4.9 sensors not 4.2 like used by 02 VAG :(
12/25/21 12:42 p.m.
What ever happened to this car?
a1MpYz9AhlKLOp00F0uTerxQXqqG3BfgpRs2lqvtdHuO13XZ0IlOcy4Udg5QwZOd
