Dusterbd13-michael
Dusterbd13-michael MegaDork
12/12/22 2:13 p.m.
I have had serious hits fixed a few times. No matter how good the shop, there were always spots that showed the extent of the damage. I can't unsee them, and then its all i see.
If they pull it straight  can you live with the tells?
Go_Gators (Forum Supporter)
Go_Gators (Forum Supporter) HalfDork
12/14/22 6:58 a.m.
thats a fair point too!
12/14/22 7:06 a.m.
and then, just like that, there was but one option...
met up with the shop owner today, he had finally had a chance to get the kart up in the air and assess it over the weekend. besides needing the driveline pulled to get at the inner frame he was finding more and more contortion. He put odds of it straightening at less than 50:50.
That was all i really needed to hear to change course.
So. heritage kart will be parked inside and stripping of soon to be kart will commence with a bit more urgency than it has the past week...
Our club's first event date hasnt been set yet, but its probably going to be early Feb. Calling that a soft target date, that truly, i dont expect to make. which is fine. No shortage of co-drive offers!
gumby
gumby Dork
12/14/22 7:16 a.m.
After talks with the shop owner, are you planning to clip your chassis or start fresh and port everything over to the new chassis?
Patrick
Patrick MegaDork
12/14/22 7:38 a.m.
Have you verified you didn't snap any chunks off the block or bend/break the torque tube or transmission?
12/14/22 7:40 a.m.
Going to use the entire 'new' chassis.  the form and construction of these jsut doesnt lend itself to clipping. Plus, the majority of things i would change if/when i did this again pertain to the rear of the kart...
golfduke
golfduke Dork
12/14/22 8:48 a.m.
sucks to hear but at least its a clear path forward.  New build thread, or just gonna piggyback it onto here?!
12/14/22 11:06 a.m.
yea, it is a reduction in stress at least knowing which way i am going know...  gonna keep it here! reckon its chapter 2.
759NRNG
759NRNG PowerDork
12/14/22 8:43 p.m.
Yes it's that time of the year, but would you entertain a thrash event to start the new year right?
12/14/22 8:54 p.m.
Lets all remember, it absorbed a lot of energy hitting that wall. All of that bent metal meant less of that energy transmitted to the driver. That's a good trade.
12/15/22 9:47 a.m.
there will be probably be a series of mini-thrash efforts.. i kinda fail to the meticulous side, so all out thrashes arent actually in my comfort zone... lol...
12/15/22 9:48 a.m.
this is true. surely that impact would have totaled any vehicle..
TurnerX19
TurnerX19 UberDork
12/15/22 10:00 a.m.
A double thread bump up to Patrick's post. Use your meticulous side to examine all of the driveline super carefully. It is so long and attached across a large part of what is known distorted.
12/15/22 10:55 a.m.
for sure. and, unsurprisingly, there is long neglected maintenance that need to be done while its out... trans and diff seals primarily..
12/16/22 10:12 a.m.
So... here is the progress on the carcass so far...
Since its not crystal clear... this is the view from where the engine should be, looking aft.
and here is the view from the B-pillar looking forward
As you can probably imagine, the bulk trash guys are not going to be happy with me the next several weeks.
12/16/22 10:19 a.m.
The part of this evolution that is stressing me the most is the A-pillar.
Ole GM Engineers didnt do me any favors.
The windshield surround and pillar are aluminum. The surround structure is bolted and super-glued to the steel a-pillar base. Then the sheetmetall forward floor pan is attached to the steel a-pillar and the fiberglass firewall and pedal box... which is absurdly well attached to both the lower steel components and the upper aluminum structure.
i dont think i will be able to get the aluminum structure to non-destructively detach from the steel a-pillar base... 5lb sledge aint makin it budge (and obviously its already been subjected to heat).
Current plan is to cut the steel a-pillar at the same height on each vehicle and weld it back. Plan of attack on the fiberglass firewall has be detaching it somehow from the steel lower section. thats going to get messy.
AxeHealey
AxeHealey Dork
12/16/22 1:33 p.m.
Go_Gators (Forum Supporter) said:
Glad to see it's living on but ...woof... Good luck!
TurnerX19
TurnerX19 UberDork
12/16/22 2:42 p.m.
In reply to Go_Gators (Forum Supporter) :
All of the structural adhesives should fail with heat at a temperature a little less than aluminum annealing, I.E. 500F . Cook and chisel with a shallow taper.
bumpsteer
bumpsteer New Reader
12/16/22 3:02 p.m.
So when are you planning on breaking out a big tarp and hammer store sandblaster?
12/19/22 7:20 a.m.
It smells so much better, now.
12/19/22 7:22 a.m.
So... indeed, i worked various thing into the crevice between the steel and aluminum and it did end up separating! how hard it will be on the more intact one... tbd.
12/19/22 7:25 a.m.
thinkin it will be moved into the garage this week. finished the dirtiest work this weekend. A & B pillars got removed and i burnt/scraped all the adhesive that held the body on the frame.
golfduke
golfduke Dork
12/19/22 9:39 a.m.
Fast progress!!!  Looking great!
12/19/22 5:38 p.m.
golfduke said:
) Fast progress!!!  Looking great!
Indeed, this part has gone quicker than expect!
Have decided its time to ditch the ABS on iteration. On early C5s, (heritage was a 98)(burn victim a 04) ABS pump was located behind the diff. that location made exhaust and radiatior placement difficult. furthermore, i would like to stick the battery there. selling the actually functional ABS pump/controller looks like it will mitigate the expenses i am about to describe...
have had great comms with finishing-line sales and i am going to go full flexible line, sans-ABS, with a rear prop valve (accessible in car) and....... hyd hand brake...
759NRNG
759NRNG PowerDork
12/19/22 6:31 p.m.
The A's & B's were removed because you did this the last time or is this a new approach to Kart 2.0?
WvFhpLko6EqzNZWUWB2xCayrLE4HOmPAUaPHwjZlCxNveZgjys0WhSnZFsnDZnb1
