Dusterbd13
Dusterbd13 MegaDork
10/20/18 7:41 a.m.
Im hoping to bring a well sorted, proven car next year. I WAS hoping for this year, but this may be the most ambitious project that i have ever undertaken. And this year has NOT gone according to plan.....
ShawneeCreek
ShawneeCreek Reader
10/20/18 8:23 a.m.
I look forward to seeing it next year. You've done a great job with this car.
Bent-Valve
Bent-Valve Reader
10/20/18 10:37 p.m.
Dusterbd13 said:
I've made the executive decision that first fire will be open headers.
Just because.
Theres no rod knock or noisy lifters that can't be ignored while whacking the throttle with openheaders.
And I bet, no matter how hard you try, you won't be able to keep a silly grin off your face. wink
Dusterbd13
Dusterbd13 MegaDork
10/21/18 10:24 a.m.
Te real bitch of a well done custom wiring job is that it looks no different than factory, or is so well done and tidy that no one ever notices it.
See what i mean?
Patrick
Patrick MegaDork
10/21/18 10:27 a.m.
That’s just firming up my plan for a white engine compartment
Dusterbd13
Dusterbd13 MegaDork
10/21/18 10:46 a.m.
The white has proven difficult to keep clean so far. I may reccomend something NOT pure white.
Dusterbd13
Dusterbd13 MegaDork
10/21/18 3:03 p.m.
We have spark!
Plug wires, vacuum caps, upper intake and throttle body, intake piping, and test fire!
GTXVette
GTXVette SuperDork
10/21/18 3:41 p.m.
I have always liked light grey,   use a little extra hardner, hot soapy water.
NOHOME UltimaDork
10/21/18 3:46 p.m.
In reply to Dusterbd13 :
You have set the bar the Molvo wiring aesthetics.surprise
Patrick
Patrick MegaDork
10/21/18 4:01 p.m.
You may only get fire for a couple seconds without the VATS key.
Dusterbd13
Dusterbd13 MegaDork
10/21/18 4:08 p.m.
In reply to Patrick :
In theory sinister performance tuned out vats entirely.....
I like clean wiring. Did it for years for extra money.....
Dusterbd13
Dusterbd13 MegaDork
10/23/18 5:38 p.m.
3 vacuum caps, one hose, and a couple of holes to plug.
We hope to pull the pin Friday night
Edit: the reason for waiting is so dad can be there with me. Him and i both need that moment together with this thing.
maschinenbau
maschinenbau Dork
10/23/18 7:00 p.m.
Your engine bay looks incredible! This is the best Challenge Miata since the 1UZ swapped winner of 2010. Looking forward to 2019 - Year of the crazy all-aluminum 6-cylinder swap. You, me, and lil Nelson so far.
Dusterbd13
Dusterbd13 MegaDork
10/23/18 9:04 p.m.
In reply to maschinenbau :
Im going to try to live up to that praise. Thank you.
Patrick
Patrick MegaDork
10/23/18 9:28 p.m.
Don’t give him too much credit he has an iron block devil
EastCoastMojo
EastCoastMojo Mod Squad
10/23/18 9:36 p.m.
That engine bay is quite tidy. And I see what looks to be a very robust ground to chassis. laugh
Dusterbd13
Dusterbd13 MegaDork
10/24/18 5:20 a.m.
In reply to EastCoastMojo :
The ground was handy and the right lenth.
Engine bay photographs well, but needs quite a bit more tidying up before ill call it good enough.
Pat and machine; yup. Missed the all aluminium part. The iron block on this is painted aluminium, so im close!
I want to wire up the obd2 port before firing.  I have found the signal wire from the gm ecm (i think) but cannot seem to understand which pin in the port carries the canbus data. Any ideas?
Patrick
Patrick MegaDork
10/24/18 6:56 a.m.
Signal wire goes to number 2, 4+5 are ground, 16 is battery power.
Dusterbd13
Dusterbd13 MegaDork
10/24/18 7:45 a.m.
Looking at the front, where you plug in the scanner, how are the pins numbered?
Thanks pat. I trust you far more than the conflicting information on Google.
Patrick
Patrick MegaDork
10/24/18 7:48 a.m.
I believe so but i will text you a picture of the plug in the impala after work
Dusterbd13
Dusterbd13 MegaDork
10/24/18 7:55 a.m.
Awesome!
Thanks man
Dusterbd13
Dusterbd13 MegaDork
10/24/18 8:32 p.m.
So this happened
Saturday i hope to get it outside to run for a little bit. Assuming it has a cooling system in place.
Papabishop
Papabishop Reader
10/24/18 8:44 p.m.
Congrats man!! Gotta feel great to finally start it after all the work y’all put in. Looking forward to first drive video.
Dusterbd13
Dusterbd13 MegaDork
10/25/18 5:15 a.m.
Thanks! Its not much, but its a big milestone. I can lock down and tidy up lots of things now.
NOHOME UltimaDork
10/25/18 5:32 a.m.
"No oil pressure"!!!???
Those are not good words to end the vdo on. Tell me it was fixed.
Pete
Efgy2krmQjsZFnJx1uAEqySpLMdfp6bmdJkYOoGcFCP8yjBUrpwT0rcldlgBJKcg
