Dusterbd13-michael
Dusterbd13-michael MegaDork
12/7/19 1:51 p.m.
No more work today. Finished almost all the work underhood and interior excepta faw small things.
At tge trans Siberian orchestra. With DAMN good seats. The whole family is here. Not pictured is mom/dad/two brothers/sister in law)
untchabl
untchabl Reader
12/7/19 2:10 p.m.
Making good progress. I'll have to come drive it again once you're done.
Enjoy TSO, went years ago and really enjoyed it.
Dusterbd13-michael
12/7/19 5:17 p.m.
Great show.
John: keys are  in it
Dusterbd13-michael
12/8/19 8:06 a.m.
time to quit procrastinating. I hate working in the floor. But i dont have a lift at my house, snd im not sure a lift would make a difference here. I also hate gear oil.
I sound grumpy. Im not. I just don't wanna do this. Which is why i did everything else first.
Dusterbd13-michael
12/8/19 9:52 a.m.
It would be on the floor if I could remember how to get the damn axles out
mazdeuce - Seth
mazdeuce - Seth Mod Squad
12/8/19 4:42 p.m.
More hammer?
Dusterbd13-michael
12/8/19 5:08 p.m.
see this? Not more hammer. More dissassembly. Pulled the control arms and spindpes to be able to pull the axles out of the carrier.
Its not a fun job here. Thonk im removing the exhaust to make reinstall a little easier.
Justjim75
Justjim75 Dork
12/8/19 7:55 p.m.
It will be worth it.  You've done so much, just a bit more
Dusterbd13-michael
12/8/19 8:02 p.m.
That was unexpected. Its definitely not healthy. But, its in the new housing. Gonna send it. Hope it survives a few seasons while i decide what to do.
Norma66-Brent
Norma66-Brent Reader
12/8/19 8:15 p.m.
In any automotive endeavor I do the worst part of the job first. Always on the downhill then. I always change the back spark plugs first. Makes me get less angry.
wvumtnbkr
wvumtnbkr UberDork
12/8/19 8:49 p.m.
Why do you think it's unhealthy?  It's like 20.plus years old, right.
TurnerX19
TurnerX19 Dork
12/8/19 9:41 p.m.
Looks like it had some moisture in it, are the pits in the picture the only ones? Or are there more on other teeth? Don't worry much about the wear on the differential gears, only the ring & pinion need concern. Do try to clean all of the iron oxide out before reassembly.
Dusterbd13-michael
12/9/19 5:36 a.m.
Its got pitting and deposits on almost every gear. Heavy corrosion on the bare cast iron parts.
It's tired. It has apparently been full of water for a while.
It is what it is. Im gonna send it. Keep my wmeyes ipen for one of gmthe 3.6 gesr ratio pieces.
TVR Scott
TVR Scott HalfDork
12/9/19 12:28 p.m.
Was it sitting a really long time in a junkyard or something?  Funny that it would rust like that - given how it's full of oil and all.
I'll bet if you hit it with some scotch-brite it'll look ok.  Give it a thorough clean-out, fill it up, and off you go.
Dusterbd13-michael
12/9/19 6:24 p.m.
In reply to TVR Scott :
Ultimately I decided to go with the magnetic drain plug and flush it with cheap gear oil a few times solution.
mazdeuce - Seth
12/9/19 7:06 p.m.
Solid plan. It's either junk or it's not junk and driving it is the best way to figure that out.
Mad_Ratel
Mad_Ratel Dork
12/9/19 7:41 p.m.
That's how I feel about the boxster motor ha!
Car is coming along nicely Duster.
Dusterbd13-michael
12/10/19 6:46 a.m.
Test drive this morning. In the rain. In bald street tires rear, and sm7 slicks front.
Rear aint noisy enough to hear over the exhaust! Interior much quieter.
New gauges are awesome
Nut and bolt check, tire swap, inner fender liners now that i found them, diagnose drivers headlight dim amd wont switch, reinstall splitter, and drive for a while until oiling system overhaul
mazdeuce - Seth
12/10/19 6:50 a.m.
Go shake those bugs out with some miles.
Dusterbd13-michael
12/10/19 7:10 a.m.
Exactly tge plan, Seth. Fun car friday is my deadline fir 100% (minus oiling). Thats 3 days from now. 72 hours. .
This friday is company meeting about 50 miles from the house. 100 mile round trip should be a good shakedown.
Stampie
Stampie UltimaDork
12/10/19 7:11 a.m.
How's the AC?
Dusterbd13-michael
12/10/19 7:34 a.m.
In reply to Stampie :
Not charged yet. Once i make sure everything else is operational and solid, ill call tim petty for a vavumm and charge. Need a belt too.
AngryCorvair
AngryCorvair MegaDork
12/10/19 7:56 a.m.
Not if it's an important meeting.
Dusterbd13-michael
12/10/19 8:04 a.m.
In reply to AngryCorvair :
Valid point. Department holiday party/meeting. Ill check with the boss....
Justjim75
Justjim75 Dork
12/12/19 10:17 p.m.
Hope you drive the racecar to your work thing today and it's glorious.
suwEs89KWI0yjcbZryYngZarkhvbAESTfNZCxC6QZAABXM8IWiiBsdxEoVtuhJyN
