6 7 8
buzzboy
buzzboy UltraDork
8/4/24 9:07 a.m.
I've never tried this trick before and didn't expect it to work so well. I'm sure a leather or rubber belt would have worked even better
buzzboy
buzzboy UltraDork
8/13/24 12:19 p.m.
Going to "elevate" my work environment
My dad and the tow truck driver(a retired career mechanic) joke that I'm about to have a lot of new friends
buzzboy
buzzboy UltraDork
9/18/24 3:37 p.m.
Racecar progress paused while I get the lift installed. She's taaallllll
buzzboy
buzzboy UltraDork
10/15/24 12:19 p.m.
We have liftoff!
Now I can get back to working on this thing
buzzboy
buzzboy UltraDork
10/16/24 4:47 p.m.
Intercooler piping is buttoned up, now with MAP sensor. Radiator is plumbed. All the wiring is hooked up, I hope. I could theoretically fire it up at any point but I'm nervous so I'll keep doing other tasks.
buzzboy
buzzboy UltraDork
10/17/24 2:50 p.m.
I thought today was the day, but I forgot to get a serpentine belt. So tomorrow should be the test day. Tidied up the wiring, filled the fluids, grounded the engine. Checked the engine mount bolts. And welded up a quick dump pipe. I haven't decided on exhaust yet. I'm torn between spending the time and money on exhausting out the rear or a side pipe. I kinda love side pipes...
golfduke
golfduke Dork
10/17/24 3:04 p.m.
Side Pipes.
ALWAYS Side Pipes.
volvoclearinghouse
volvoclearinghouse UltimaDork
10/18/24 9:10 a.m.
Awesome lift!  It's really a game-changer, isn't it?  "Oh, darn, this bolt isn't cozy to get at, I shall raise this 2 ton vehicle an additional 3-1/2" skyward to facilitate the repair in comfort."
Can't wait to see this fella on a track again.  Did you see the 2025 schedule released yesterday?
I know that feeling of "I _could_ start this thing...but I'm nervous to do so".  Been there many times.  It's a good thing- always take a day or 3 and think of the stuff you forgot....like a drain plug...
buzzboy
buzzboy UltraDork
10/18/24 3:21 p.m.
Belt on, coolant in, diesel installed. No smoke when I turned the kill switch. No smoke when I turned the key. No click from the starter solenoid. Oh well, today's the day for a start button. I wired a momentary switch to the starter solenoid, pushed the button, and popped the fuse just after hearing the starter make a solitary clunk. Guess the solenoid takes more amperage than I expected. Oh well, let's add a heavy gauge wire and a relay. Still no click. I grabbed my volt meter to start checking the wiring and my volt meter decided to die. The light comes on, but not the display. Tomorrow I'll get a new volt meter and begin to diagnose my no-start.
In reply to volvoclearinghouse :
There are a few tasks I saved until the lift went up, driveshaft and exhaust. And this bad boy is tall enough I have inches of clearance between my 6'0" head and the arms of the lift. I actually had to lower it so I could reach up high enough!
I haven't looked at the schedule. I really want/need to race next year but don't want to hype myself up until I have access to one running and driving Lemon.
volvoclearinghouse
10/20/24 6:01 p.m.
In reply to buzzboy :
*Cough* Summit Point *cough*
buzzboy
buzzboy UltraDork
10/23/24 8:44 p.m.
I got shafted
Southwest Speed sells driveshafts in ½" instruments increments up to 63½" which is exactly what I needed. Good price and looks nice. I hope install goes well...
buzzboy
buzzboy UltraDork
11/7/24 1:27 p.m.
I rewired my starter circuit to be button>relay>solenoid. Real racecars have big red buttons to start, right?
First try it started spinning over. Success! Or was it?
Second try to spin it over the new relay clicked... and nothing else happened. What now!?
buzzboy
buzzboy UltraDork
11/15/24 11:25 p.m.
Another season has come and passed. I'm "this" close I feel to firing up Planet Express but not quite there. On Sunday I leave for 4.5 months at my winter job. This time a little closer to home. The wife an I are teaching skiing at Stratton VT if anybody wants to come visit.
I love you and I'll miss you Planet Express. I'll be back for you.
golfduke
golfduke SuperDork
11/18/24 8:26 a.m.
We usually hit Stratton 1-2x a year, I'll try to remember to shoot you a message!  It's a nice mountain, quieter than the Bush or Killington, that's for sure.
buzzboy
buzzboy UltraDork
11/27/24 11:17 a.m.
No access to car means spending all my time dreaming. I know I should focus on making it run and drive but wheels are important too.
My current wheels are really cool but limiting. I want to move to an 8J wheel, preferably an OEM takeoff. Looks like a facelifted S197 18" wheel is reasonably available and has a high enough offset to make up for the thickness of an adapter.
Wheel Adapters to 5x4.5
Then that let's me run a 235/40R18 which has plenty of good tire options
This car has cavernous wheelwells and my current wheel/tire package sits about as far inboard as it could. I could likely go to a thicker adapter but I'll need to measure everything when I get back home.
buzzboy
buzzboy UltraDork
4/7/25 10:27 p.m.
I come home from the other job to find I've been ducked!
buzzboy
buzzboy UltraDork
4/17/25 6:01 p.m.
Back to where I left off. My starter solenoid wasn't clicking. I verified power to the 'noid and put power directly to the trigger. No noise, no click, no power to the output side. So I guess that means the solenoid is bad? I pulled it off the car and I'll figure out how to test it.
Also good to find out that I can remove the starter and the solenoid while the engine is in the car. But it's tight
buzzboy
buzzboy UltraDork
4/18/25 8:47 p.m.
It berkin runs! It's a little rough but hearing it fire off feels good! I cut it off because I know it's not got full PS fluid.
A post shared by Hyatt Busbey (@buzzboy_7)
buzzboy
buzzboy UltraDork
4/29/25 10:06 a.m.
Why isn't my new driveshaft spinning smoothly? I guess I banged this cap on a little too hard. I'm still learning how to do UJoints
buzzboy
buzzboy UltraDork
5/1/25 6:10 p.m.
I really didn't want to cut or bend anything else on this poor car but the combination of 3" driveshaft and higher transmission means I had to clearance a little more. Now we have a driveshaft with 1/4” of clearance all the way around it in the tightest spot. Gotta wait until I find good scrap metal to close the hole, but I'll be willing to test drive it(one day) with a gaping hole in the floor.
buzzboy
buzzboy UltraDork
5/12/25 8:29 p.m.
6 7 8
xsd9NXZzzU69aFt4OJB5WbfdcmqbPnQRHy78usF8FOSW7tVlFYhLTkMI7utds718
