throttlegrotto
throttlegrotto New Reader
5/10/24 5:17 p.m.
Hey GRM -
I'm Jeff, and I've hit a road block. I spent the past few years bringing a 20 year dormant body shop orphan Porsche 928 back from the dead. I got lucky to get one of the 'rare' 5 speed no sunroof cars, and after a formidable assembly process, including a respray - I finally got to drive it.
And what a disappointment it was. It is a nice freeway cruiser, but with a 240 hp (probably) 4.5L V8, its not really anything special in the sound or performance departments. But it looks fabulous.
So I set out to change the deficiencies. I found a physically smaller V8 from the Maserati Quattroporte, and gathered up a bunch of spare Maserati (clutch setup and bellhousing) and 928 (trans, torque tube, bellhousing, flywheel, pressure plate) parts to see how I can get them all to communicate and work in the car.
Problem is, I'm no machinist. I don't even know one. I am stumped at this point on how the best way to get the 928 trans, shifter, and torque tube to talk to the engine in the space I have to work with.  I know the 'easy way' out would have been LS swap, but I don't want the car to sound like another LS swapped car.
Looking for advice and input on how I can do it the most efficiently. The video below goes into some of the details about what I'm working with and my limitations.  Thanks for any input you have - I think with the ideas here and over at Rennlist, I can come up with some type of manageable solution.  I know I'm not the most qualified person to be undertaking this type of build, and I'm definitely among the lowest funded person trying something this ridiculous.
jfryjfry
jfryjfry UltraDork
5/13/24 9:10 a.m.
Have you considered going the LS route to make it a little easier on yourself and just doing something with the exhaust if the sound is the big reason you don't like the LS?   (180-degree headers, single, 4" collector  ala celertech, etc)
throttlegrotto
5/25/24 12:21 p.m.
I have considered the LS swap. I don't disagree that it's a much easier way to do things. I also don't want to have the same thing that others have done. The LS is a great engine, but the swap is so commonplace that it just doesn't do anything for me.
There's no commercially available adapter for the F136 engine, and especially nothing that makes it mate to the porsche items. The closest item there is would be the boxster swap from squonkwerkz.  But that uses a more traditional setup, and not the torque tube stuff like I have in the 928.
I'm going to see how much a couple companies are charging for custom clutch setups, it may be cost prohibitive for me to go that route vs. the output shaft adaptor for  $1200-1300. Room in the car is also a big factor.  It may be significantly cheaper to put it into a car I can cut to pieces and modify at will - aka regular trans  and rear diff.
MrJoshua
MrJoshua UltimaDork
5/25/24 1:20 p.m.
Have you considered going back to a Porsche engine and chasing more power? The later engines have a decent amount of power, and IIRC all of the engines take to your choice of boost really well.
Edit: and it has all been done in recent enough history that there should be threads you can use as a guide.
preach
preach UltraDork
5/25/24 1:51 p.m.
If the bell housing is the same bolt pattern as a 944 (or just use the 944s torque tube) that would open up an 07k swap from a VW. May not be a v8 sound but 5cyls sound amazing and they like turbos. The reason I bring that swap up is that it's being done quite a bit to 944s. Probably much more budget friendly than swapping a Maserati engine 1 off.
I do not want to dissuade you from your idea, as it is pretty cool, just trying to outline another option (I am also a huge 07k fan). Some light reading:
07k 944 Swap
Hoppps
Hoppps Reader
5/25/24 10:43 p.m.
Son of a guy in our local SCCA is swapping a barra into their 944.
throttlegrotto
5/26/24 1:13 p.m.
The later porsche engine (like the 32v 5.0) does probably sound quite a bit better. The engine bay on these cars are packed to the gills with anything porsche, though. They made the engines to fill the bay (my impresssion) and making power on them is definitely not a money saving proposition. I did see locally a 5.0 32v for sale that had questionable history for more than I paid for a 35k mile maserati engine.  The maserati 4.2 is also physically smaller than either of the water cooled porsche engines.
I don't think the torque tubes share the same pattern. They are definitely not the same length.  I wouldn't be opposed to a boosted 07k, but I also may save that swap idea for my vw rabbit. It would be an easy engine to fit into a 928 though. I would probably be able to stand in the bay at that point.
I wanted to do a barra swap for a while in the 928, I bet in a 944 it will be a screamer.
I'm going to try and get measurements over the holiday weekend and get some clutch quotes this week.
There's also a parts 951 in the area that I may be able to get crazy cheap. I wouldn't feel terrible about cutting up a parts car and fitting whatever I wanted into it. A regular transmission and rear diff setup would be easier to modify, and with 400hp on tap, weight distribution isn't as big of a deal. Suspension tuning can take care of a lot of those issues.
throttlegrotto
1/17/25 2:06 a.m.
Sorry for the lack of recent updates.
After a lot of grieving and acceptance, I decided that an Audi ABZ is a much better fit for the car with a 4 inch lower (nearly matching the 928) crank to oil pan height, and a front sump like the 928.
I'm currently on the hunt for a way to marry the 928 bellhousing to the ABZ engine and then figure out if the 034 flywheel insert adapter will work as a friction surface for the twin disc clutch. The flywheel on the 928 and the ABZ flexplate are nearly the same outer diameter. I'm sure this portion of mathing is 2nd nature for some here on the board, but it's all foreign to me.
classicJackets (FS)
classicJackets (FS) SuperDork
1/17/25 8:20 a.m.
I'm gonna plug for AngryCorvairs build here, as he designed/had machined an adapter to mate a GM LT1 engine to an Audi transaxle in the process of his build. If I can find a link I'll drop it here.
glad to see updates though!
TR7
TR7 HalfDork
1/17/25 8:59 a.m.
Well, you have the Maser bellhousing, and you have the 928 torque tube. Does the tip of the 928 drive shaft reach into the Maser flywheel with a bit to spare (maybe 1/4")? Yes - Great! Grab a piece of MDF or cardboard or what have you, and find center of the TT (where the driveshaft needs to be) and mark it up, drill some holes. Do the same at the end of the bell. That will be your adapter plate more or less. If you dont have that reach, you will still need to do this step, but cut the flange off the end of the TT and then weld it on a little further back. Next step figure out your pilot bearing situation. You want the tip of the 928 DS to fit nicely in the flywheel. Take measurements and see what can be had (mcmaster carr or fastenall is a good place to start to try a couple sizes to see what fits).  Now figure out the clutch. Does the 928 clutch fit between the flywheel and pressure plate? Awesome, lucky you. If not, you might need to find other clutches with the same spline and different sizes to fit (good luck) or have a custom clutch built (try here https://www.kennedyeng.com/clutches). Now head off to the Home Depot Racing Supply Store and get yourself a plate of aluminum, same thickness as whatever gap you have from bell housing to TT we talked about earlier. Center up your MDF templates and drill away. Assemble all your pieces, figure out where you went wrong, break stuff, repeat, enjoy.
NOHOME MegaDork
1/17/25 10:41 a.m.
Agreed that the 928 is a beautiful car, even more so for lack of sunroof.
Agreed that the 928 is a mile-eater not a sports-car. I can respect that.
Agreed that for all its swiss-watch-rube-goldberg complexity and cost, the 928 engine is wet toilet paper in the power dept.  by today's standards. All the ones I have met are also expensively broken, so that leaves an impression
Where I don't agree is that the Masserati driveline is going to be any more  life-affirming than the 928 drivetrain. It will certainly be broken more often with more expensive parts than the 928 to repair. So it will feel like you are dating an Italian chick rather than a german frau.
I think that by the time you are "done", you are going to be a lot wiser and know how you SHOULD have done the job. By then you will be ready to move on because you will also be facing the two-year de-bug/development phase of the project that none of us budget for emotionally or financially.
The LS swap is the correct answer BECAUSE it has been done to death, It delivers what you want without the short and long term pain. Forget Ginger, jump on Mary-Ann.
Then again, there is always something good to say about a good Bunga-Bunga party!
1/17/25 11:20 a.m.
In reply to throttlegrotto :
First, an apology: I didn't watch the video, so I don't know if you've answered these questions:
what fabrication tools do you have? Drill press, lathe, mill, plasma cutter, welder, etc?
what fabrication skills do you have? ie the ability to safely use any/all of the above?
how much do you want to make vs buy?
are you willing to fail your way to success?
NOHOME MegaDork
1/17/25 12:50 p.m.
"Fail your way to success"
Now THERE is a term I can relate to!
golfduke
golfduke SuperDork
1/17/25 1:18 p.m.
I don't think the engine choice is the limiting factor here, moreso than it is the mechanical interfacing and potential ptototyping nature of the project.  The Porsche torque tube/transaxle setup isn't the most common in terms of adapability, so  that's gonna be the key.
I'd almost start off by buying/adapting a 944/951 torque tube end onto your 928 torque tube, which allows use of an off the shelf adapter to accept an LS/coyote engine/hydraulic throwout bearing.  From there, see where your engine of choice lines up, and make a cardboard template and see how everything plays together... Without the pieces actually in-hand though, I think it's gonna be really hard for you to get the math right.  Not impossible, but like Angry said, you're gonna need to be patient and willing to fail plenty to get it right.
Basically, work backwards, not forward.  I'm positive there are off the shelf LSx bellhousing adapters that will likely get you close... then it's  a matter of trial, error, luck, patience, and fabrication to get it to interface with your engine.
Where are you located, if you don't mind me asking?  There's plenty of people around the country that would love to help I bet.
wawazat
wawazat SuperDork
1/17/25 2:16 p.m.
I havent watched the video but did see your note about a front sump oil pan.  Not sure where that stands on your engine selection card, but small block and big block Ford engines used in the Mustang and its derivatives in the 60's and early 1970's used a front sump oil pan.
kombatrok
kombatrok New Reader
1/17/25 3:58 p.m.
I'd imagine an early 928 would be a prime candidate for a swap. I have a later 32v car and even with some tuning and tweaks it has just barely enough power to not feel slow by today's standards (it does sound good though... very obviously not an American V8 in the noise department)
Another option if the 928 engine is in good shape otherwise is to rebuild it as a stroker. People are running 6L setups that make good power. Not that it would likely be any cheaper than a swap.
throttlegrotto
1/18/25 2:31 a.m.
In reply to TR7 :
Thanks for taking the time to make that all 'make sense' to a non-machinist.
I'll try and address all the responses here -
The major issue with the F136 is the crank height. 4 inches higher in the block is way more than I can compensate for in the driveline and the small tunnel. Briefly considered the new tunnel and driveline route, but that is just getting to screw you levels of money, which I don't have.
The audi ABZ is the consolation prize. All aluminum, 300 hp, which won't light the world on fire, but gets me to Euro 16v /5.0 levels of power and a significantly cheaper engine. I bought an 85k mile engine for $500.  I really don't want the LS swap because I don't want the car to sound like every other LS swapped car out there. And it's definitely the easy way.  The ABZ will give me sort of a RS2 vibe with the audi/porsche combo.
I have a ton of hand tools and a drill press. I'm not flush with this type of fab tools, so the method TR7 went through is pretty easy to do, even in my home garage.
One of the benefits to the ABZ is the flexplate and the 928 flywheel are nearly the same diameter. 034 motorsport made a flexplate insert with a friction surface for 5 speed conversions a decade ago. And they're making a new run of them.
The reason (and part of my expensive learning curve) the LS works so well in the 928 is the low crank height in the block. Here's a 928 block with the oilpan removed. The pan is pretty thin at the back, maybe a inch or two deep.
in comparison to the ABZ block (best photo I could find)
If you imagine the maserati crank 4 inches higher in the block on the 928, and the 80mm (IIRC) from the crank center to the bottom of the mating surface, there just isn't room to play under the engine.  But with all the stuff set up on against the ABZ block, using a S4 bellhousing I had from a spare driveline, it almost matches up arc-wise to the block. So it will be a much easier thing to adapt.
I'm located near seattle
Adapting the 944 torque tube makes things a little more complex, because the length of the cars are different. So there's a modification there to either the length, the ends, or both. And since it's not a c5/6, people aren't doing that stuff as much. That can get expensive quick.
My prediction is that I'll need to space the flywheel insert away from the block, and leave the trigger wheel and starter ring in place. I think a custom flywheel makes the most sense in that scenario. Finding a company that will do that is a whole different scenario.  But using the stock twin disc clutch will hold the power, and take up the least amount of space in the bellhousing. Plus, the 928 uses a pull type clutch instead of a push. Not having to reengineer that will save a ton of time.
And I do seem to fail upwards. I've failed at 8 years of youtube and can still build cars at home, so I guess that's all I can hope for.
I had considered a stroker, but the cost to do that on a 40 year old porsche engine is just not in the cards. The $40/ month of adsense payments won't get me too far on that project. But I heard you can use a LS crank and parts to do it.
Sometime in the next week or so, I need to get the bellhousing and engine in the same spot in the garage and do some real measuring to see what I can do with TR7's technique.
And the 928 engine will make a great coffee table project, hopefully recovering some of the costs of this part of the build.
wvumtnbkr
wvumtnbkr UltimaDork
1/18/25 7:50 a.m.
This is pretty cool!
Run_Away
Run_Away Dork
1/21/25 12:18 a.m.
What about Coyote swap? It's been done before, it doesn't sound like an LS, and makes plenty of power
TR7
TR7 HalfDork
1/21/25 2:08 p.m.
My brain wants to tell me that not only is the length between the 928 and 944 TT different, but the drive shaft diameter is also different (smaller on the 944), and therefore wont mate up with the trans in the rear easily. But I am going from memory, so I could be wrong.
However, being that its not the end of the world to fab up a different diameter spline to the end of the drive shaft. Look into not only the 1.8t swap 944 kits, but also the 07k swaps.
TR7
TR7 HalfDork
1/21/25 2:17 p.m.
There are a couple of threads floating around that might be of inspiration (mostly for 944 - VW motor swaps), but the idea is the same.
https://forums.tipec.net/viewtopic.php?f=25&t=21900
Using the donor motors bellhousing, clutch, starter, ect if possible simplifies things. I wouldnt jump to custom flywheels and the like if I didnt have to.
throttlegrotto
1/22/25 2:25 a.m.
I'd considered the Coyote swap, but at 4k for an engine, and a fairly wide one at that - it wasn't gonna happen on my mac and cheese budget.  There was a shop that installed a coyote engine in a 928, but there's not much information other than a few photos available on it.
I did contact a machine shop about a splined adapter in the past to go from the F136 bellhousing output shaft down to the 928. At $1500, I'm glad I held off on that expense. But the knowledge that it can be made was worth the time expenditure.
I currently plan on using the 928 clutch, pressure plate, and splined torque tube adapter, with the 928 upper and lower bellhousings.  I also have the whole F136 clutch assembly (not easy to come by) but the length of that unit is even deeper than the 928 parts. I think it added 4 or 6 inches of length over the 928 parts.
The ABZ starter will engage with the ring gear on the flexplate.  The 928 starter would engage the ring gear on the intermediate plate. So I have two options for starters, depending on what the actual interface looks like between the intermediate plate/forward disc and the engine. If the 034motorsport flexplate insert is the proper thickness for it all to work, I'd just have to have the plate drilled to accept the pins and bolts for the IP.  I have no idea of the thickness of the plate or any idea of how much room I have to play with yet.  These parts have been out of production for about 15 years, but they are currently producing a new run of them.
If I have to space the 034 insert out past the flexplate to make the friction surface have proper contact (can that even be done) I would presume that some kind of AL spacer would be set behind the flexplate insert to push it rearward.  Reason to keep the flexplate is the engine speed sensor and the toothed ring. I suppose that could be moved to another location (e.g front pulley) with another custom part.
The custom flywheel would make that part of the install easiest, provided I measure things correctly and then it's a simple bolt on, and bolt in part of the swap.
Maybe I could have my 928 flywheel filled and drilled to work with the 10 bolt crank orientation, and use the flexplate simply as a toothed sensor for the ECU and a starter gear?
I need to borrow an upper bellhousing for mockup soon. I don't want to remove the one from the car unless I have the engine coming out as well.
TR7
TR7 HalfDork
1/22/25 10:51 a.m.
Why try to match up the ABZ with the 928 bell, clutch, PP, flywheel? That seems like extra work. Use as much of the ABZ as possible and just adapt the 928 TT and DS to fit. Dont even make a spline adapter, just cut off the splines from the 928 TT and weld on what you need from an  ABZ trans input shaft or something.
bearmtnmartin (Forum Supporter)
bearmtnmartin (Forum Supporter) UberDork
1/22/25 3:51 p.m.
If you do a search, there is a pretty extensive thread here somewhere regarding adaptor plates.
throttlegrotto
1/23/25 1:39 a.m.
There never was an ABZ manual trans equipped car in the states. Even ROW, it's a pretty rare bird. Think Audi D2 S8 and the take rate on a manual on those. I think some of the C6 RS6 cars came ABZ equipped too, but not stateside.
And the 928 setup is unique in that it goes in and out of the car from underneath, not pre attached to the flywheel. You can remove a whole 928 clutch setup in a half-hour. The party trick is the 2 piece sliding spline adapter that goes down the torque tube for removal, and then slides into the clutch discs and bolts in place for engagement. The lower bellhousing unbolts as well to allow to access to about 40% of the pressure plate, and gives room for the intermediate plate/2x discs/pressure plate/release arm/ T-O bearing / and guide tube to drop straight down out of the bellhousing. Only the flywheel stays attached to the engine.
the splined shaft that engages the 2x clutch discs
And the coupler that joins it to the torque tube.
So deviating from this setup would take a lot more ingenuity than I have ,and also make engine removal potentially more difficult later.
NQSxtUEgkb1M7yqNkHsu26xw2msrckuFoesObmrhQuSkW8V0qxNGGWDOwrXqQDBy
