pres589 (djronnebaum)
1/23/25 6:46 a.m.
I feel like a set of cams and a tune on the 928 engine would make a lot of sense here?
TED_fiestaHP
TED_fiestaHP HalfDork
1/23/25 8:56 a.m.
   Cams and tune....
      The nice thing about a 928, its already good.  The down side not so easy to improve.
         Some have added a supercharger, and there are a few examples of other mods, but not as simple or as cheap as updating some chevy V8.
        Something as simple as exhaust headers, normally a cheap and simple update, while headers are available, they are fairly expensive.
       The easy update seems like some sort of chevy V8 that could be updated, basically just use the engine block, the rest could be after market improved parts, there is so much available
      But I do admire anyone being creative.   I wonder what it would be like to put 4 weber carbs on a 928.  Instead of sorting out the old fuel injection.
       The 928 is a older design, but it doesn't look like a old car, engines have been greatly updated since then.  So many other engines could be a update.   There seems to be a fair supply of old / fairly cheap 928's to work with, most need a engine.
kombatrok
kombatrok New Reader
1/23/25 2:15 p.m.
Not really much in the way of cam options. For the 16v engine about the only option that I'm aware of currently is to get a set of euro cams, which would be a nice upgrade over the stock US sticks, but still we aren't talking about a whole ton of power.  Likewise there isn't a whole ton of tuning to be done for more power with the stock L-Jet.
brad131a4 (Forum Supporter)
brad131a4 (Forum Supporter) HalfDork
1/24/25 8:11 p.m.
If you could have found a 01-03 S8 that was wrecked it would have been a bit easier. They have 360hp and are pretty rev happy. Only thing is getting the ecm tuned to have the emobilizer removed from it. Sometimes getting the ignition and instrument panel works as well. Thing with those motors is that when they are uncorked they sound like a nascar. Now if that's what you are going for then good luck.
MrRobogoat (Forum Supporter)
MrRobogoat (Forum Supporter) Reader
1/25/25 12:15 a.m.
I do have access to a machine shop that could do an adapter plate easily, but not the flywheel.
Some thoughts: The ABZ was a popular swap into older Audis. VW/Audi gear boxes used to use either the 4/6 cylinder bolt pattern, the 5/8 cylinder bolt pattern, or both (this is up until the mid 2000s). I do not know what flywheels were being used. Motorgeek.com has forums that probably have some answers on how those swaps worked.
Here are some flywheel options, you will have to inquire for price.
The real key is whether you can get the engine into the right position by adapting to the 928 bellhousing, of if you'd have to have a new bellhousing made. Clutch clearance inside the bellhousing also effects this, followed by whether there's space in the tunnel. I'd expect the ABZ to have the starter on the engine side, which would make things slightly easier, since it shouldn't require any modification to engage any off the shelf flywheel product for that engine. If it's transmission side, that means modifying or making a new bellhousing I expect.
The other good news is that with the weird coupler adapter to the torque tube shaft, you could conceivable have a new adapter shaft made to whatever length you need. Since the splines are external, they should be able to be cut on a 4th axis mill, though the cutter may have to be ground to get the right profile. This would be easier than having a bellhousing made, and would let you correct for whatever depth adapter plate you end up with. Additionally, it would also let you use whatever clutch disk you want, ideally the one that matches the pressure plate you use, which then has to fit the flywheel and inside the bellhousing.
For the clutch actuation, using an internal slave cylinder is a popular and relatively easy way out if you have the longitudinal space. Flipping and modifiying or making a new clutch fork would be necessary for an external slave. I know flipping and modifying the 944 clutch fork has worked in the past.
throttlegrotto
throttlegrotto New Reader
2/16/25 2:20 p.m.
I think if the 034 flywheel insert plate gets released soon, that will solve the engine to flywheel part of the swap. I think that there is a way to have it drilled to accept the twin disc clutch. Then it all bolts to the ABZ flexplate and it needs an adapter plate between the engine and bellhousing.
I had an offer to trade the 928 for another car, and I should be hearing on that soon. If that doesn't happen, it's probably game on-ish for this swap.  I just spent another wad of cash to have the intermediate plate pinned and de-warped, so that should fix the previous clutch issues. I may end up trying to enjoy the car a little bit over the summer and get a little use out of it before I tear into it.
If it doesn't, I also have a rough-ish 944 hanging out in the shop that is just worthless enough to be a project for this engine. I think with a 924 turbo (931) bellhousing, it gets things pretty close from what I've read.  So I'm in limbo for a bit.  It would be fun to have a 944 empty bay and play around with the ABZ and the F136 to see what is possible with the 944 chassis, but I also may just get that car back together and have a driver for a while too.
Also have a supra coming to the shop for some work and a 2j conversion soon, so I'm going to have a busy spring.
throttlegrotto
3/2/25 6:59 p.m.
Just a quick update:
After a long few days swapping the g28/05 that was in the 928 for a g28/13 that I got an okay deal on from a junkyard, I have 5 gears both up and down the shift pattern. Still waiting for the trade guy to come and see if he's still interested.  Got the IP back in after de-warping and it seems the clutch is healed.
It was a lot more work than I thought it would be.
https://www.youtube.com/watch?v=GdR3zXVZNX0
I also found a company that makes an adaptor and clutch solution for the f136. Uses a cd009 transmission, but it at least solves the hardest part of the swap. I need to figure out if the engine will fit into the bay of a 944, or sell the 944 and find another platform to put it into. Smart sense says the 944 is the worst idea, but I could sell the drivetrain parts and come out ok and pay for some swap parts. I wouldn't feel bad about cutting up the 944 to make the swap happen since the car is already a but rough.  I'd say goodbye to 50/50 weight, but that isn't always the most important thing.
What would you put that combo into? I think the f136/cd009 fits better (on paper, mental math) in the 944 than the euro E30 I have.
yupididit
yupididit UltimaDork
3/3/25 8:43 a.m.
So you traded the 928?
throttlegrotto
3/15/25 5:41 p.m.
Not yet. I should find out tomorrow morning if the deal will happen.
Well, good news if you are planning on an F136 swap - there's a solution now that uses a CD009 transmission and custom flywheel. Speed Gems now makes a kit for this engine and trans to mate up. If you use code 'throttlegrotto" you can save %10 on the kit.  My kit is still in the mail, but should be here soon, and I'll do a video on putting it all togther.
https://transmissionadapters.com/products/ferrari-maserati-v8-f136-to-nissan-cd009-6-speed?_pos=1&_sid=25ddbda22&_ss=r
Which means that there is now a push to find a car to put this setup into. Requirements are:
good road presence.
large engine bay
drives well with 400hp
decent aftermarket supplies
Leading the list are Z32 300zx cars right now - Some of the other cars I've considered don't quite have the whole package.
yupididit
3/15/25 7:15 p.m.
In reply to throttlegrotto :
Z32 would be perfect. They're beautiful.
What about a Lexus SC300/400.
throttlegrotto
3/24/25 2:40 a.m.
A few big updates here while stuck on nights.  First off, the 928 trade deal fell through. He got a 'better deal' elsewhere at the 11th hour, so I'm stuck with the car for the near future. The prospect of a trade got me to get a few things done on the car that had been annoying me, so that is a positive. I'm still going to look into the ABZ parts as they come available and I think once 034 re-releases their flywheel insert, I will be able to make some moves on that stuff.
The F136 adapter kit showed up and it's a nice setup. Should have a detailed video of the parts and the install soon. I'll have a complete engine/trans by the end of the week, bolted to a CD009 ready for a project car to show up. I'm still waiting on confirmation of an offer I made, so I won't speculate on the z32 recipient yet.
My datsun roadster took over some spare time with an incident involving a Honda Pilot. So I've been negotiating all that and starting the work on the body repairs. Minor damages, but major time to fix them in an already sparse amount of time I have for garage stuff recently.
Not the greatest set of updates, but it's still some sort of forward progress. Which is terrible for youtube, but average for most humans.
throttlegrotto
5/14/25 12:13 p.m.
oof. A tone of updates in the last month. things have been absolutely silly around the garage.
First off, I got the cd009/F136 all bolted together. The adapter setup is a nice piece of kit.  And there is a 10% discount code if you want one yourself. (throttlegrotto)
https://youtu.be/JZjhgIuet0I?si=snQYlbTgm79iYhy9
And then I drug home another project, as I am contractually obligated to by youtube (not really, but this is the way, and it sucks sometimes.)
A Sapphire blue metallic Z32 300zx for those of you that skip the links.  It was the typical 'old guy' owned car with a bunch of deferred maintenance. Including a clutch that blew in the owners' driveway, some seized brake calipers, and the rabbit hole went deeper.
https://youtu.be/UpwvYL4JFcY?si=H5jaNxoWAxeJEr01
But, after a TON of replaced items, the only logical thing to do with a completely untested (to me) car that sat for a while was to take it out and drive it. I used the same recipe on the datsun roadster and did the Idaho overcrest rally in '23, after an initial test drive of about 10 miles.
So I had initially signed up for the Daypass event here in the PNW and had planned to take either the Datsun or the 928.  After a significant investment in clutch issue resolution (and the lack of progress in achieving that) I elected to take the 300zx.  Which meant another thrash to get various issues taken care of before subjecting it and myself (and a partially suspecting co-driver aka @slippery) to a full day of driving backroads of Orygun.
https://youtu.be/UCgyVJ-yoVY?si=47-uvYIyxF0_BfgD
Turns out, having a co driver is a lot of fun, and he was a great sport about the trip and my less than pro level of vehicle handling. The car, aside from a hot start issue that didn't surface on my 10 mile test loop, worked like a champ. Turned out to be an easy to replace coolant temp sensor. Still a few things to take care of, like the front tension rod bushings and a completely untrustable emergency brake. Wood block for the win. And, the Taiwanese vintage 90's mufflers - Hayame brand - literally caused nausea with the cabin drone around 2k rpm. They did sound good in the woods at full throttle, but I paid for that joy on the highway for 175 miles each way there and back.
People, The 300zx is good. So good. In the car for most of the day from 5am to 11pm in one day. 3rd and 4th gear for a lot of it. Hadn't driven the car, let alone hard-ish and it felt GREAT. The stock suspension saved my back and made for some fun backroad driving.  Sure, it could have used a bit more power on the uphill sections, but it wasn't slow either.  This one may be a long term ownership car.  And I have an engine and transmission just 'laying around' that may really make this car amazing.
I met a ton of great GRM people at the event too, including the guys from Scheel-mann and am scheming on how to afford a set of the grey checkered sport seats to put in the car.  If you are looking for Recaros, give them a look too.
I have more updates on the other cars in the fleet, but that is another video update away!
Slippery
Slippery UltimaDork
5/14/25 12:23 p.m.
Co-driver here.
I was very impressed with the Z32, especially being NA, how fast and nimble it was. I thought it was going to be more of a grand touring car, I owned a z31 and always thought the Z32 was a much larger car, but was pleasantly surprised. It is quite quick as well.
Throttlegrotto gave the car hell and it never let us down ... and even though he was not thrilled by how loud the exhaust was, I thought it sounded great.
Loved meeting other GRMers, both ae86andkp61 and throttlegrotto!!
Awesome trip to Oregon and an awesome co-driver. Had a blast!!
yupididit
5/14/25 1:13 p.m.
Time to go make an offer on the Black z32 that's been sitting in the driveway of the house behind mine!
throttlegrotto
5/20/25 11:49 a.m.
It may surprise a bunch of you, but I'm still trying to figure out the issues with the 928 clutch, in addition to all the other trash going on in the shop. Having the 1.4t rabbit immobilizer go bananas doesn't help the fleet, but I pulled the clutch again on the car and got another round of disappointment.
so I definitely have more work to do in the shop.
throttlegrotto
5/25/25 6:39 p.m.
Along with a regular job, a house, and the other struggles of life, I've also been trying to sort out the issues that have been consistently preesent on the 1.4t rabbit swap I did a while back. The car ran and drove, but the wastegate, which is electronic, opens at 3300 rpm and kills all the boost. I tried working with a few people to get some tunes that would allow me to calibrate the item through VCDS, and it all ended up bricking the ECU.
So now there's another one enroute to a mystery location (really) and I am hoping for a solution within a week or two.
throttlegrotto
6/7/25 7:13 a.m.
Hopefully I have an ECU in hand for the rabbit next week.
Current shark closest to the boat is E30 picnic, and a very uncooperative E30 323i. The euro bits are making it hard to get the car to run properly. Thought I had it dialed in and then on a quick test drive around the block, I learned I didn't. Turns out 40+ yr old L jetronic isn't easy to get running right.  Now on the hunt for a motronic engine to swap in, which is also tougher to find than they were 20 yrs ago.
throttlegrotto
6/17/25 12:17 p.m.
I had an even closer shark to the boat this week, since the e30 replacement engine didn't show up, I flexed to driving the 928 a bit to see if the clutch would improve.
Turns out the volvo fan control unit I had didn't work, and I picked up a replacement volvo fan controller and new rad switch to fix the issue.  Decent time to document how to wire one up for a 2 speed fan.   Next item to fix is the z32 300zx, since every single fuel line clamp I redid before the rally decided to loosen and spring a leak at the exact same moment this morning. Oddest thing I've ever seen fail. 10+ fuel injection line clamps all spraying fuel.  Not a drop on the garage floor prior to startup, no gas smell in the shop.
oKgyAaSRpbfgvm7QrDZxe0F18nvxK6RjcaYj2PqZxm3DLRVIkwXXDOBusDSeABXZ
