Dusterbd13-michael
Dusterbd13-michael MegaDork
8/12/24 6:12 a.m.
Is the engine still serviceable nestled down like that? Or is any service now an engine out operation?
nocones
nocones PowerDork
8/12/24 11:39 a.m.
It would likely be fine.  The body would drop relative to the engine by about 3" realistically.  The subframe for proper geometry needs to come up some.  But everything is accessible so normal service should be okay.
Other then a radiator and hood/bumper mounts there is nothing else that needs to go in front of the engine.  I will likely run some tube along to sort of hug the radiator and provide a hood latch, but it should still allow for easy access.
Good question though.  I hate building things that can't be serviced and it made me think about it a little more.
nocones
nocones PowerDork
8/12/24 11:40 a.m.
Day 7/30 was a lighter day.  Just got exactly 30 min and just cleaned up some tools and moved a few things around.  Nothing photo worthy.
Dusterbd13-michael
8/12/24 12:18 p.m.
Gotcha. The angle of the picture made it look like the valve cover and plugs on the drivers side would be engine out. I ASSUMED it was angle, but wanted to ask.
Gammaboy
Gammaboy New Reader
8/14/24 8:20 p.m.
nocones said:
So I present a pile of parts I am 99% certain has never been attempted before.
A Miata Subframe with a RWD converted Subaru EJ22/5MT in the front of a Panhard Dyna Z.
The engine obviously is in front of the subframe but because of the firewall position any engine would end up that way there isn't a lot of space between the wheels and the firewall.
Not much poke even with the 15x9s.   So it looks for sure like this will wind up with Miata subframes and RWD.
I had been thinking a BMW 1150 or 1200 flat twin would be a great swap - like the 2CV guys do.
nocones
nocones PowerDork
8/15/24 10:18 a.m.
In reply to Gammaboy :
I had considered motorcycle power.  The flat twins would definitely match the original car, and nearly double the HP as the Panhard had 50-60hp when new.   But it's still a 1900lb car, plus weight of people.  2CVs are much lighter at ~1300lbs.  At the weight this will be Automotive power with integrated reverse available makes more sense.
nocones
nocones PowerDork
8/15/24 10:19 a.m.
No pictures for day 8/9 of 30.  I just continued to clean on day 8, and on day 9 I did a small home project.  Tonight will be something picture worthy I hope.
nocones
nocones PowerDork
8/17/24 11:27 a.m.
Day 10 and 11 have passed with more cleaning and moving stuff around.   Honestly I'm kinda tired of it.  There is no actual end in siight.  Almost everything is on wheels so it's easy to move but I've still spent weeks basically shuffling stuff around the garage.  I think despite the fact that I have really exciting plans for lots of this stuff it's probably just time to move on from it to free up space to do the 3 big projects I already have.
Its very difficult though because I tell myself keeping these "future projects" around doesn't really hurt anything but it really does.  It takes up physical space but perhaps more importantly it takes up mental/emotional space.  My wife had a good observation the other day.   She said all these projects in waiting are fine if they are just waiting and the ideas I have for them make me happy but it seems like for me they are just 4 projects I feel like I'm behind on.  And she's right.
As cool as they are and as good as the plans are it's probably time to legitimately make some for sale posts.
Gonna spend time thinking about it all this weekend and probably get some pictures of things.
hobiercr
hobiercr UberDork
8/17/24 12:35 p.m.
In reply to nocones :
I'm right there with you. I have projects and project cars to last two lifetimes. Letting go of potential futures is TOUGH.
budget_bandit
budget_bandit Reader
8/17/24 12:43 p.m.
I can resonate with that. A good friend of mine said it well once, and i'm not going to try to quote him because i'll butcher it. But his premise was that current projects cost you money, future projects don't cost you money but they cost you emotional capital in thinking/planning/wishing. And I have found that to be true for myself. Selling my motorcycles that were "oh i could do this to one some day" was a huge mental load off of me. YMMV
physician
physician Reader
8/18/24 8:38 p.m.
not tryin ton convince you here, but R1200 air cooled engines have divorced transmissions and 120hp. they weight 100 pouds, around 200 less that a ej22. somes are turbocharging them to 180.
ej22 sure will be way more reliable.
im considering it for mid engine locost/550 build..
Piguin
Piguin Reader
8/19/24 5:10 a.m.
In reply to physician :
That comment sent me in a deeeeep rabit hole looking for conversions on the net. Thank you, it was enjoyable.
nocones
nocones PowerDork
8/22/24 1:13 p.m.
Okay I'm on day 16 now.  More then halfway.  Still keeping up with 30 min or more per day.   It is helping avoid falling into a rut of not doing anything.  I force myself to even just clean for a half hour.  Many days I am motivated to do something but it's easy to string days of rudderless nothingness together and then the projects just sit.   This helps avoid that when you are in between goals.
Cleaning continues but I got the Sambar into the lab to do some work.  The brakes where... Awful.  Also the carburator didn't work right.  It would run okay until about half throttle on the choke and idled great.  But it had no top end.
So it clearly needed the carb cleaned.
Hovermode engaged.  I found the left rear brake clamped off.  I figured out why.  The brake shoes where missing.   The right rear was absolutely covered in fluid inside.  One piston had seized and it seemed that the other moved to far and blew fluid past the seal.
The front brakes where okay, nearly new pads and both calipers worked.   So after a bleed and a cleanup of the bad wheel cylinder I managed to make 3 working brakes.   Thats enough for now.
The carb was removed and cleaned.  Harbor Freight sonic cleaner for the win here.
This morning I threw the wheels on and drove it before work.  Man it drives much nicer.  Still a slight hesitation at half throttle but much more driveable.
Now to decide what to do with it.  It probably will just get sold with the 360 van with the goal of downsizing the fleet.  But it is cool to play with.  I'm resisting taking it off roading.  1. Because I'll probably break it, and 2. Because I will fall in love with it.
Somebeach (Forum Supporter)
Somebeach (Forum Supporter) Dork
8/22/24 4:37 p.m.
Does the cab of the Sambar feel cramped? It just looks pretty small.
I saw your picture compared to the Willy's truck, but I've never sat in one of those either.
Piguin
Piguin Reader
8/23/24 3:05 a.m.
Guess you decided what you want to do with it - didn't see a mention of the 360 in the ad though.
akylekoz
akylekoz UberDork
8/23/24 7:17 a.m.
I can hear this, however you need at least one future project to keep you going or you die.  At the rate I'm going I will live several lives.
nocones
nocones PowerDork
8/23/24 5:03 p.m.
In reply to Somebeach (Forum Supporter) :
It's not huge but at 6' 240lbs I could use it comfortably.   It is actually less cramped then the OEM Willy's would of been.  It's wider then the Willy's and has more cab depth.  My Willy's has a ~5" firewall extension so it's much more comfortable then a regular one.
In reply to Piguin :
Yeah for now it is for sale for what I paid.  Unfortunately it does look like the market may have softened considerably over Summer.  On the 360 Van disposition is not guranteed, I am waiting to see what the result of the brake installation is.  It also will most likely get sold but "functional brakes" are a big deal on the value of those.  Mine needs some seals and boots but if I can say that they work and just need seals the value is probably $1000-1500 higher.  And it could be driven some.   If someone was interested in the Van+Sambar to continue with the chassis swap I would sell both.
In reply to akylekoz :
I totally hear what you are saying and you are right I would go crazy if I didn't have "something" out there to think about and do.  But even if the Panhard, 360 Van/Sambar, and Autobianchi go I will be fine for future projects.  Nearly everyday I send a few FBM listings to people of cool stuff I would like to build, so I could always buy something.  I also have another "BIG" idea that I have no parts on hand for that I would start on purchasing as soon as the LMP360 got the swap and aero mods done, the MG got a hardtop fabricated and street converted, and the Willy's got a UTE tray and canopy fabricated for "overlanding".   I think I probably already have the several lives thing going also.
And honestly that's part of the reality.  These "Projects" I have are all big nearly LMP360 level efforts.  Multiple thousands of hours over months and years of time.  Probably between everything in the garage I have nearly 10 years of projects.  And some of them have been here for 4 years already.  I am not sure if it makes sense to keep them around when my desires and ideas may change.  It probably makes more sense to buy something when I have the time vs. sit on them.
I don't mean to give people whiplash talking about projects and showing some work and then in the next post talking about selling that project but that's kinda the thing with this thread.  This is for all the stuff that is floating around that might just be an idea I impulsively bought or an opportunity I saw that I jumped on that just doesn't work out.
nocones
nocones PowerDork
9/8/24 7:30 p.m.
A few things happened this weekend.
I've kept up the 30 min a day so much that it has just kinda became a thing.  Which is nice.  Lots of little stuff keeps moving forward.
Before I put the brakes back on the 360 van.  I had to deal with a broken stud.
I drilled it and tapped it to 5/16 with a bottoming tap.
Then I drilled and tapped a short piece of a 5/16 bolt.
Then I made a stud out of a short 6mm full thread bolt.
I also made a purchase.   There will be more about the "why" behind this but it's a 2004 Yamaha Zuma 50cc.  3300 miles runs and rides excellent.
There will be no mods to this right now.  I will register it and ride it some.  It's purpose will be revealed.  It is not part of a future project.  It's just a random scooter.   But I already really enjoy it.
nocones
nocones PowerDork
9/13/24 2:08 p.m.
I've put about 150 miles on the Zuma already.  I really like this thing.  I am able to ride it to work on a mix of low traffic country roads and <35mph roads door to door, so the ~40mph top speed doesn't bother me much.  If I take the same route by car it's about 30 minutes, and the Zuma is 38 minutes.   I will trade 8 minutes for the fun of scooting.   This may stay around for a while.. or get turned into a GROM in spring..
That is all.
maschinenbau
maschinenbau PowerDork
9/13/24 4:14 p.m.
All these cars and youre riding a scooter to work?? ...sounds kinda awesome tbh. I guess get it while it's nice weather out.
nocones
nocones PowerDork
12/2/24 2:31 p.m.
Long time no update.
It took me an unusually long time to get the Van brakes assembled.   No pictures but imagine reassembling small weird drum brakes.   The brakes mostly work and the van is now for sale.
I was thinking about the Panhard and kept going back and forth between Miata subframes, P71 chassis gasser build and selling it.  But after some thinking using a full Miata chassis came in with a steel chair and I acquired the donor for that.  It is much more Miata then I was planning on but when cheap car becomes available you jump.   The Panhard will move to a new thread.
Panh-iata Dyna Zoom-Zoom
And I accidentally bought a 2003 Tundra.
When I picked up the Miata the guy with the Miata had this tundra that had been sitting on the side of the street with a dead battery for  like 9 months.  It is pretty well rust free and not perfect, but the frame is pretty solid.  Some rust but many years of service left.  A battery change and it checked out, drove nice, started without oil smoke, didn't make weird noises and the trans shifts tight, 4x4 works, etc.  I will roll the dice on it for a under challenge money price.
Also the Willy's went and picked up the Christmas tree.  I think it's the trucks favorite activity.
TurboFource
TurboFource Dork
12/2/24 4:27 p.m.
"started without oil" ?
nocones
nocones PowerDork
12/2/24 5:08 p.m.
In reply to TurboFource :
Lol edited.  Started without oil smoke.
TurboFource
TurboFource Dork
12/2/24 7:43 p.m.
Thank goodness!
nocones
nocones PowerDork
12/19/24 1:45 p.m.
Man this thread is CRAZY.  The Panhard project is now dead.  It's being returned to it's previous owner who has big plans for it.  I guess on reflection I didn't really dig that one and any roadblock was sufficient to quit.
But as documented in that thread I purchased a $500 transmissionless Miata as a chassis donor for the Panhard that I IMMEDIATELY destroyed.  Info full on Kart mode.
Look at that thing.  But it's relatively low mile and rust free.  So what do I do with it.   Now a sane person would sell it.
But .  I want to do the challenge again this year.
Also as was discussed in the Panhard thread I was trying to cram two potential project wants (a family capable cruiser, and a Quick just for fun lower effort project) into one.  It makes sense to just do the low effort project, and use the Miata as the base.
Obviously the Miata could easily be turned into a "death kart" but those are so passe at this point.   So I thought about alternative "bodyswaps" that would be fun for the challenge.   But typical bodyswaps are a lot of work.  More than I want for a "throw away" project.  I want something low enough effort that I would part with it post challenge.
And then I remembered the idea that was supposed to be the 2023 PLB before we realized how wrecked that car was.
Enter the Miata ManX-5.  I had briefly explored putting a Manx clone body on a unaltered wheelbase Miata and thanks to the Library of Congress a quality Manx CAD model exists and it..  mostly works.
So I decided that's the idea for this chassis.   I needed a Manx Clone though.  I asked around a bit and PSteav has one he regrets buying in his garden.
It's perfect because it's just the body, there is basically no way the hood will work so I'll cobble something.  I'm planning to use a MG Midget windshield that I have kicking around the garage.
ROUGH mock-up of the MG windshield shows that it just might work.
Also the cutoff MG roll bar will probably be welded in.
I'll know more once the body arrives which should happen over Christmas break.  Assuming initial attempts with the body are successful I'll probably start a thread for this one.
Should be fun.  Worst case it doesn't work and I've not ruined the Miata any more then I already did .  .  Right?
E78vNayywZrjmhww5gYJLAQgscxRIcbExTiEWKWhfcM12yj4f1isTWvb3SDLoQ2d
