Norma66-Brent
Norma66-Brent HalfDork
12/18/21 1:58 p.m.
In reply to ZOO (Forum Supporter) :
Thank you. Still got a ways to go to make it a reliable driver that I don't need to be sweating as I'm driving it.
NOHOME MegaDork
12/18/21 2:11 p.m.
In reply to Norma66-Brent :
I very valid point when speaking of project cars and "Done".
Norma66-Brent
12/18/21 2:11 p.m.
Things that need done, starting from the back of the car.
-drop gas tank and redo pickup height for fuel pump
-get a bigger fuel filter
-redo wiring for fuel pump
-build parking brake system
-Neutral safety wiring
-reverse lights wiring
-seat belts
 -exhaust bolts sealent
-redo large -8 line fire power steering
-clearance exhaust to bellhousing
-Rebuild steering gear
-redo fuel line to allow air cleaner to sit down
-maybe vacuum Assist pump
Norma66-Brent
12/24/21 6:35 p.m.
did a little Christmas Eve shoot today on this 38 Buick. Customer didn't want a full resto so we didn't remove any of the trim. The roof on this one was crushed down about 18 inches from a building falling on it. Gonna be real cool. Gonna shoot the other half on Monday.
Norma66-Brent
12/30/21 10:26 p.m.
getting closer. Having to mix it in after normal collision is done for the day. Should put a big hurt on the rest of the work tomrorow.
Norma66-Brent
1/5/22 12:47 p.m.
all done. Ready to get some space back!
Norma66-Brent
1/12/22 1:30 p.m.
Just got confirmation. My dealer is getting one ford lighting. Just finished putting in my order and finalizing configuration. Should see it late July.
Norma66-Brent
1/20/22 9:19 p.m.
Pulled the cover off Norma today. It was -22 here today. Spring can't come soon enough
Norma66-Brent
1/28/22 9:04 p.m.
Anyone have a good recommendation on sealant for water jacketed exhaust ports? Need something that is going to hold up to heat.
Norma66-Brent
1/31/22 9:10 p.m.
Bump
Dusterbd13-michael
Dusterbd13-michael MegaDork
2/1/22 5:43 a.m.
Ive used the permatex white paste stuff on big block mopar before.
Norma66-Brent
2/12/22 10:20 p.m.
it was zero degrees here today. Spring needs to hurry up
stuart in mn
stuart in mn MegaDork
2/12/22 11:30 p.m.
Looks like she's all ready to go.
Supposed to get down to -7F here tonight, but we are on the downhill side of winter.
Norma66-Brent
2/14/22 9:12 p.m.
Norma went to the exhaust shop today. Pumped to hear that big block with actual exhaust
tperkins
tperkins New Reader
2/18/22 12:35 p.m.
Very nice! I kind of sort of have a 4 door slant 6 Mercury Comet around the same year ish I hope to do something with sometime.
Kind-of-sort-of meaning its just parked at our place and landlord said I could have it lol.  You probably know more about it than me.
TurnerX19
TurnerX19 UltraDork
2/18/22 1:34 p.m.
In reply to tperkins :
Please do not call that a slant six. It is bolt upright, and you will hurt its feeling with the Mopar reference.
Norma66-Brent
2/18/22 1:35 p.m.
2/18/22 2:58 p.m.
Nice!
Azryael
Azryael HalfDork
2/18/22 3:48 p.m.
As much as I'd like a 4-door for the convenience of having people get in and out, I'd be more than happy with a running 2-door that can make some long trips if needed (maybe that's asking for trouble, lol).
That thing sounds AMAZING.
tperkins
tperkins New Reader
2/18/22 4:10 p.m.
Thought I might hurt some feelings lol
Pretty sure that car is the least desirable it could be.
Norma66-Brent
3/16/22 9:03 p.m.
just did a thing. I'm gonna be in trouble
10001110101
10001110101 New Reader
3/16/22 10:24 p.m.
Are you keeping the Galaxie, or replacing it with the Elky? Either way, great thread and I can't wait to see what you do with it.
Norma66-Brent
3/17/22 8:00 p.m.
Galaxie is staying this is a fill project for the shop. See how it turns out. It's in Florida I'm in Iowa. Need to figure that out
Norma66-Brent
3/19/22 4:05 p.m.
pulled the steering gear this morning. It's worn out. Seal rebuild kits incoming.
went to go address the water jacketed exhaust ports and ran into a HUGE problem. Went to retorque the heads and intake. Been through a few heat cycles at this point and it's time. First head bolt was at 20ft/lb when it started spinning crying. Stands and rockers need to come off at this point and potentially the heads. Berk, Berk, Berk
(supposed to be at 80ft/lb)
Norma66-Brent
3/23/22 9:38 p.m.
Had a buddy come out and confirmed we should pull the heads and inspect everything. While we are in there we will inspect lifters and make sure everything survived break in.
tg9uEr26KnAb1hijoIs7BYRZkghI6ZpRy5nL2ZuRN5Y0XxVDDAYuB5NSenl6AzAb
