Chris_Heideman
Chris_Heideman New Reader
7/26/23 6:15 p.m.
Well, it has been quite a busy past month, and I figure it is about time to update this thread. Over the past month I have competed in the CRX in both the Peru, and Chicago SCCA Solo Tour's, and have trophied at both, my first national trophies! I also went to the Time Trial National Tour at Gingerman this past weekend and was able to pull out the Touring 5 win by a little under 2 seconds. However, with the car being run so much, it is not without difficulties, granted, the main issues has not been that serious.
I have had strange starting issues with the car, and after this past weekend on track the car would misfire right when it was started up, and the headlights would flicker on and off. It seemed like a poor connection somewhere in the wiring, and was not surprised to find that was the issue. The power for the car was spliced to the 12 volt power to the starter, and the connections were quite poor.
This was the wiring pulled out of the car. I then got a separate cable that runs straight from the battery to the starter, and have the main power for the rest of the car going straight to the battery as well, and that seemed to cure the strange electrical issues.
In addition, while preparing for this upcoming weekend's SCCA Solo Finger lakes tour, I noticed that all of the bolts for the lower side of the intake manifold support bracket were missing. So I used some of our miata spare fasteners to put it back together.
How I found the bracket with the car in the air. (Ignore the oil everywhere, I did a sloppy job cleaning up after an oil change)
Finally, some upgrades have been put onto the car. I am currently planning on running Solo Nationals with a co driver. My co driver has been an EF chassis guru for years, so he had some go fast parts lying around. We decided to put a Willwood brake kit on the car, as it cuts around 12 pounds of unsprung mass from the car.
Everything the kit included
Weight of the factory brakes with Hawk ER-1 pads. (per corner)
Weight of the Willwood kit (per side)
Some safety wire practice, I ended up re-doing this rotor after the photo was taken.
The whole kit on the car.
After putting the brake kit on the car, I put the car on some random wheels we had lying around while I got a fresh set of tires mounted on my 6UL's, however, once I went to put the 6UL's back on the car, they did not fit over the rotors. I was praying I would not have to switch back to the factory brakes two days before I left for the event, and was able to find some 5mm 4 x 100 spacers, and that seemed to remedy the problem.
I put tape on the outside of the fenders, and then promptly went to an empty parking lot near by and cornered as hard as I could in an attempt to see if there would be fitment issues with the tires and fenders. It seemed as if there was no issue, however I do plan on bringing a fender roller, and the factory brakes to Finger Lakes this weekend just in case.
Chris_Heideman
9/10/23 9:47 p.m.
Well, with Solo Nationals coming and going this past week, I figure it's appropriate to update this thread. The main goal with this car was to have something that was already almost all of the way there in regards to prep, in an attempt to trophy at Solo Nationals. Well, I am pleased to say that I was able to trophy this year at Nationals.
A couple weeks before nationals there was a misfire that needed addressing, which was cured by cleaning various grounds on the car, and it also needed a clutch. The clutch that came out of it had lots of life left on it, however it was clear that it had been overheated. It started to slip really badly off launches and between the 1-2 shift right after the start of an autocross course. Although it probably only had ~2000 miles on it, due to all of the abuse from constant launches and a couple track days it decided to let go.
Photo of the clutch that came out of the car.
Nationals this year was quite an experience. This was the first time that I found I had the mental game right for it. I just did my runs, and tried not to think about results too much (although constantly looking at them after every car finished), and it worked. After day 1 I was in 8th place in STS, and was able to secure 6th after day 2. My fast runs can be found below from both courses.
East Course
https://www.youtube.com/watch?v=9oRbENFMeks
West Course
https://www.youtube.com/watch?v=QZzndKQrDTw
greasemonkeyreborne_5x1gs
greasemonkeyreborne_5x1gs New Reader
11/10/23 7:23 p.m.
Good catch!   And in the off season.
jfryjfry
jfryjfry UltraDork
11/27/23 12:43 p.m.
Why didn't you weld around all the subframe where it meets the body vs just the spot welds?
or maybe you did and I can't tell!
fQql9WPjfIkuZXcau8DG9zUY5xSLaVfYPDcRWGWLuh8v5NQXa37kDo9UoDQsWWu7
