Matt_the_Wolfe
Matt_the_Wolfe New Reader
8/17/16 4:51 p.m.
Hey all, first time poster, long time reader.
Finally decided to take the time to introduce our team's RallyCross project to the GRM masses.
Meet Edna the Escort!
Long story short, we picked up this little gem from a local salvage yard about a year and a half ago and have been diligently turning her into a dirt-based cone carver ever since.
I've reserved a couple spots below to run down the car's full back-story.
We're a team based out of SE Michigan and run with the Detroit Region SCCA, though we will be running the car at RallyCross Nationals this year as well as some events in Ohio. We also do ice racing with this car when old man winter turns our home into a frozen tundra.
You can visit our Team's Facey-space page here and see all of our ongoing projects, including our 2003 Mazdaspeed Protege Super Touring build
Matt_the_Wolfe
8/17/16 4:51 p.m.
The backstory of how we ended up with this Escort;
A little over a year and a half ago, my buddy Kiefer and I started participating in some local Detroit Region SCCA RallyCrosses with his daily driver Protégé 5. The car was actually pretty competitive in the Stock FWD class, but it was pretty rusty and since it was Kiefer’s only form of transportation we figured it wouldn’t be wise to keep beating it to death in the dirt.
We had kicked around a couple different ideas for a dedicated RallyCross car, and one of the ones I had mentioned was the Escort GT. My reasoning was that they were cheap, light, durable, parts were plentiful, and the GT version was furnished with Mazda’s wonderful 1.8 DOHC BP engine. We’d made some half-hearted craigslist searches for cars, but never came across anything we were seriously interested in. That is until Kiefer went to one of our local pick & pull yards to find a less-rusty hood for his P5…
The particular pick & pull franchise has three different locations and all of them keep a couple complete cars sitting on the lot for purchase that are too nice to be crushed. On this particular day, Kiefer walked into the lot and was greeted by this abnormally clean example of an Escort GT. The car looked complete and surprisingly didn’t have most its body panels missing (in SE Michigan that’s a very rare find). More importantly, it was an honest to goodness EGT with the all-important manual transmission. Kiefer gave me a call to let me know what he had found so I ambled down there to examine it more closely.
We were told that it had come in on a hook and that it needed an alternator and an engine mount. What the employees at the salvage yard didn’t tell us was that the alternator had been removed and that it was dangling behind the engine on top of the jackshaft. What they also didn’t tell us was that the front motor mount bracket was sheared in half. We gave the car a quick once-over and determined that the chassis was clean enough for RallyCross duty. It wasn’t a rusty pile, but it would definitely need some love down the road.
Thinking that this car might actually be worth putting some time and money into if we could get it running, we decided to return the next day with tools, a spare battery, and a lot of hope. Since it was in a salvage yard and Escorts are about as common as belly buttons in the pick & pulls around here, we figured it would be worth a shot to see if we could find a replacement alternator and the engine mount bracket we needed. After a few minutes of bumbling around we hit a gold-mine; another manual transmission EGT with a brand new remanufactured alternator on it!
We set to work tearing off anything we thought might be useful off the car and a little while later we had our new alternator, engine mount bracket, some nifty OE Escort mud flaps, and a couple other odds/ends. We took our treasures back to install them on the new car and immediately discovered why the alternator was sitting on top of the jack-shaft; there was not much room to drop it out of the car with the shaft still in the trans.
Not wanting to pop the shaft out, we decided that since the engine was already partially disconnected from the car, a little help from an engine crane could free up some space to get the alternator out. After a bit of juggling and grunting, Kiefer was successful in pulling the dead alternator out of the car, though he did get a bit stuck under the car. Luckily, I was able to grab him by the ankles and pull his 150 lb arse out from under it.
While he messed around getting the new alternator on, I got the new engine mount bracket installed and make sure that everything else on the powertrain side was good to go. The car seemed to have been reasonable well taken care of for most its life, but had recently fallen on hard times (I.e. the top end of the motor was actually pretty clean, but the oil that was in it was about as black as midnight in a coal mine). We must have been pretty entertaining to watch because half of the salvage yard employees and even some customers were watching us work on this thing.
With a new (to us) alternator installed, the motor properly mounted, and a fresh battery, we were ready to see if there was life on planet Escort. We got the keys, cranked the motor with the fuel injector relay pulled to make sure it built up oil pressure, and then crossed our fingers when we fired it up for real.
Success! The car fired right up, didn’t make any nasty noises, and actually ran quite well. We couldn’t take it on the road, but were able to take it around a part of the lot for a short test-pound. We determined that it stopped (eventually), steered, and well…worked remarkably like a car. We took it back to its spot, made the lot an offer, and after signing two checks totaling $1300 we had ourselves a RallyCross car. They didn’t even charge us for the parts we used to get the car running.
We couldn’t drive it home that day because it was a Sunday and the paperwork couldn’t be completed, so we came back the next day to drive it home. We knew the car wasn’t exactly 100%, but we figured it was good enough to make to 20 min drive home. I was the lucky one who got to drive it back. The first thing I discovered about the car is that we hadn’t figured out was that the shift linkage was in pretty poor shape. This is very common with the BG platform Mazda’s/Ford’s as the linkage can rust out and, when it’s in really bad shape, drop through the floor. So finding gears in this thing was an experience. The next thing I figured out was that the blower motor wasn’t working. This was problematic for 2 reasons; one was that it was October in Michigan, so it was more than a bit chilly out. The other was that I had no front defroster, and the windshield was very foggy with only my body heat in the car. The last thing I figured out was that the brakes we a bit on the weak side. They stopped the car, but you had to apply a fair amount of pressure to get them to really grab.
Despite the car’s foibles, the journey home was actually pretty smooth. Once we got it there, we immediately set to work on improving what obviously needed attention. It got an oil/filter change, we swapped the transmission fluid, did some general cleanup, and started diagnosing some of the cars issues. Upon inspecting the HVAC system, we found that the bower motor resistor pack was completely fried. One trip to O’Reallys and $15 later (god bless econoboxes), we had a working blower motor again. We even discovered that the A/C worked!
All in all we were pretty satisfied with our purchase, but we were about to discover some interesting secrets hiding under the car’s somewhat sparkly exterior.
Matt_the_Wolfe
8/17/16 4:52 p.m.
Reserved
Matt_the_Wolfe
8/17/16 4:52 p.m.
Reserved
irish44j
irish44j UltimaDork
8/18/16 5:04 p.m.
Nice But your pictures don't work ;)
irish44j
irish44j UltimaDork
8/18/16 5:06 p.m.
Btw, if you're able to find him, look up Jim Kelly who used to run with Washington DC region. He used to dominate stock front and then mod front with basically that exact same car (eventually turned it into a stage car and IIRC destroyed it). In any case, I recall he had quite a few budget-oriented tricks in that thing.
Here it is the last time I saw it a couple years ago at STPR
EvanB
EvanB UltimaDork
8/18/16 5:40 p.m.
Matt_the_Wolfe
8/19/16 8:53 a.m.
In reply to irish44j:
Thanks for the reminder! I had seen/heard of that car before but couldn't remember the guys name. Any idea what a good wat to get in touch with him might be?
Matt_the_Wolfe
8/19/16 8:54 a.m.
In reply to EvanB:
Another one of my favorite pics! I believe that's from the 2-day Great Lakes Divisional
EvanB
EvanB UltimaDork
8/19/16 8:55 a.m.
In reply to Matt_the_Wolfe:
Yep, I figured this thread could use some pictures.
Are you coming down to our 2 day event on the 27-28th?
Matt_the_Wolfe
8/19/16 9:59 a.m.
In reply to EvanB:
Up in the air right now. Car's ready, but we may just save it for Nats.
BTW; what's the best method you've found to post photos to this stinking forum? Apparently Google Drive and Dropbox are no bueno
EvanB
EvanB UltimaDork
8/19/16 10:25 a.m.
I posted the above one from facebook (if it is set as public it will work). Just right click on image in facebook and open in new tab then copy the image address.
Otherwise you will have to host it on a site like photobucket, picasa etc and then copy the link into the photo link box.
Matt_the_Wolfe
8/19/16 12:42 p.m.
In reply to EvanB:
Thanks! That did the trick. Makes it super easy to post as well. What's the status on your car these days?
EvanB
EvanB UltimaDork
8/19/16 1:23 p.m.
Took some beating in MD at the Eastern Championship, I haven't driven it much since. I need to go through it this weekend and fix some little stuff in preparation for the 2 day and then nationals. It looks like I'll likely be driving it out to Nationals, good thing it isn't in August this year and shouldn't be too hot.
irish44j
irish44j UltimaDork
8/19/16 3:24 p.m.
Matt_the_Wolfe wrote: In reply to irish44j: Thanks for the reminder! I had seen/heard of that car before but couldn't remember the guys name. Any idea what a good wat to get in touch with him might be?
I'll see if I can look him up and let you know.
Matt_the_Wolfe
8/19/16 3:53 p.m.
EvanB wrote: In reply to Matt_the_Wolfe: Took some beating in MD at the Eastern Championship, I haven't driven it much since. I need to go through it this weekend and fix some little stuff in preparation for the 2 day and then nationals. It looks like I'll likely be driving it out to Nationals, good thing it isn't in August this year and shouldn't be too hot.
We went through ours yesterday and pronouced it good to go, then our event got cancelled due to rain
We're in the waffle-house on coming down for the 2-day. We'd like to save the car for Nats, but it looks like too much fun to miss.
Luckily we have a truck and trailer so we'll be enjoying the A/C if it decides to be hot in September for Nats. The Escort actually used to have A/C, but that crapped out last year at I-96 and we've never bothered to diag. why
Knurled
Knurled MegaDork
8/19/16 7:30 p.m.
Doooood! Awesome to see you here. Come down to the 2-day next week, the site we have tucked away in the hills of south-central Ohio kicks ass. Which reminds me, I got word that the car I will be driving is fixed so I should prereg...
  • That guy who done broke the drain plug off the Miata last year
Matt_the_Wolfe
8/19/16 11:08 p.m.
Knurled wrote: Doooood! Awesome to see you here. Come down to the 2-day next week, the site we have tucked away in the hills of south-central Ohio kicks ass. Which reminds me, I got word that the car I will be driving is fixed so I should prereg... - That guy who done broke the drain plug off the Miata last year
Man you're like the 3rd or 4th person to say that, LOL. Maybe we should have come on here a long time ago. Yeah I'm heavily considering it, it just sounds like way too much fun to miss but at the same time its money and time that I could use to put into the road racing car so I can actually get that thing on track at some point this year. Decisions decisions...
Matt_the_Wolfe
8/29/16 2:53 p.m.
Updated with part 1 on how we acquired our salvage-yard special
irish44j
irish44j UltimaDork
8/29/16 6:49 p.m.
skip to the 3:00 mark....some Jim Kelly escort....carnage.
https://www.youtube.com/watch?v=MLcyWaE5M8o
Matt_the_Wolfe
8/30/16 10:53 a.m.
Looks like it had a bit of an owie
dH5DI7DSBCBeT4yISCFhj0EyU3RoQ4NzCQAbERzQfvFuRz6tljQLJWWgn1c0uMtR
