TheV8Kid
TheV8Kid HalfDork
8/2/18 9:10 a.m.
Pete Gossett said:
In reply to TheV8Kid :
It’s just more time to test & tune for 2019, right?
That's something we have to decide. There are going to be a lot of opportunities between now and then. Those opportunities will involve racing others who do not limit themselves to a $2019 budget. We will definitely be there with something, it just may not be the Nova. Time will tell.
PseudoSport
PseudoSport Dork
8/2/18 2:17 p.m.
Color kind of reminds me of the F-Bomb Camaro. Looking good!
TheV8Kid
TheV8Kid HalfDork
8/3/18 6:52 a.m.
I can't tell if you are being sarcastic or not..
Thanks!
PseudoSport
PseudoSport Dork
8/3/18 9:20 a.m.
ha, I've been so focused on the fab work I completely spaced on the theme (name of thread, images posted earlier, etc...)
TheV8Kid
TheV8Kid HalfDork
8/4/18 9:07 p.m.
Lol. That's funny. I guess that means we are doing a good job!
TheV8Kid
TheV8Kid HalfDork
8/7/18 8:11 a.m.
Day 134 - June 20, 2018
Began wiring.
TheV8Kid
TheV8Kid HalfDork
8/9/18 4:50 a.m.
Day 135 - June 26, 2018
Continued wiring.
Patrick
Patrick MegaDork
8/9/18 3:48 p.m.
Fuse panel looks familiar...
TheV8Kid
TheV8Kid HalfDork
8/10/18 6:09 a.m.
In reply to Patrick :
Must be a common fuse block. We get them from the street rod show.
Patrick
Patrick MegaDork
8/10/18 7:20 a.m.
I got one for $11 listed for boats.  If it’s cheaper than where you’re getting them i’ll divulge my sources.
TheV8Kid
TheV8Kid HalfDork
8/10/18 8:12 a.m.
Nice! They're $22 at the street rod show. $11 is cheap! eBay?
TheV8Kid
TheV8Kid HalfDork
8/14/18 7:55 a.m.
Day 136 - June 27, 2018
More wiring.
TheV8Kid
TheV8Kid HalfDork
8/16/18 10:39 a.m.
Day 137 - July 1, 2018
Made hole in rear cross member to allow fuel lines and battery cable to pass through. Bent fuel line. Machined holes in intake for injectors.
bluej
bluej UberDork
8/16/18 12:31 p.m.
what's that intake? Is it meant to be a carb intake for an LS and you're adding injectors instead?
TheV8Kid
TheV8Kid HalfDork
8/16/18 2:22 p.m.
Its a Victor jr. It is meant to  put a carburetor on an LS.
It comes in two variants. They sell these with the injector bosses drilled and without. The one we had did not have the holes drilled. We plan to run a plate nitrous kit, because we have lots of parts for that.
TheV8Kid
TheV8Kid HalfDork
8/21/18 7:06 a.m.
Day 138 - June 2, 2018
Started machining intake elbow flange. Installed feed and return.
Dead_Sled
Dead_Sled Reader
8/21/18 12:54 p.m.
Did you do anything special to get a better surface finish for the injector orings or is that not really a concern?  I know we'd specify either a 63 or 32 surface finish for that hole and chamfer here at work, but we also do alot of things because "that's what we've done in the past" so it may be overkill for a static oring.  Just curious if that's a legit concern.
TheV8Kid
TheV8Kid HalfDork
8/21/18 6:37 p.m.
I wrapped a deburring tool with scotch bright and ran over each hole with the drill a couple of times. That smoothed them out pretty well.
TheV8Kid
TheV8Kid HalfDork
8/23/18 7:11 a.m.
Day 139 - July 3, 2018
Finished carburetor spacer modification.
TheV8Kid
TheV8Kid HalfDork
8/28/18 7:12 a.m.
Day 140 - July 4, 2018
Made throttle body flange.
mazdeuce - Seth
mazdeuce - Seth Mod Squad
8/28/18 7:55 a.m.
I've read a bunch about intake runner length and how that affects things, but what I haven't ever read is whether the distance from the throttle body to the start of the runners has an affect on that tuning or not. Is any of that included in what you're doing here?
wheels777
wheels777 SuperDork
8/28/18 10:17 a.m.
In reply to mazdeuce - Seth :
Plenum volume is important.....but...... this engine is EFI and will be ram air so it's less important. Plus it's going to be nitrous injected. Throttle location and plenum volume are critical on a carbureted engines.
TheV8Kid
TheV8Kid HalfDork
8/30/18 7:16 a.m.
Day 141 - July 5, 2018
Finished intake elbow. Still not completely happy with it. Mounted radiator.
TheV8Kid
TheV8Kid HalfDork
9/4/18 6:52 a.m.
Day 142 - July 7, 2018
Made IAC valve block off plug.
maschinenbau
maschinenbau Dork
9/4/18 7:45 p.m.
Love how you hollowed it out for extra lightness. That's a nice piece you should be proud of.
GL4fCCKfICSZLmfl79kzNGrrfKHmokIZPC2Qo0w9v6yIRfwbGQmA2My1odXJhwV6
