4 5 6 7
Manual_Trans
Manual_Trans Reader
12/16/24 7:32 p.m.
I encountered some interesting steering rack bushings for the truck recently. They are advertised as polyurethane with billet aluminum sleeves. The factory units consist of a steel sleeve wrapped in very soft rubber. The ones on my truck are looking a little worse for wear and these new pieces were only fifty bucks, so I gave them a shot. They arrived today and I was kind of surprised to see that the bushings themselves are actually translucent. I've never seen clear poly bushings before.
They look cool and the billet sleeves are very lightweight. I hope they function as well as they look!
I also spent some more time on my lower control arms. For those of you who haven't been following along, the tubular lower control arms that I installed, had bump stops that were mounted way too high off the arm, thus limiting my front suspension travel down to maybe two inches (and this picture was taken after I added shorter bump stops).
A few months back, I got sick of bottoming out the suspension around corners and on uneven surfaces and cut the mounts off entirely.
Without the bump stops in place, the front suspension was using the tires and inner fender lips as bump stops, which was definitely not ideal. Last night, I made an attempt to remedy the situation. I cut and ground off the last of the welds that can be seen the the picture above, so the entire area was smooth. Then I marked and drilled a hole, centered under the part of the frame where the bump stops are supposed to make contact and inserted some new conical bump stops from Energy Suspension.
It turned out really nice, but I won't know if they're tall enough until I can drive it again. If they're too short, I can always try the taller, cylindrical ones that have grooves for trimming them down shorter if needed. This picture shows the suspension drooping with no weight on it, so while it looks like a lot of travel, everything rests a whole lot closer when it's on the ground.
I'm hoping to resume my brake system overhaul this weekend, but the weather is going to be super wet for a while. So even if I get it buttoned up, I may not be able to drive it for another week or more.
Manual_Trans
Manual_Trans Reader
12/24/24 6:40 p.m.
Well that escalated quickly...
Impulse buys are so real. This is a wet kit, specific to early two-thousands Chrysler products. It should work just fine on the truck and can be easily carried over to the next motor. In order to run this even remotely safely on that tired old 4.7 I'm going to downgrade from the performance tune in my Superchips programmer, to the 87 octane base tune, but keep filling the tank with 92 octane fuel. The performance tune adds too much timing (so I'm told) and probably won't play nice with the nitrous. The 87 tune is still a ten horse improvement over stock and maintains the secondary features like speedo calibration and raised limits. I'm also going to install a pair of wideband gauges to monitor things when spraying. Innovate makes some nice ones that will work perfectly for my application.
Ideally, I'd install some sort of timing retard window switch, but MSD is the only company I know that does that without a full standalone, and they don't make a single box that will work on my truck. As far as I can tell, I'd have to run two DIS-4 boxes simultaneously. Those things retail for $900 each, so that's a hard pass for me. The Terminator-X system that I'm going to purchase for the Hemi swap will control all of those things, so there's really no need to add all the extra junk under the hood at this point.
I'm planning to start out with a 50 shot and monitor everything to see how it looks and sounds. If it behaves, I'll bump it up incrementally to a 100 shot, which was my original goal for this motor. If this one pops, it'll only motivate me to get started on the Hemi swap sooner.
Stealthtercel
Stealthtercel SuperDork
12/24/24 6:46 p.m.
This is my nomination for today's Spirit of GRM Award, if there is such a thing.
Manual_Trans
Manual_Trans Reader
12/26/24 10:05 p.m.
I need to be able to monitor my air/fuel ratios to run the spray. Having a nitrous pressure gauge inside would be handy as well. This lead me down a very, very deep rabbit hole. I am super picky about my gauges and dash lights matching during the day and at night. I also don't like gauge pods hanging off of A-pillars or stuck on the dash in ways that couldn't pass for OEM. This really narrows my options for gauges and mounting locations. In typical form for this build, I've decided to make my own solution. I'm going to mount the gauges where the stereo normally sits. There's a great product called a "Ghost Box" that plugs into the factory stereo wiring harness and hides in the dash. It's basically just a Bluetooth receiver that plays music directly from your phone like a standard Bluetooth stereo would, but it stays completely out of sight. It weighs less than a pound.
For the gauges, I've arrived at the one matching set to satisfy the majority of my extreme visual requirements, and that's the Sport Comp series from Autometer. They need a black face, white numbers, red/orange needles, and they absolutely must glow green. I also like the silver rings on this series and that's something I was planning to add to the factory cluster eventually. The GS series has green through-dial lighting which is the one thing I like better than the Sport Comp's edge lighting, but the GS gauges also have chrome rings. I hate chrome and do not have the patience to either meticulously sand and/or paint them a satin silver. The Sport Comps also provide me the option to change the color of these down the road if I ever tire of the green lighting.
So anyway, here's a quick, digital mockup I made for the triple Autometer gauge mounting solution:
As a second option, I could use an Innovate dual AFR gauge and a nitrous pressure gauge next to each other, which would free up space to add the arm and purge buttons. Having those next to the gauges eliminates the need to drill holes into my perfectly good dash trim to mount random rocker switches. Innovate makes some nice stuff and the gauges come with alternate faces and rings to switch out for different looks. These come with white OLED displays, which can be changed any color I choose by trimming a light gel and placing it behind the removable face panel. I've obviously opted for green here.
The second option doesn't look nearly as good as the first IMO, but it's also about $100 cheaper. I've already created the design files for both mounting plates that I can upload to SendCutSend when I'm ready. I'm planning to have it cut out of 2mm carbon sheet, which is plenty stiff for this application. I'll either use some super strong adhesive to attach it to the aftermarket head unit mount, or I'll throw in some tiny black screws around the perimeter. Those are things I'll figure out later. Right now I just need to focus on recovering from the sticker shock after seeing how much these various gauges are going to set me back. Regardless of which option I choose, they're going to cost more than I paid for the berkeleying nitrous kit. For gauges. It's insane.
Manual_Trans
Manual_Trans Reader
12/29/24 5:07 a.m.
While I was working on the truck today, a very large package showed up. Many years ago, I learned about a company called Stillen from a friend of mine who drove a 300ZX. He showed me a catalog that was full of super fun looking parts for his Z. A little while later, I learned that they actually made a front bumper cover for the second gen dakotas. I remember seeing it and thinking that it was the only aftermarket front bumper cover that I'd ever even consider putting on a truck, if I had one. It looked mean, but not gaudy. I liked it immediately.
Fast forward a couple of decades and I now have a second gen Dakota, but those Stillen bumper covers are long since out of production. Bummer. So I install an OEM style bumper cover and call it good. Except it didn't look as aggressive as I was hoping it would so I started searching for a way to make it look meaner. Then I found it. Some random seller on eBay must've purchased the remaining stock from Stillen and was selling them for a not-so-great price, but there it was. Begging me to buy one. So I did. And here it is.
Personally, I love it. And that kind of odd, lower middle section in the picture above won't be nearly as noticeable in black. I'm stoked about it and I can't wait to get it painted so I can mount it up. It's actually designed to slip over the factory cover, but I don't intend to do that because that seems silly to me. I'm going to remove the cover that's on it and mount this directly to the steel supports. The only downside to this is that I'm going to lose the mounting provisions for the factory fog lights. I do have a plan to make lemonade out of that situation, but I'm getting ahead of myself.
Manual_Trans
Manual_Trans Reader
1/6/25 3:03 a.m.
More progress was made tonight. The Wilwood master was finally put into place for what is hopefully the last time. I bent and reused the factory stainless hardline to the front brakes, but the short line from the ABS module to the proportioning valve had to be made from scratch. I purchased some bulk copper nickle brake line and bent it up appropriately. It was during this process that I realized that I kind of hate cutting and flaring hard lines. But I digress...
On to the brake hoses. I ordered some custom braided stainless hoses a while back. I made sure all the fittings and lengths were the same as the factory hoses. The one thing that I had put off until now was figuring out how to replicate the bracket that was built into the front brake hoses. There's actually a section of hard line that's permanently attached to them and keeps the rather long hoses from contacting any of the suspension or brakes. I could have just put some p-clamps directly onto the control arm, but I didn't like any of the angles or the fact that I'd have to drill at least one hole into the arm itself.
I took some thick aluminum flat stock and cut it to the same length as the steel factory brackets, added a matching bend, drilled three holes, then inserted a rivnut into the outermost hole, like this:
I then reused the factory bolts for the rear holes and added a fresh bolt to the front hole, added two p-clips, and ended up with this (ignore the brake fluid mess; I didn't clean it up before snapping pictures):
You'll notice that I pointed the rear clip upward instead of down, like the factory mount. That was for two reasons. First, there was a clearance issue when pointed down, that caused the hose to rub on the control arm and two, pointing it upward helped to reduce a little bit of slack in the line behind the rotor, as it dips around the bottom of the caliper. I have a plan to maybe add another tab to the back of the knuckle, under one of the mounting bolts, where I can add a third p-clip to ensure the hose never steps out of line and rubs on anything. Not sure if it's needed, but it might make me feel better.  Overall, I think it turned out quite nice.
Manual_Trans
Manual_Trans Reader
1/6/25 3:15 a.m.
I also spent a few days messing with a tiny interior detail that I'm pretty sure no one else will ever notice unless I point it out to them. Back when I painted the pillars black to match the new headliner, I removed the little sliding pieces of plastic behind the B pillars that move up and down when adjusting the seat belt height. I did this because the paint would never survive the friction of sliding up and down constantly, and having those bright colored strips would have been an eyesore. This is what I've been staring at for about a year:
I decided to cut some strips of carbon fiber that I had laying around, into the same exact size and shape of the original plastic inserts, then drilled a big hole for the bolt. I also touched up the paint in a couple of high wear spots.
All reassembled and they now look like this:
Ultimately, this is probably wasted effort, but it makes me happier knowing they exist. ADHD can be quite challenging at times, but it also provides the drive to put insane amounts of effort into tiny details that not many others would even notice. For better or worse.
Manual_Trans
Manual_Trans Reader
1/8/25 8:03 p.m.
If you've read a few of my posts, you know that I've been using SendCutSend for custom bracketry and even some aesthetic pieces. I've been wanting to have them make me some carbon fiber pieces, but their pricing on carbon is downright unreasonable. Plus they only offer matte finish and I've been told their cuts aren't very clean. This is fine for structural parts, but I want interior parts to look a lot nicer. I found a company in Vancouver BC called CNC Madness, that cuts carbon fiber, so I sent them my design files and asked for a quote. They quoted me 1/6th the price of SendCutSend for the exact same part, so I ordered two of them and some extra pieces. It all came out to less than one of the parts from SCS and I received them in less than a week. This brings me back to my new center gauge setup.
A few posts back, I shared some mockup images of various custom gauges that would go into the area where my stereo mounts. I wanted these before I could install my nitrous setup. I loved the aesthetic of the triple gauge setup, but I didn't love the cost of the three Autometer gauges. I really liked the functionality of the Innovate gauges; I could get a double wideband readout on one gauge and then a matching nitrous pressure gauge that could go with it. They were more than $100 cheaper than the Autometer gauges and they offered custom warning light options as well as data-logging capabilities. Leaving the third gauge spot open meant that I have a clean spot to mount the nitrous arming and purge buttons. Here was my final mockup before I ordered everything:
The gauge panel(s) showed up today and it's perfect. Twill weave, gloss finish, and smooth cuts all around.
The Innovate gauges also showed up today. I swapped the black rings for silver, flipped the black faces over so they're plain (instead of having white and yellow-orange writing all over them), and added a piece of green lighting gel under the faces so that they will light up green instead of white (because OCD). I bought a third silver ring to mount over the far left hole so it maintains the triple-gauge appearance. The buttons and LED "armed" light will mount to another piece of carbon fiber, behind the third ring.
For the buttons, I found some really clean looking ones on Amazon, of all places, that are billet aluminum, anodized black, and they glow green when powered up. The power button is a latch style for arming the system and the plain button is a momentary switch for the purge. The little red LED will be wired so that it's on when the system is armed. I tried to hold them up to the ring and backing plate to make sure my mockup measurements were good, but I accidentally held the LED on top, instead of under the buttons like I intended. I didn't want to take another picture, but in person I was able to see pretty clearly that everything will fit as intended. The photo is misleading because the buttons are standing closer to the camera than the trim ring, making it look like they're wider than they are.
Once I finally wrap up this brake system redo, I'm going to hop onto the nitrous kit installation. I'm really excited to play with it.
Manual_Trans
Manual_Trans Reader
1/18/25 5:49 p.m.
I didn't feel comfortable with a nitrous bottle sitting in my bed, uncovered for the world to see, so I started looking for options to hide it. Ideally, I'd mount it under the bed somewhere, but I don't have the time or materials to fab up a completely custom solution for that. I toyed with the idea of adding a low-profile, locking toolbox in the bed, but that added a considerable amount of cost and weight. My third option was a tonneau cover.
I have a love-hate relationship with tonneau covers. I prefer hard covers, but I hate the tupperware lid look of the ones that cover the entire bed and fold down around the top. They also tend to be incredibly expensive and a major pain in the ass to remove if you ever need to do so. And heavy! On my last truck, I had a nearly perfect, flush-fit, hard tonneau cover that was made by a company called Checkmate, but that company no longer exists. I don't love soft covers in general, but unfortunately, the only cover I could find that was as close to flush as possible, lightweight, and relatively affordable, was a soft one.
It's called the "Vanish" and it's made by ACI. I gave it a shot. I installed it myself in not much time and it fit well. I had to use some spacers to raise the rear latch in order to clear the front lip of the tailgate spoiler, but other than that... it fits nicely.
It has adjustable tensioners at the front that I can use to pull it tighter if I want. I'm going to let it sit and stretch a little more and then give them another spin or two. It has two hollow aluminum cross-bars that keep the whole thing from flapping or losing its shape at speed. It only sticks up about half an inch over the edges of the bed, which is acceptable for now.
It locks in the closed position, which is mostly wishful thinking when it comes to a single layer of vinyl with velcro along the edges. Thus my dislike for soft covers. But whatever...
Manual_Trans
Manual_Trans Reader
2/12/25 3:23 a.m.
I've been really busy lately, but I did have some time to make a little progress on the truck the other night. The front brake hoses are installed with their new brackets that I created, and the Wilwood master is fully installed and plumbed with new hard lines that I had to make. I discovered that I really, really dislike cutting, bending, and flaring brake lines. Once the rear hoses are finished, I hope I don't have to do any more brake lines for a long time.
My front wheel well liners were pretty messed up. A previous owner cut them up in a couple of places (no clue as to why) and my brief time driving it without bump stops had caused some friction damage. I ordered some OEM-style knock-offs to replace them. For whatever reason, only the passenger liner had an aluminum heat shield on it, but not the driver's side. The factory liners were like this as well. They're the same exact distance from the exhaust manifolds, so it never made sense to me to only shield one side. I decided to remove the cheap looking aluminum piece and replaced it with some of the woven titanium heat shield material that I had left over from my CAI build. I also added some heat shielding to the driver's side liner, so they matched. Here's one of them before I installed it:
I discovered that getting a decent photograph these things installed is kind of impossible. This is the best I could do. You can see it down there, just above the valve cover.
From under the truck, it all looks a lot cleaner now. I painted parts of the frame that I could safely get to, without having to worry about overspray. The stock, tired, upper control arms' days are numbered. I have a plan to replace them with custom adjustable units in the near future. They will also solve that ugly upper ball joint angle.
The liner is only partially installed in that pic, but you get the idea. Instead of reusing the nasty, partial collection of mismatched plastic plugs to hold the new liners in place, I installed rivnuts into all of the stock mounting holes. The liners will be screwed in with black, flanged, button-head, M5 screws this time, for a more secure and tidy appearance. I didn't fully install the liners because I'm going to need to pull them back out when I install the new bumper cover. I dropped it off at the body shop today to get painted. Once I get that back (hopefully next week), I'm going pull the front bumper assembly off, clean the hell out of the brackets, repaint them, and then put it all back together with new hardware. The new cover was designed to be slipped over the factory bumper cover, but I have no plans to actually do that. The factory-style cover is being removed and I will install that new cover onto the brackets underneath, even if I have to make some modifications.
Manual_Trans
Manual_Trans Reader
2/24/25 3:11 a.m.
I've always thought the old hot rodders trick of drilling "speed holes" into their cars to reduce weight was kind of a fun idea. Since I was mounting the new bumper cover directly to the factory support beam, I wanted to give this a shot to see how much weight would actually be removed by drilling a few big holes. The main beam is fairly thick steel, so I thought it was a great place to cut out some weight. I didn't want to go overboard and Swiss cheese the whole thing because I still needed some flat surfaces to apply double-sided tape for the cover. There were already a few small holes in it, so I took a bunch of measurements, made a couple of templates to ensure everything was aligned (even though no one will see these), and ended up drilling six 2.5" holes and twelve 2" holes along the leading edge of the main beam. I then de-burred them, sanded and painted the entire assembly, then reattached it with some new stainless bolts.
Now for the big reveal. What was the total weight reduction from all of this effort?
21 ounces (or just under a pound and a half)... not much!
There were a lot of smaller spots where I could have drilled additional holes and I could have drilled larger holes in some places too, but it doesn't really matter in the end. It was a fun experiment and it was free. I'm hoping to have the new cover mounted by tomorrow. It's been giving me headaches because it was designed to slip over the factory cover, but I refuse to do that because it's a stupid idea. If I'm going to drill this much metal off of an unseen bracket to shed 21 ounces, then I'm certainly not willing to immediately stick an extra 5 pounds of plastic over the top of it. The audacity!
Manual_Trans
Manual_Trans Reader
3/3/25 2:54 a.m.
Okay, so first off, the new cover is finally on and I think it looks pretty great.
Much more aggressive than the factory cover. More fitting for the truck. I need to modify/adjust the fog light brackets to get them aligned with the new holes and then I'll reinstall those. I'm also toying with some brake duct ideas, but that will take a whole lot more fab work and time.
Since I'm going to be removing the stereo, which has my phone mount built into it, I purchased a nice looking mount to take its place. It's made entirely out of machined aluminum and it has a carbon fiber section in the middle, so it matches the interior theme nicely. I also added a Broadway mirror because it's a common JDM thing (on theme with the build) and I've always wanted a convex rear view. I can see out the entire rear window of the truck now, without having to lean or tilt my head. It's so nice! I can't wait to try it out on the road.
After finishing all the work with the new master cylinder, braided hoses, custom hard lines, and high-temp fluid, the brakes are now incredibly spongy. Like, pedal to the floor soft. Not good. I suspect there is still a bunch of air trapped in the ABS unit, which is a common issue when the system is run dry. I've bled it as much as I can and I even bought a scan tool that is supposed to activate the ABS to evacuate the trapped air, but it won't work for some reason. It keeps giving me an error message, which is incredibly frustrating.
Rather than researching and purchasing another, even more expensive scan tool just to get the ABS unit to bleed properly (or taking it to a shop so they can attempt to mansplain my own creation to me in order to upsell a bunch of E36 M3, because that's what they like to do to women), I've decided to just delete the damn thing. It only works on the rear brakes anyway, so it's not even a great setup. If it was a true 4-wheel ABS system, I'd be much more willing to save it, but this is no longer worth the trouble to me. I'm deleting the ABS unit under the hood and routing the rear brake line directly to the prop valve on the new master. I'm over it.
budget_bandit
budget_bandit HalfDork
3/3/25 10:06 a.m.
In reply to Manual_Trans :
i'm not an ABS apologist, but you might be able to save yourself some trouble and get the ABS to purge by slamming on your brakes on a gravel road a couple times
spitfirebill
spitfirebill MegaDork
3/3/25 10:15 a.m.
Today is the first time I have come across your build.  I never seem to visit this page.  The truck looks great.  I am amazed at how much you get done so quickly.  Well done.  Ahhh to be young again.
golfduke
golfduke SuperDork
3/3/25 10:50 a.m.
Maybe I missed this part in the thread, but I'm curious as to why you're removing the stereo?
3/3/25 11:09 a.m.
Follow this with another round of bleeding, to get rid of any air that has been relocated from the ABS valve into the tubes downstream.
Manual_Trans
Manual_Trans Reader
3/3/25 12:16 p.m.
Thanks! And "young" is a relative term, I suppose. I'll be forty-three next month. I feel half that in my brain, but my body likes to remind me otherwise on a regular basis.
Manual_Trans
Manual_Trans Reader
3/3/25 12:23 p.m.
In reply to golfduke :
I'm going to install a custom gauge panel in its place to house the wideband and bottle pressure gauges, as well as the switches for the nitrous system that I have waiting to go in. I bought a bluetooth device called a Ghost Box that will plug into the stereo harness and hide inside the dash, so I can still listen to music if I want.
rdcyclist
rdcyclist Dork
3/3/25 1:12 p.m.
Exactly so. I'm 68 and my brain regularly thinks we're half that and starts writing checks the body can't cash...
Manual_Trans
Manual_Trans Reader
4/16/25 6:17 p.m.
I finally managed to get the sytem all put back together and had one of my teenage kids pump the brake pedal for me to ensure all of the bubbles are truly out of the system. The pedal felt nice and firm and the brakes seemed to be working, so I took it for a spin. Unfortunately, while the pedal is no longer spongy or soft, the brakes don't seem to want to grab at all. It feels like the pads are greasy or something. I didn't touch the pads or rotors throughout this entire process, so I'm not sure what the issue is. I sprayed everything down with some brake cleaner and let it sit overnight.
My next step is going to be to remove the master cylinder and use a push rod measuring tool to make sure that the rod is adjusted to the correct length. I don't notice any delay in the braking from when the pedal is pushed, but I read recently that any preload on the push rod inside the master can cause some issues. I honestly should have done this when I first installed it, but it was my first time fitting a custom master cylinder and I had no idea it was even a thing. I just eyeballed the rod until it looked to be about the correct length to just barely make contact with the receiving end of the rod in the master.
Other issues included the ABS and BRAKE lights constantly lit up and the speedometer not working. I expected the lights since I deleted the rear wheel ABS, but the speedometer thing confused me at first. After some quick research, I learned that the speedometer circuit is routed through the ABS module, as part of an integrated wheel speed/ABS system. I really didn't want to re-mount that heavy ABS module to the inner fender, so I dissected it to see if I could keep only the electronics and not the heavy hydraulic parts. Here's what I removed:
I plugged what was left of the assembly back into the harness and then restarted the truck. All the lights were off and I'm pretty confident that the speedometer will be functional again as well.
The rear looks like this:
I'm going to seal the back of this up and then re-mount it somewhere in the vicinity, using either a custom bracket or some sort of creative but secure zip tie maneuvers. I'm hoping that this little "brain" remaining plugged in will keep the rest of the system happy for the time being. I still need to figure out why the brakes feel like E36 M3. I'm hoping a push rod adjustment will magically solve everything, but I'm not feeling particularly optimistic about that being the true issue here. I will receive the measuring tool tomorrow, so I'll find out soon if that's the case.
Manual_Trans
Manual_Trans Reader
4/17/25 2:29 a.m.
Okay, so I took it for another drive tonight and I paid extra attention to the pedal feel and engagement. I do believe I detect a very slight delay in the push rod contact when I press the brake pedal. I think the rod needs to be extended outward a few millimeters from the booster to properly engage the master. This might also explain why the brakes never feel like they're clamping at full force; I don't think the push rod inside the master cylinder is being fully engaged. This gives me hope that utilizing the push rod measuring tool might actually solve this issue for me. Fingers crossed!
Also, it looks like spring has finally arrived here in the PNW, so I took some low-light evening pictures while I was out. They're not great, but whatever. The truck still looks good.
I guess the fog lights are mounted too deep into the new front bumper cover. They're actually shining onto the ground from behind it, which creates a weird visual effect. At some point down the road, I'll have to figure out how to space those outward an inch or so. Speaking of the fog lights, I added some old school race car Xs to them because I thought it would look cool. The lenses are composite, so it's 100% an aesthetic thing, unlike the old glass sealed-beams of yore. Also, instead of using solid tape, I cut the Xs out of some tint film in order to retain more usable light. I'm not sure it really makes a difference, but I like how they turned out.
Here you can see the new hood pins that I added. I really didn't want to add hood pins, but they're required in a lot of track settings, so I decided to get it over with. I completely eliminated the factory latch system altogether, which freed up a bit of space and dropped another few pounds off the nose. I was originally going to get some AeroCatch pins, but I liked the simplicity of these ones. They're made by Quick-Latch. They're black, they're smooth, they lock, and they only required a round, 32mm hole, instead of the larger tear-drop-shaped hole that the AeroCatch units require. This was not my first hood pin installation on a carbon hood, however it was by far the most challenging hood pin installation that I've ever experienced. First off, the hood rounds downward on the edges, which makes it really hard to get an even measurement from side to side, unlike the mostly flat hoods that I usually deal with. In addition to that, the core support and the under-hood skeleton structure are both asymmetrical, providing zero even reference points for me to accurately measure where to drill the holes. It was an immensely stressful process. Drilling holes in a $1500 body panel was also terrifying. But... it's done. The hood stays firmly closed and the pins are evenly spaced. Mission accomplished.
Manual_Trans
Manual_Trans Reader
4/18/25 2:43 a.m.
Well the tool showed up and I did indeed need to adjust the rod, but not the in the direction I was hoping. It was actually a few millimeters too long, so I adjusted it down to where it was supposed to be and reinstalled the master cylinder.
Needless to say, this did not solve my weak brake issue, so I'm going to bleed all four corners again tomorrow. I have a suspicion that there's just more air trapped in the system somewhere that I haven't eliminated yet. It was basically run dry while everything was disassembled and I've replaced almost everything that holds fluid. There is a single factory hard line that runs from the front frame rail, back to the rear end that remains in place, but that's basically it. It makes sense to me that I just haven't worked out all of the bubbles yet; there are a lot of places for them to hide. The pedal felt a tiny bit soft today too, so I'm going to keep bleeding until it's right.
Just to double-check my work, I verified that the bore of the Wilwood master is the same exact measurement as the factory master, so that's not the issue here. I don't see any leaks anywhere from front to back, either. It has to be air in the lines somewhere. I'm determined to figure this out.
akylekoz
akylekoz UberDork
4/18/25 7:10 a.m.
Surface tension of fluids can help keep bubbles trapped.  Putting new calipers on my daughters Escalade, we had to smack them with a rubber hammer between bleeds to get all the bubbles out.  I'm not a hammer mechanic, but, a nice whack with soft faced hammer to all components can free up some stuck bubbles.
Still loving this build, especially the small details, they are what separates a good from a great final product.  Ha! final, they are never done.
Manual_Trans
Manual_Trans Reader
4/18/25 3:45 p.m.
In reply to akylekoz :
Thank you! The details are everything and it makes me so happy every time another gearhead notices and appreciates them. And yeah... I'm not sure this will ever be considered "done". I'm not working with a SEMA builder's budget or shop, so it's going to continue to be an evolving project.
I do own a rubber mallet and I have used it to tap the calipers before. I will certainly do it again tonight, at all four corners. I'm actually planning to lift the entire truck off the ground at once so I can move from corner to corner quickly and bleed them all without needing to move jack stands or remount the wheels. I will do plenty of tapping with the mallet and I may even go all the way around more than once. It can't hurt and I have plenty of fluid. I am determined to get this sorted. There is a really cool, eclectic cars & coffee tomorrow morning that I've been unable to attend for months. The truck always gets a great response when I bring it. People have actually been messaging me and asking when I'm coming back, so I really want to make it safely tomorrow.
4/18/25 4:13 p.m.
If it's still got drum brakes on the rear, make sure they are properly adjusted (should drag very lightly). It is surprising how much brake pedal movement can be lost to improperly adjusted drum shoes.
4 5 6 7
FS5KNgCXJoZtjjvnbCMEdqWpk0Wl8ooC9NXloVYDAltDSjXChdzcg2C5Aso5ZMDR
