3 4 5 6 7
Ben_Modified
Ben_Modified Reader
2/5/17 5:21 p.m.
Cage is mostly done and all of the temp supports are out
Part 5 on YouTube
<img src="20170204_164236_resized" /> <img src="20170205_112442_resized" /> <img src="20170205_112508_resized" />
BenModified.com
Ben_Modified
Ben_Modified Reader
2/7/17 6:20 p.m.
After searching unsuccessfully for an R1 engine, I finally moved forward and installed the cbr600 engine instead
<img src="20170206_152511_resized" />
Plenty of leg room for the driver and a sufficient amount for the passenger.
<img src="20170206_152656_resized" />
As soon as I got it into place I ran across this for sale.
<img src="20170207_140242_resized" />
A well worn but good running 2001 Yamaha R1. 150hp (cbr was 100) with much better dimensions for the Autobianchi. It will allow more passenger room and has a much better output shaft placement and will also give me more ground clearance.
BenModified.com
CLynn85
CLynn85 HalfDork
2/7/17 7:52 p.m.
Ben_Modified wrote: After searching unsuccessfully for an R1 engine, I finally moved forward and installed the cbr600 engine instead As soon as I got it into place I ran across this for sale. <img src="20170207_140242_resized" /> A well worn but good running 2001 Yamaha R1. 150hp (cbr was 100) with much better dimensions for the Autobianchi. It will allow more passenger room and has a much better output shaft placement and will also give me more ground clearance. BenModified.com
HATE when that happens...
JamesMcD
JamesMcD SuperDork
2/7/17 8:41 p.m.
Excellent!
Indy-Guy
Indy-Guy Dork
2/7/17 9:14 p.m.
Ben_Modified wrote: After searching unsuccessfully for an R1 engine, I finally moved forward and installed the cbr600 engine instead <img src="20170206_152511_resized" /> Plenty of leg room for the driver and a sufficient amount for the passenger.
Now I understand why you went right hand drive.....
Ben_Modified
Ben_Modified Reader
3/22/17 6:39 p.m.
Now that the 3 Day Caffeine and Octane show is over,
<img src="20170317_101512_resized" />
I can get back to work on the Autobianchi. Removed the cbr600 engine today to make room for the R1 engine
<img src="20170322_152547_resized" />
The engine is ready to come out of the R1
<img src="20170322_164758_resized" />
BenModified.com
Ben_Modified
Ben_Modified Reader
3/24/17 5:46 a.m.
<img src="20170323_162434_resized" />
JGRAHAM
JGRAHAM New Reader
3/24/17 6:11 a.m.
Beautiful work! It's an inspiration!
Ben_Modified
Ben_Modified Reader
3/24/17 5:00 p.m.
JGRAHAM wrote: Beautiful work! It's an inspiration!
Thanks! Made some progress mounting the R1 engine today
<img src="20170324_160647_resized" />
BenModified.com
Ben_Modified
Ben_Modified Reader
3/25/17 11:50 a.m.
Driveshaft is done. The slip joint is to allow for the rubber mounted engine.
<img src="20170325_101213_resized" /> <img src="20170325_102254_resized" />
BenModified.com
Ben_Modified
Ben_Modified Reader
3/27/17 6:26 p.m.
Engine is properly positioned. Driveshaft is bolted in and engine mounts are coming together
<img src="20170327_170951_resized" /> <img src="20170327_174837_resized" />
BenModified.com
Ben_Modified
Ben_Modified Reader
3/28/17 6:03 p.m.
Finished all the motor mounts
<img src="20170328_150534_resized" /> <img src="20170328_150518_resized" /> <img src="20170328_150502_resized" />
Also cut up the original R1 header and started reconfiguring it to fit the car
<img src="20170328_175558_resized" />
BenModified.com
crankwalk
crankwalk Dork
3/28/17 7:11 p.m.
YES!
Ben_Modified
Ben_Modified Reader
3/29/17 5:58 p.m.
MulletTruck
MulletTruck Reader
3/29/17 7:03 p.m.
I know I am late to the party but if you are unhappy with the lack of torque of the R1, the best car engine I have used so far is from a Suzuki Bandit 1250. I have done Hayabusa engines in Buggys with good success too.
Look into Turbo headers for the R1, you may find they are what you are looking for.
Lof8
Lof8 HalfDork
3/29/17 7:03 p.m.
Man, this thing is going to be wild! What are you going to do with it when it's complete? Autocross, just play around, something else? Will it be street legal?
Ben_Modified
Ben_Modified Reader
3/29/17 8:40 p.m.
MulletTruck wrote: I know I am late to the party but if you are unhappy with the lack of torque of the R1, the best car engine I have used so far is from a Suzuki Bandit 1250. I have done Hayabusa engines in Buggys with good success too. Look into Turbo headers for the R1, you may find they are what you are looking for.
I will. Thanks for the suggestions!
Ben_Modified
Ben_Modified Reader
3/29/17 8:43 p.m.
Lof8 wrote: Man, this thing is going to be wild! What are you going to do with it when it's complete? Autocross, just play around, something else? Will it be street legal?
Yes, it is street legal. Mostly for fun. The closest autocross is about an hour away and not very often, but I will have to make it there!
Ben_Modified
Ben_Modified Reader
4/1/17 5:43 a.m.
After using a large crowbar to lever the engine against the rubber mounts, I find that the rubber gives a lot less than expected. Meaning that the u-joint angles under load do not decrease as much as expected, so I remounted the engine for more desirable angles
<img src="20170331_114940_resized" />
<img src="20170331_114955_resized" />
BenModified.com
Ben_Modified
Ben_Modified Reader
4/7/17 8:02 p.m.
Header is done <img src="20170405_175118_resized" /> <img src="20170405_181244_resized" /> BenModified.com
Ben_Modified
Ben_Modified Reader
4/8/17 6:57 p.m.
Fabricated and installed the sequential shifter today using an automatic trans cable and the original, now modified, motorcycle foot shifter
<img src="20170408_171640_resized" /> <img src="20170408_171816_resized" />
BenModified.com
Ben_Modified
Ben_Modified Reader
4/9/17 8:53 p.m.
Pete Gossett
Pete Gossett UltimaDork
4/9/17 9:24 p.m.
Nice!
DaewooOfDeath
DaewooOfDeath SuperDork
4/10/17 12:10 a.m.
Can't believe I didn't see this before. Incredible work.
Ben_Modified
Ben_Modified Reader
4/10/17 5:15 p.m.
DaewooOfDeath wrote: Can't believe I didn't see this before. Incredible work.
Pete Gossett wrote: Nice!
Thanks! Welding on the shifter is done. Just needs a few passes with a fine grit flap wheel. Weighs only ounces! <img src="20170410_174635_resized" />
BenModified.com
3 4 5 6 7
GeEsyTnKo3dItGzXCLJjdjddDDcI7KDlhj90KbneeZkB5G8JRQDHIghJgMKg9ERL
