Warning! This post will be full of cool pics of sexy suspension components! Not suitable for children or those who are considering buying new suspension.
As I mentioned before, the plan was to use the old KW V3s (great suspension!) for a while to get the car up and running, and then buy some "real suspension" later on. Yeah screw that.
I called up TC Design, a local race shop well-known for their very fast very winning cars, and said "I have an E36, I'm building it for NASA ST4, I'll have this aero and these tires". A few weeks later I showed up with a (large) envelope of cash and picked up a set of components that I never really thought I'd own. For me this is the stuff of dreams.
MCS 2 way remote reservoir dampers with true rear coilover, Eibach springs, Ground Control race camber plates
'95 M3 knuckles (96+ would've been preferred for their higher KPI, but these will be fine for now) with Ground Control bump steer kit and a custom TC Design roll center correction kit.
A WHOLE BOX OF GOOIDIES! Ground Control adjustment tie rod ends, Ground Control monoball RTABs and FCABs, and a variety of OEM joints and bushings. I was almost weeping at this point.
Brand new 96+ LCA with modified outer ball joint. There's a slight geometry difference between the 95s and 96+ LCA, which affects caster.
From what I remember: 95 M3 and non-M LCA, combined with offset FCABs, yield the same caster that 96+ LCA and a centered FCAB do. More caster is more gooder here. In my case, I'll be running the 96+ LCA and an offset FCAB, for all the casters.
Another look at the knuckles.
A whole workbench full of new suspension parts. I've been a car guy for a long time, and this was really a huge moment for me. I never thought I'd be in a position to be able to own parts like this. A huge thank you to Tony and Joe at TC Design for answering my infinite questions and helping me along the way.
Also dug some old-but-unused CondorSpeedShop polycarbonate side windows out of storage. These include a NACA duct cutout on either side, which I later decided I didn't like and made my own windows (...and then changed my mind again and decided I wanted the ducting).
This is my workshop, almost all of it. Prepped for battle, about to start installing and refreshing suspension components. It isn't a ton of space but I make it work! Its also very messy most of the time lol.
First up, rear trailing arms. These needed new RTABs, wheel bearings, and upper and lower joints. My dad and I bought a HF 12 ton press a few years ago to do subframe bushings on my wagon- it doesn't get used much but when you need it, there's nothing that can replace it. It was invaluable for the next few steps. O'Reilly's tool rental is also super helpful, I have a wheel bearing press kit from HF, and that combined with a variety of kits from O'Reilly made this go somewhat smoothly.
If you don't have a hydraulic press and are doing jobs like this, buy one. If you don't have the means to and are in the Bay Area, message me and you can borrow mine!
Some parts of these would've been much easier with two people, just to help balance parts. Here I'm pressing out old wheel bearings.
Rear trailing arm explosion!! I got both of them stripped down to clean up and paint before installing any new parts. Never reinstall dirty parts!!!!! Ever!!!!!!
For those following along at home: its currently the end of November in this picture. The goal is to have the car driving by the end of the year.
The hard part of getting a lot of these bushings out is just finding the right combinations of dies and receivers. Are those the right terms? You know what I mean. This is a rear upper control arm, I'm pressing out the outer bushing. I'm using a 23mm socket to press, and using some black pipe fittings as a receiver. A few times I just brought parts down to OSH and went through various pipe fittings and found things that'd work. This turned out well, but I ended up basically destroying that threaded fitting.
A closer view of what's going on here. This is "grassroots", right? That means no judgement, right? :)
Rear suspension components are torn down! You're looking at two rear trailing arms and two upper control arms. The uppers double as spring carriers, which are moot for me now as I'm using a true rear coilover. The lower control arms were junked and are being replaced with some nice Bimmerworld race adjustable LCA.
RTA prepped for paint. This doesn't need to be perfect, just better than it was. Wire wheel for any nasty spots, wiped down with acetone, and paint.
Parts being painted in my high end custom paint shop, AKA on a piece of cardboard in my backyard.
mmm shiny! I used Rustoleum High Performance Enamel for all the components. Comes in a big can, sprays nice, and is very durable. Stays tacky for a while so let it dry for a day or so before attempting to really handle the parts.
Knuckles are given the same treatment
Here I will give you a tutorial on assembling a knuckle for a 1995 M3. This is also applicable for 1992-1999 non-M models and 96+ M3s.
First step: lay out all your parts.
Second step: put the parts together.
Easy! Let me know if there are questions and I can walk you through the steps again.
This is really the part of the project where things got more expensive than I had planned. The suspension was big money, and doing things like all new wheel bearings aren't cheap either. At this point I realized that I need to do it right the first time, and not hack it together over years like the last car.
Moving on to rear trailing arm assembly. This is tricky, so make sure you follow each step carefully.
First, lay out your parts.
Second: assemble those parts, and a bunch of parts that weren't in the first picture.
Easy!!
It felt good to get these jobs done. For the longest time I thought I just didn't have the skills to do it, but here's something I learned a lot during this build: you shouldn't tell yourself you can't do something until you try it. I just started on the job, and it went relatively smoothly! A few things had to come in and out a few times, antiseize went everywhere, the basics. If I had to, I could do all of this again in probably less than half the time.
These old Powerflex FCABs were a pain in the butt to get out. I probably should've used the press but didn't for some reason.
New hotness! Here you can see the offset nature of the bushings. These are fully servicable and rebuildable joints.
If anyone wants more info on how I put together my incredibly insightful tutorials:
WOW SHINY!!
Need to find a good spot for these reservoirs. I end up just zip tieing them to the core support. Not great...but it works.
I don't remember what was happening here or why I pulled the steering rack out but it looks stressful.
Rear suspension going in.
Looks good from this angle, even with the blurry pic! The subframe and diff were taken from the orange car. The subframe and RSB mounts have been reinforced previously, and there are AKG 75D poly mounts everywhere. I didn't bother changing those out, they looked and feel fine.
The diff is a 3.91 LSD that I rebuilt a few years ago, with a 3 clutch upgrade. Poor man's supercharger! I painted it red for extra horsepower.
Next job: brakes! I rebuilt the stock M3 calipers. Cleaned up, new stainless pistons, new seals, brass caliper guides, new stainless braided lines.
PFC08 pads front and rear (jesus these are expensive wtf) and Zimmerman blank brake rotors.
At this point it's Christmas! I got an ultrasonic cleaner, which meant within 24 hours every small bracket and nut and bolt in the house was shiny and clean.
Before and after 10 min in the ultrasonic, without any wiping!
Magic!
I got the CAE shifter installed, which took me a while because I mounted it a lot farther back than most people do, just because my seat is so far back.
It took me a while to get the adjustable DSSR (dual shear selector rod) set to the right length.
Nice
Other things going on around this time: I got a big box of AiM harnesses, connectors, and sensors. Goddamn this stuff is cool but expensive!
I also ordered slightly too much wiring loom from ProWireUSA. At least, at the time I thought it was too much. I've used up most of this now. Another thing I learned along the way here: always order more than you need. Wiring components, materials, bolts- just always order an extra 25%. I absolutely love McMaster-Carr, and at this point there was a delivery of something arriving every few days.
So it's Christmas, and the plan was to have the car driving by the end of the year. Will he make it?? Will the car explode??? Tune in next time to find out!
