java230
java230 Dork
11/28/16 12:38 p.m.
I have been half searching for a replacement for our Ski Bum Mobile V1.0, I love the truck, but the long overhang and fiberglass construction limit me a bit. I had gotten a quote from Tri Van for an all aluminum body for an F450/550, and was keeping an eye out for cab chassis to com up cheap on CL.
Then I found this truck, Nearly the same body I had a quote for, on a 2008 F450 4x4 frame, which had been stretched 36" to allow for nearly no overhang. It was built as a chase truck for a UTV racing team. I wasn't really ready to pull the trigger for a new truck, but this was too good to pass up. Deal was struck and the truck headed to my driveway.
00v0v_6xxQZ87mlJ7_600x450
About the truck, Its on its second motor, the first owner towed horses with it, she attempted to drive it home after the CEL came on, #8 injector had failed, rod ventilated block. PO bought it, had a local shop drop a long block in and used it to go to Vegas for races a couple times. Then it sat, this is good and bad, it has ~4k miles on the new engine, but it leaks. A fair bit. Oil pan, valve covers and #6 injector seal. And the dreaded flex joints in the up pipe. Not the end of the world, but a lot of stuff to remove to get to the problem areas. It seems most procedures on these new trucks is cab off or trans out. Fun.
Everyone home in the driveway, I need a bigger driveway for this many large trucks...
20161127_155754
The box is a bare shell.The cabover is 4' tall. Very high interior roof. First order of business is the roof, two vents were framed in, and covered over with plywood and Plexiglas. They leak. So two Maxxfans were ordered and have arrived!
20161123_113657
Maxxfans and sealant, first of many parts deliveries.
20161127_162410
The back is insulated barn doors. They will be staying. One will be for exterior storage, the other can be opened to the end of the bed if its used in summer. Four 6V 250Ah AGM batteries can be seen here too.
20161123_113752
Design Condensed version of our current layout. I think it works pretty well. Toilet will just have a curtain, leave a bit more space at the door. Cabover bed for the kiddo, back bed for us, fixed dinette. Counter space is limited, but will have a fold out over the crawl through, and is across from the dinette table that can be used as well. Small bar sink, three burner RV cooktop, and the space below used for a marine fridge. Exterior storage for skis, other tall stuff at the back. Still debating on propane tank placement, I am thinking two BBQ style tanks on a swing out on the drivers rear.
RV 3
RV 2
RV 1
Plans
First order of business is getting the crawl through, windows and doors framed and cut. The crawl through is going to be a challenge, I have some thinking and blue taping to do still, but it should be doable. Accordion seal will be used there. If anyone has done this I am all ears.
Once the framing is done I will have the entire thing spray foamed. I am still debating on ceiling thickness if anyone has input. Walls will be 1 3/4" foam with 1/4" plywood interior skin. Spray foam will be a big $$ item, but I fell it will be worth it in the long run.
Then its on to interior finishes. Dinette and vertical walls I am thinking will be small steel tubing with a thin plywood skin. Maximizes interior spaces of the compartments that way.
I am leaning towards doing EGR and DPF delete stuff to the engine while I am in there, but it adds a good budget hit. It may be a couple years down the road. Lift is a ways off too, but for most of what we do it should be ok for awhile. FS roads and snow/ice covered roads to ski areas. It has brand new tires that I wouldn't mind using up either.
This will be a very slow build. I am very budget limited, so it will be plugging away a bit at a time as budget allows. I will need to sell the RV come spring, and would like to have this one done shortly after, but I think that may be a lofty goal.
SyntheticBlinkerFluid
11/28/16 1:06 p.m.
Glad to see you got the truck. Sucks about all the oil leaks on a new motor, but at least it's all fixable. Hopefully that 6.4 doesn't give you any issues.
I dig your plans. Will be watching to see your progress.
java230
java230 Dork
11/28/16 1:23 p.m.
In reply to SyntheticBlinkerFluid:
Thanks, Yeah sucks, but maybe the bolts didn't get torqued or need a retorque after a few heat cycles. Ill try it on the oil pan after a good washing. Im afraid its cab off for oil pan gaskets, or at least motor mounts and engine lifted... The dealer wanted big money for that but not the VC gaskets....
I hope it treats me well too!
golfduke
golfduke HalfDork
11/28/16 1:32 p.m.
nice score! Much more 'utility' than a run of the mill Class C.
11/28/16 2:06 p.m.
In reply to java230:
I will say, even though that engine has 4k on it, I'd do a coolant flush on it and make sure it's fresh, just for piece of mind. That's one of the biggest issues on the EGR cooler, until you can do the delete.
java230
java230 Dork
11/28/16 2:18 p.m.
In reply to golfduke:
Thanks! Thats the idea
Ill look into it, it looks pinky fresh. Those are some HUGE coolers, my god. The Delete isnt too much $$, just gotta do it at some point I guess. DPF, tuner and EGR stuff is ~$800.
java230
java230 Dork
11/29/16 9:12 p.m.
A little progress today. Light goes fast after work these days!
hmmmm leaking roof "vent" 20161129_160747
Pull off plywood, scrub with MEK 20161129_160947
MaxxFan shroud, covered in sticky stuff. 20161129_163002
Roof hole #1 done! Only broke one screw off. Stupid stainless. 20161129_163305
Run_Away
Run_Away HalfDork
11/29/16 10:14 p.m.
Neat! So how does all that engine work happen on a truck like this? Does the box have to come off, then the cab?
java230
java230 Dork
11/29/16 10:17 p.m.
Run_Away wrote: Neat! So how does all that engine work happen on a truck like this? Does the box have to come off, then the cab?
I sure hope not!! There are a few things that that would have to be the case for.
A lot of the things the dealer says are "cab off" i have found a lot of DIY write ups that make it do able, just tight working areas.
java230
java230 Dork
12/1/16 10:11 a.m.
More small progress. Climbed under, with tarp this time (i managed to park on the non gravel, ie mud section of my driveway), to investigate oil leaks. Headlamp, UV light and torque wrench in hand.
Oil pan bolts are to torque spec (9.5 ft lbs, really?!) but are dripping from the heads around the back of the pan, front looks dry, that makes me thing its seeping past the bolts/threads, but could be running down from above. I just don't see it getting to the heads of the bolts.
Valve cover area on passenger side is wet and running down the block, may be valve cover gaskets, may just be the glow plug harness on that side (DUMB design). Likely both though. Still determining if I want to tackle those or farm it out.
Stripped the interior down. I was getting a bit of water at the back edge of the cabover, need to find it. I had a suspect in mind.
20161130_212548
Marker lights were the suspect, and sure enough, you can see the tel tale dribble line coming out the bottom. (there may still be a little coming in from the gutter-body joint, but that is TBD)
20161130_212351
Passenger side is better, but still a little drip.
20161130_212433
In case anyone is interested, here is how the panels clip together and form the ribs.
20161130_212631
java230
java230 Dork
12/5/16 11:02 a.m.
Brown Santa has been leaving me lots of goodies.
12/3 SJTW for the 12V circuits. I could buy 100' extension cord cheaper than the wire, go figure. Made in the USA too.
14/2 Anchor Marine Tinned cooper wire for the 12V circuits, 250' roll, also Made in the USA.
Also got a switch panel and the interior lights I will be using.
I only had an hour or so, but I started on the cab.
20161204_113511
Stripped the back wall.
2016-12-05_08-43-36
I knew there were some mice at some point as I found some turds under the back seat.... But they made a home in the middle seat belt housing. No fresh, but stinky mouse pee. Somehow they seemed to have made it above the headliner too... I really didn't want to pull that.
Planning for the pass through, it looks like I can unbolt and slide the box back about 6" I hope thats enough! And of course this is a glued in back window.
java230
java230 Dork
12/7/16 10:13 a.m.
Well I used the entire 250' roll of 14/2. And I still need to add a circuit for the heater and water pump.... I didnt even use it for the lighting loops (used 18/2, LED pucks)....
Two main areas for the elec, under the bed, where the batteries, inverter/charger fuse panel and breakers will live, and the end of the cabinets of the opposite side, where all the switches will be. The rest is lighting circuits, and conviniance plugs. I need to figure out a way to keep the end of the wires poking oout of the walls/ceilings where I want them, duct tape may work, but the entire inside of the box is covered with frost at the moment, its cold out...
I got some rigid insulation to start furring the ceiling down with as well!
20161206_210352
20161206_210345
20161206_210335
I got my windows ordered, that was painful, but they are custom sized double pane ones, they all open and have screens too. Found a cheap entry door on Ebay, so thats on the way too.
So I can start hacking holes in it and furring out the walls and ceiling for insulation!
SVreX
SVreX MegaDork
12/7/16 10:23 a.m.
I'd really like a truck like that for my DD...
Enjoy!
java230
java230 Dork
12/7/16 12:33 p.m.
In reply to SVreX:
Like a mobile office?
thanks, im really excited about it.
SVreX
SVreX MegaDork
12/7/16 1:37 p.m.
Well, my office and my shop are both mobile. Back seat of my truck, with a tool cap.
If I could also include my sleeping area, I could easily get my company to pony up $1000 per month in expense reimbursement (less than the hotel bills they pay now).
java230
java230 Dork
12/7/16 1:54 p.m.
In reply to SVreX:
Ah yes, it would be a GREAT mobile shop truck.
java230
java230 Dork
12/8/16 10:29 a.m.
A little more every day is the idea right?
One table saw, one sheet of 3/4 ply turned into little pieces.
20161207_122354
Got one wall almost done. It was butt berkeleying cold. The missing areas are doors/windows.
20161207_214017
jfryjfry
jfryjfry Reader
12/8/16 11:16 a.m.
Going back to your plans, if I'm reading them right, you have the left/driver's door opening and closing with the toilet in front of the right door. But don't most box trucks have the right door as the primary opening door??
java230
java230 Dork
12/8/16 12:39 p.m.
In reply to jfryjfry:
The rear doors? Yes the Right (passenger) is the primary door.
The rear doors wont be used for access. The passenger side is going to be an exterior storage compartment. The drivers will be bedroom ventilation in the summer.
The entry door is just in front of the toilet in the passenger side wall. 26x72 RV style door.
jfryjfry
jfryjfry Reader
12/8/16 10:13 p.m.
Gotcha. I interpreted it to be accessed from the drivers rear.
Nice progress!
java230
java230 Dork
12/8/16 10:39 p.m.
Thanks! Drivers rear is my bed
12/9/16 12:24 p.m.
Looking good so far.
curtis73
curtis73 PowerDork
12/9/16 12:30 p.m.
I'm loving this build. I want to do the same with a 48' tractor trailer.
java230
java230 Dork
12/9/16 6:55 p.m.
In reply to curtis73:
That would be a mansion!
Got a fair bit done today, furring strips are almost done.
Tried to Squirt spray foam into the ribs, that was a fail. It wouldn't go more than a foot or so from the hole, I don't want to drill that many holes.... It doesn't seem to expand well in a closed space. Ugh they are $$ too.
Think those spaces need to be insulated? I am trying to avoid cold bridging as much as possible.
java230
java230 Dork
12/12/16 1:25 p.m.
So I tried insulating the aluminum channels. That was a failure. The foam would only expand ~6" either side of the hole, no matter how much you tired to pump in. Im not going to put a 15/64 hole very foot.... Looks like they will remain uninsulated unless someone has a genius idea. [B]Thoughts? I am trying to avoid cold bridging. [/B]
You can see the foam puking out of the holes in a few spots here. That stuff was not cheap.
20161209_172016
Got the ceiling channels filled at least.
20161209_172025
Box of goodies is growing
20161209_172122
Battery interconnect cables. Check, CL score.
20161209_172112
Got an on demand hot water tank on Ebay, killer price, should be a nice unit, 60K btu's.
fYYxrFFXFNeBGTjgRBvMCeT4yhiCyJx0CXQAN0n2247RiZ0bH3udN8wUhaGsfRPl
