5 6 7 8
teamilluminata
teamilluminata HalfDork
11/18/21 8:25 a.m.
Committing to Front Bars
The last time we referenced the front skid plate bar was back in May when we were installing the front tow hook which is sandwiched between the chassis rail and the skid plate bar mounting flange. At that time, it was mocked up from PVC conduit. Now we felt it was time to commit it to steel and even connect it to the front bumper bar. How hard could that be?
Pretty tricky actually. We don’t have a pipe bender but have access to one but it would be a one shot deal. However, it proved difficult to make the compound bends in the same plane and end up with the bar at the correct length. When we got it back to the workshop what we had was a wrong length bar with a 90 degree bend at each end! Both bends were in the same plane but, as you will see, that didn’t matter in the end. It was a bit disappointing to be honest so we put the kettle on and had a think over some Yorkshire Tea and Hobnobs. They did the trick as by the last sip and crumb it dawned on us that we had all the right pieces, just not necessarily in the right order! If we chopped up the continuous 90 bends we could configure them in the right way and make the bar any length we wanted and we wanted it the correct length. So that’s what we did.
We even got it to “make the noise” (be level if you’re watching in black and white)
The next part of the project was to connect the skid plate bar to the bumper bar with a couple of brace bars in such a way that either bar could be removed separately. Fortunately, we had a model for this from MAT’s restoration, which we are not copying in any way shape or form, honestly.
So, we squished some pipe:
It took ages to grind the correct angle on the top but once we were happy with it we tacked the braces in place with the bars in situ:
Then a few issues revealed themselves. Firstly, the right-side brace bar interferes with the intercooler inlet pipe so that will need to be modified
But also, and more fundamentally, we couldn’t remove either bar from the car! We were perplexed for a few minutes as we had the configuration just like the MAT restoration bars but then we realized we had mounted our bars with studs and nuts and they had uses bolts! Once we removed the studs from the bumper bar flanges it fell away elegantly. We will be attaching it with bolts from now on. DUH!
So here are the two bars tacked together and removed and primed later.
We’d like to see a Norwegian Blue muscle up to these bars and try to bend them apart with its little pecker!
teamilluminata
12/8/21 9:59 a.m.
The Quattro rally cars all had a very iconic and loooong oil cooler tucked under their large, trunk mounted rear spoiler but we never wanted or needed the expensive dry sump oil system that goes with it so we are going to use a more traditional, front mounted oil cooler on this build. The stock oil cooler that came with our AAN engine is quite small, some would even say tiny, so we didn’t want to use that either.
So we had always assumed we would use something from the aftermarket but what to use and, more importantly, where to put it? We looked for some free space that would be visited by cool air and also be accessible by some oil lines. The oil system and consequently the oil cooler inlet and outlet, are on the right side of the AAN engine but there was no room there now we had relocated the alternator and added the bars for the skid plate. It seemed the only place for it would be in front of the radiator on the left side of the engine. Lots of room there but no obvious route for the lines was present. We couldn’t go round the front of the engine as that’s already full of alternators, bumper bars, intercoolers and other stuff and round the back of the engine is full of pipes, wires and steering arms. After mocking up the skid plate in cardboard (see previous blog) we thought there was possibly room to squeeze two braided stainless steel oil lines under the engine between the back of the oil pan and the front sub frame and anti-roll bar then squeeze them under the radiator to the oil cooler if, and only if, we mounted the oil cooler with the connections underneath AKA upside down.
We were skeptical of this because we were concerned that the oil would drain out once the engine was turned off and, if still hot when started again, would cause a small delay in flowing oil to the engine as it would have to fill the oil cooler first. We are not sure if this is a genuine concern but didn’t want to find out the hard way. After a short session with a tape measure, we determined that most of our oil cooler would be below the oil cooler inlet and outlet on the block and therefore oil would not drain out YAY!
So, we started mocking it all up. Cardboard was required of course. We selected a cooler from Mishimoto but built a CAD model before placing the order; you know, just in case. We also ran some stainless-steel hoses under the oil pan to test that our intended route was indeed feasible. It was. So, we broke open the piggy bank and ordered some parts. AN fittings from Finish Line Factory, said Mishimoto oil cooler and some stainless steel lines.
We were happy to be able to easily remove the OE fittings from the block and replaced them with AN adapters. We thought they might fight us but it seemed that they wanted out of there...
Then we set about mounting the (WISHIMOTO?) oil cooler. We fabbed up a bracket for the left side that bolts to the frame rail (currently with self-tappers but ultimately with rivnuts and screws of course.) For the right side we mocked up some steel angle we had lying around and attached that to the intercooler mount on the bumper bar as they were coincidentally at the same height. We’ll make a nicer aluminium version during final assembly.
We’d order some 60* and 45* AN fittings from Finish Line Factory so could figure out which ones would line up best with the oil lines. We mocked all this up than realized we should secure the lines somehow as it didn’t seem like a good idea to have them sawing their way through the skid plate or worse, the oil pan. This bracket and (of course) a rally zip tie should do the trick.
So now, if we ever get this beast finished, we can be sure our engine oil will remain chill.
teamilluminata
1/6/22 10:11 a.m.
Twice As Cool
We know we said we weren’t going to “use” a rear mounted oil cooler but we never said we weren’t going to “install” one did we? The rear oil cooler on rally Quattros is so iconic that we couldn’t not have one. There are plenty of tribute cars out there that don’t bother with this touch but we just couldn’t give up on this detail. Soon, we started to wonder if we’d made the right decision however.
We knew we didn’t have the skills to create this wondrous icon so we dragged our trunk lid complete with spoiler over to nearby Four Seasons Radiator who made our custom radiator a while back. We told them what we wanted and they came back with two quotes. They would make a fully function oil cooler for us for around $650 or a non-functional one for around $450. After mulling over the idea of spending thousands of Dollars to build a dry sump system one day we decided that the extra $650 we’d need for a functional oil cooler would seem like a pittance so we opted for the more frugal path. Yes, we ordered a purely ornamental oil cooler; a fake, a pretender. Please don’t hate us.
When we picked it up though we noticed it had AN fittings at each end. Turned out the fab guy couldn’t bring himself to make a fake oil cooler so made a functional one for the same price. We are forever in his debt. We’re still not installing a dry sump system though.
Now to slap it on. Oh, if only it were so simple. It had to be centered on the trunk. It had to be centered in the void under the spoiler. It had to have holes under the spoiler wing for the locating pins and it had to be bolted to the trunk. How hard could that be? Surprisingly actually. Getting it centered on the trunk was pretty easy and transferring that to the spoiler also not too challenging.
Although we had the locating pins marked side to side getting them located front to back was a bit more tricky. So we pulled out our 40 year old Steadtler dividers and transferred their distance from a known point on the trunk and drilled two small holes, with bated breath. They fit perfectly and we could then, for the first time, bring the spoiler down onto the trunk with the oil cooler in place.
Once the elation waned, we noticed that the gaps either side of the oil cooler header tanks and the spoiler sides were not equal. How could this be? We’d measured everything so carefully. We checked again. The oil cooler was definitely in the center of the trunk. After quite a bit of head scratching and remeasuring we came to the conclusion that the spoiler itself was not centered on the trunk. It was not out that much that we ever noticed but now, with the old cooler in place you could clearly see it was a few millimeters out. We decided that we needed to fix this but we were not willing to move the spoiler. Rather, we thought, we’d move the oil cooler, a little. Just enough so that you wouldn’t notice. It’s a fake one after all. Or not.
This left us with another problem. The mounting holes for the cooler were always going to be tight and getting a nut or screw in there would be a challenge that we’d just made easier at one end but harder at the other. We did manage but had to make a custom wrench to do it.
This just left one more task remained. Adding some isolators to the upper locating pins. We though a bit of hose would do the job so cut some to length and enlarged the holes in the spoiler till they just fit snugly. We were happy we hadn’t installed these before we found out is wasn’t actually centered.
Finally, we slapped a couple of VIBRANT stickers on the protective cardboard covers we’d made and called it a (long) day.
Hopefully our next job will be a bit simpler.
teamilluminata
1/20/22 12:16 p.m.
Did we do anything in 2021?
Oh boy, another year has gone by and we still haven’t finished this car! We have photo albums on Flickr going back as far as 2016. That’s seven albums, if you include the new one for 2022! To be fair, the 2016 album and the project itself only started in September of 2016. We actually got the car in December of 2015 but didn’t know what to do with it for quite a while. Also, in our defense, we did move into a new building after spending most of 2020 working on it in a storage unit, there was and still is a pandemic going on and the business experienced a dramatic sales growth during 2021 which sort of limited time to work on the car. So, what did we get done during 2021? Quite a lot, though not many transformational things. Perhaps that’s why it didn’t feel like a very productive year.
In January, we finally got the car established in its very own build room on its pin stands. This allowed us to work on a lot more areas of the car simultaneously and is so much nicer than the storage unit where it spent most of 2020.
Not a big leap but figuring out a throttle cable for the car was troubling us. We were very relieved when we found a way to utilize the stock Quattro cable with the AAN throttle body on the Wagner manifold. Yes, the same one Ken Block’s Quattro has!
Gotta stay cool so we refurbished the heating and vent panel and found some suitable aftermarket vents too. We also sourced a European only short center console just like the works cars used. Not seen here is the way we managed to snake the stock vent tubes behind the custom dash.
Tow Hooks - More little things but they needed doing and we figured out how. The rear is a stock RENNLINE unit whereas the front is the same but modified to exit where the works cars hook did.
While we didn’t make the actual skid plate in 2020 we did figure out how to make a mockup of the factory Kevlar plates in aluminium sheet by first making one in cardboard sheet.
At last, a biggy. Local Subaru guru (Suguru?) Scott Banes made this beautiful custom exhaust, mimicking many details of the original, except the catalytic converter of course. The rear muffler hanger took a lot of work but worth every ounce of effort and is completely over the top.
Not yet finished but our door cards are mocked up in cardboard and the door pulls figured out too. Easy to make in ABS during final assembly.
This was a biggy too. Just simple Sparco mud flaps you might say but the brackets were a lot of work and getting everything lined up and level was far more work than anticipated.
We managed to cobble together some rather period looking footrests for the navigator and driver. At one point we were measuring pictures on the computer screen and scaling them to figure out what size holes they had. We could have just bought some but we are so glad we made these now.
The front support for the skid plate was way more work than anticipated. Getting the shape and location correct from pictures was a challenge, as was making the connection tubes to the bumper bar. But we did it and now can fab up a skid plate.
A long time ago we had committed to using a high output Ford alternator and mounting it on the opposite side from where the AAN one went. This meant fabricating a custom bracket that had to be stiff enough and hold the alternator in the correct position and orientation. We think we nailed it but time will tell, hopefully soon.
More cooling stuff. This might be classed as a another “biggy”. Well the rear one is and that’s fake!. The front one is what we’ll actually be using to cool the engine oil. Once we realized we could pass oil lines under the engine we able to locate it in front of the radiator in good airflow.
We also mocked up some ¼ panel cards in ABS. These have to curve over at the top so were a little more involved that the door cards. We’ll make the final panels during final assembly.
At the end of the year, we also started to work on the rear bulkhead, which is not a small project. Unfortunately, we didn’t finish it so that’s a job for 2022. So what else is in store for this year? Well, ideally, we’ll finish the bloody thing. Hopefully we get plenty of time to do so. For this current “dry build phase we still have such large items as the entire wiring loom, electric power steering pump and lines, diff lock actuation, making the doors fit, fabbing a spare wheel holder, floor mats, finishing the dash panel and a myriad of smaller things. Then we’ll strip it all down and work on getting the body painted. Then final assembly. Maybe 2022 is the year we finally finish it! Stay tuned to find out.
teamilluminata
4/1/22 1:14 p.m.
It’s 2022. Car Is Not Finished.
We started 2022 full of enthusiasm with a clear goal for the car: finish it. Well, now it’s late March and sad to report that not a ton of progress has been made. On a brighter note it’s probably because the build is getting us so much publicity that we are overwhelmed with orders, maybe. We did go on a bit of a spending spree however. We bought some snazzy, 3D printed, reproduction fuse panels from a fellow Quattro enthusiast in Ireland. These look just like the originals but these use modern blade fuses instead.
We also picked up some seam sealer for the next big project. Hopefully to be revealed in the next update.
and an intercom and rear-view camera/mirror because some plonker stuck a bloody great real/fake/real oil cooler on the trunk lid.
Equally crucial to the project though not, apparently, worthy of photographing, we also ordered some Hella horns, a map light and a period correct, roof mounted antenna that is about 5 feel long!
The astute among you, or readers who are not bored yet, may have noticed that we are acquiring quite a lot of electrical equipment. Could we be ready for wiring? If this sparks your attention then stay tuned to find out.
teamilluminata
8/25/22 9:36 a.m.
REAR BULKHEAD
We finally installed and sealed the rear, aluminum bulkhead that we have had in and out of the car quite a few times. It’s never coming out again now though.
The bulked, supplied by TRF, is in two parts. One is essentially a parcel shelf and the other the more bulkhead-like vertical divider between the passenger compartment and the trunk, that contains the fuel tank. For this reason, we thought it was important to seal it up as much as possible. Not only that, we felt it necessary to seal all the cavities in the body that provide passageways between the two compartments. Turned out there was a lot of them so our first job was to seal them up with fire resistant expanding foam.
Then we moved on to the lower bulkhead. This piece rest against the strut brace bar of the cage which is by default totally sealed off from the trunk. For this reason, we were able to rivet the it in place, but only with a couple of rivets for now as it gets overlapped by the parcel shelf piece. The bottom edge rests up against a small flange left when TRF cut the original bulkhead out. This flange is also a hollow section sealed off from the trunk so we felt comfortable using rivets there too. The side however, rests against flanges that are not sealed off from the trunk so we used self-tapping screws along these edges so fuel could find its way through the holes in the rivets, should we be unfortunate enough to end up upside down with a damaged tank.
We sealed the sides and bottom edges with a bead of seam sealer before synching it down with the rivets and screws. We didn’t need any sealer along the top as that edge would be lapped by the parcel shelf next, with a layer of seam sealer between the two.
The parcel shelf portion was more complicated however. Apart from the front, which as mentioned overlaps the lower bulkhead, it sits on a flange left by the original bulkhead on three sides. However, these flanges are not flat so we had to build some spacers, particularly along the rear or the sheet would be deformed. We used small set screws and nuts around these areas as they were not sealed from the trunk. We could have used self-tapping screws again but we felt they might have posed a hazard to anyone reaching into the trunk with their hands so opted for the screws, spacers and nuts instead. As we were using a bead of seam sealer along the front edge, we had to test fit everything first as we knew we would only get one shot to install it. So, we ran the bead of seam sealer, lowered the plate into place, riveted it to the strut bar and then added the screws, spacers and nuts to secure it in place. This left a lot of voids under the other three edges so we filled them with more fire-resistant foam. Then we ran seam sealer around all the edges on the inside of the passenger compartment.
You might think this would complete the bulkhead project but we had one detail we really wanted to incorporate from the works cars: bracing bars on the lower bulkhead.  We had these pieces formed out of sheet aluminum and cut them at 45 degrees to form an upside down V. Then we attached them with self-tapping screws as they protrude into the trunk. We felt it was safe to use the self-tappers as they will be shielded from prying hands by the fuel tank. Yes, we checked to make sure they wouldn’t screw into that too.
759NRNG
759NRNG UberDork
8/27/22 9:03 p.m.
what a treat......after a year and a half I stumble upon this again and not to be disappointed I must say ...great work carry on
teamilluminata
12/1/22 10:03 a.m.
Securing The Hood
As we are using motorsport hood pins from Sparco we won’t be needing the OE bump stops so we also won’t be needing this bit of metal were they live. We cut them off and tidied up the area. Looks much neater and very Group B now.
Adjustable Strut Tops
We were never quite confident in the no-name strut tops that came with the car originally so we bit the bullet and order some proper adjustable versions from CompBrake in England.
But first we had to weld up the holes our previous ones required.
Front is eccentric so has camber and castor adjustment.
Rear is non-adjustable be we could have used the front ones here too.
teamilluminata
12/7/22 1:36 p.m.
As there’s no carpet anymore and the floor is pretty uneven we took another cue from the Group B cars and built what we’re calling a “heel plate”. This raises the drivers feet a bit and gives a lip for the heels to rest against. Of course we tried to copy the Group B version as much as possible. We only hope it’s in the right place!
First some Cardboard Aided Design, of course, followed by copying the shape in ally sheet.
Then the tricky bit; bending it up without a brake. The template we made helped.
And the finished article. We have a little fore and aft adjustment so it’s just on two self tappers for now.
We also installed the Sparco trunk latches. We were surprised to see the works cars put them right in the corners but we couldn’t put ours there because of the bumper brackets we’d had installed. So we put them more inboard by adapting some existing holes
teamilluminata
12/15/22 10:01 a.m.
While we were in there (the trunk) we decided to mount the battery. We selected a medium sized AGM version from Odyssey and a battery mount from Rennline. We just needed to create a platform for them to site on. There’s a spare tire sorta depression on the right side so we welded some bars across that to mount the bracket too. Looks like it belongs there.
We also got the horns mounted and the period correct roof antenna, which we won’t be needing but wanted anyway. It’s 5 feet long?
teamilluminata
2/2/23 11:20 a.m.
More Power! (steering)
We may have mentioned, some time ago now, that our engine packaging approach left us without power steering and that we planned to solve this issue by installing an electric power steering pump from a Volvo. Well we recently got around to actually installing it.
This is our pump:
And we need to install it behind the radiator which, in these cars, is off to the side of the engine not in front of it, where there is a surprising amount of room. As it’s going to sit above the left engine mount we hit upon the idea of supporting it vertically on stilts cunningly fashioned from threaded rod and bracing it off the inner fender with some sort of bracket arrangement. The pump gives a savage kick when starting and weighs quite a lot so there are some serious forces to be controlled.
We procured some OE Volvo bushings and said threaded rod and starting mocking things up.
Then we thought “This might have legs” and carried on with trying to brace it from the inner fender. At first we tried one arm that we thought we’d bolt to the fender or chassis leg.
But we soon realised the twisting forces this thing develops would easily overwhelm this so we  mocked up what might be considered more of a cradle and figured out ways to attach that to the inner fender.
This was obviously much better so we committed it to metal and forged ahead with  figuring out the attachment points.
We soon realised that our cradle would interfere with one of the oil line fittings so we cut a slot out and bridged it with a bend.
Job done. We only hope it works.
teamilluminata
3/2/23 10:19 a.m.
Light at the End of the Tunnel, or Hood...
We have been picking away at this project fairly consistently this year and we are beginning to sense the end is nigh. At least in terms of the dry build phase. If we are feeling generous, we could probably convince ourselves we that we only have two things left to do: all the wiring and all the bodywork! Plus, this stuff below.
2023 got going with a visit from Ryan Thompson, owner of TRF, one of the country's premier rally car builders and the chap that built our cage. We wanted to move the driver's seat forward and up and Ryan insisted he do the bracket welding. We did not argue with him.
Next, we thought we'd have a go at the hood pins. We'd been holding off on these as we’ve been using the slots to hold our makeshift work light so before we could begin on the pins, we had to buy a proper under hood work light.
We like speed holes. Who doesn't? So, we added some; first to the B-pillar gussets and then to the A-pillar gussets.
Next, we finally removed the ugly residue of the handbrake bracket. We drilled out all the spot welds and then welded up the hole. I wonder what we'll install on this newly flattened surface. Cup holders?
teamilluminata
3/16/23 11:42 a.m.
Radiator Shrouds!
The ancient art of ducting cold air through the radiator is shrouded in mystery. We were fresh out of mystery so we used ABS sheet instead as it's malleable and we had a lot of it lying around..
With a bit of heat and some persuaders it can actually be formed into 90 degree bends!
We were pleasantly surprised how it came out, except the top piece looked too white so we covered with a piece of faux carbon fiber film for now while we come up with a better solution..
teamilluminata
4/6/23 9:32 a.m.
We are checking things off pretty quickly lately and are starting to feel as if we might actually finish this phase of the project someday.
One major victory was getting the intake sorted. We had settled on a simple cone filter next to the turbo but were never really happy with it.
We really wanted a Group B Kevlar tube taking cold, pressurized air from the cowl but that was a bit of a stretch for us and we have a dirty great MAF to accommodate so we couldn’t just buy one.
So, we came up with a compromise. We’d build a filter box in the cowl, under the bonnet louvers where the Group B filter was and send the cold air into the passenger foot well, through a 90 bend and out into the engine bay through the firewall. Then we’d snake some 3” silicon tube to our MAF sensor. Let’s see how that went.
BFH
We used the connector off our cone filter to attach the filter housing bas to the tube coming up from the cowl.
We even managed to come up with a heat shield.
teamilluminata
5/18/23 12:58 p.m.
It’s been a little while since our last update but that doesn’t mean we haven’t been beavering away on the car. It just means we’ve been too busy to write an update. Let’s rectify that now.
We finalized our mounting system for our spare and tool kit and jack.
Then installed our intercom and Rennline fire extinguisher mount.
And then found room for one of these fancy Element fire sticks.
We even installed the co-driver’s map light!
Does it look like we are running out of things to do? Feels like it too. Don’t worry, there’s still lots to do but it does feel like we might get it into paint this year!
teamilluminata
5/25/23 8:58 a.m.
One of our favorite aspects of this build is how many friends in the local car community have helped us with it; so, you can imagine how thrilled we were when we got the opportunity to work with a personal friend on the car. The original works cars used a canvas dash pad/cover held on by snaps that was somewhat unique. Our friend Jean is a dab hand with a sewing machine and we were excited when she agreed to help us make one. We secured the appropriate snaps and period correct canvas and invited her over. We were stunned by the result.
teamilluminata
6/1/23 11:56 a.m.
In order to move the project along at a quicker pace and to implement the wiring at a much higher level than we could manage we have engaged the services of Jonathan Carlini of SportsCarTecnologies.com To build us a custom, race specification wiring harness for the project. The first part of this was the battery and power cables he built and delivered so we were very excited to get them installed, as you can imagine. First, we installed the battery wiring.
...and then we ran it through the rear firewall towards the dash mounted cut off switch.
Next, we’ll send one of these to the alternator, starter and then move on to the engine harness, dash harness and body harness.
teamilluminata
8/31/23 9:06 a.m.
PLAYING THE SLOTS
Building this car was always going to be a gamble but we had no idea how addictive it could be. And so, it was proven when we started to consider putting the screens into our bumper slots. We always thought they would need cleaning up a little but the closer we looked the worse they looked. We soon realized they were all the wrong shape and even, to some extent, in the wrong place! Oh boy; another rabbit hole. Here’s a comparison between ours (below) and a works car from back in the day.
It might not be obvious but you can see how the large, upper slots are supposed to have fillets in the corners. They are also supposed to be equi-spaced and centered about the centerline of the bumper. Ours weren’t. Even though most these will be covered by giant spotlights we just couldn’t live with it so set about fixing them. We assumed we could live with the lower, thinner slots as they were however.
Using a suitable size socket, we estimated how much radii we needed in each corner and drew a template and a buck (right term?) to shape the slots around. We thought we’d need to use fiber-glass to add the needed material but as the fillets ended up being really small, we just used reinforced body filler instead. In fact, on many of the slots we were just removing material, they were that far off. So, after hours of filling and sanding over and over we finally had our big slots perfect-ish.
Unfortunately, we then looked at the smaller side slots. They were even further out.
Check back later to see if we managed to leave the lower slots alone. (spoiler alert: we didn’t)
teamilluminata
9/21/23 9:07 a.m.
MORE SLOTS & SCREENS
At the end of our last update, we left you wondering if we could resist the temptation to adjust the lower slots on the bumper cover. Well, of course we couldn’t. They actually didn’t need much fettling. This was the worst offender and a fairly easy fix.
So, we moved on to installing the screens. We found this nice stainless-steel mesh online that looked about the right size. It came in a roll so we had to convince it to be a flat sheet again. It wasn’t welded so would easily deform from being a rectangle so we covered it with masking tape the keep the mesh at right angles.
We decided to mesh the bumper slots in two halves rather than individually. Thankfully one piece of mesh was long enough. The un-meshed slot is for the light bracket. Still taped up we manipulated it into shape before removing the masking tape.
Then we clamped it where we could and used bags of lug nuts and anything else we could find to weight the mesh down so it would stay flush with the bumper while the glue set.
It worked very well.
Inspired with how the mesh screens turned out in the bumper we looked at the hood slots next. They were a mess too, not surprisingly.
So we set to work with the filler and files again.
Once perfect we made individual patterns from cardboard and transferred them to taped mesh once again.
We used the same method of clamping and weighing while we glued the screen down and were very pleased with the result.
teamilluminata
1/11/24 2:21 p.m.
TEAM ILLUMINATA MOTORSPORT 2023 FLEET REVIEW
83 QUATTRO RALLY BUILD: https://teamilluminata.com/blogs/quattro-rally-build
We are closing in on finishing the dry build phase of this project. Once we get the wiring done, we can disassemble the car and prep the shell for paint. Hi-lights this year include, power steering pump mount, hood pins, A-pillar gussets, handbrake lever delete, radiator ducting, cold air intake, spare tire, intercom, fire extinguishers, map light, dash cover, power wiring and the bumper and hood slot mesh.
84 911 RALLY CAR: https://teamilluminata.com/blogs/84-porsche-911
Not a lot of work on the 911 rally car this year but we got to drive it quite a bit. The year started out with some new wheels and tires as we upped our game with tire width. Then we replaced the front anti roll bar bushings and fixed an oil leak. We took the car to plenty of cars and coffee events but the standouts were our attendance at the Woodward Dream Show at M1 Concourse with around 15 other rally cars as part of the Woodward Rally Cars (WRC) Group. We were also invited back to the American Speed Festival at M1 where we demonstrated the car’s track capabilities and the Empire Hill climb again. Not a bad year for the little car that can.
85 QUATTRO: https://teamilluminata.com/blogs/85-ur-quattro
This year we got to drive and show the 85 Quattro a few times. We are still chasing some minor drivability issues and the passenger side window regulator is awaiting its third fix attempt but we can now enjoy the car. We got it fully detailed, paint corrected and ceramic coated at Auto Europe early in the year and it has never been cleaner. We really enjoyed showing the car at the DeutscheMarques show at the Gilmore Museum and a concours in Northville as well as numerous cars and coffee events.
89 944 TURBO: https://teamilluminata.com/blogs/89-944-turbo
Early in the year we got a new addition to the fleet. A 1989 Porsche 944 Turbo (951) fully built race car and all its spares. We are not sure what we’ll do with this one yet or how it will fit into our marketing plans but it does look good in the showroom. As it’s not even close to being street legal we haven’t driven it much but we did shake it down at a local autocross in the summer where, despite its wide Hoosier R7 tires, it performed very well and was very easy to drive. The only real mechanical work we have performed on the car is to give it some proper BRAID wheels and more autocross and track day friendly tires. Hopefully we’ll have some opportunities to get this beast out on a track during 2024 so we can see what it can really do in the environment it was built for.
2005 CAYENNE (TIMSYBERIA): https://teamilluminata.com/blogs/timsyberia
The Timsyberia Cayenne continues to fulfill its daily driver and TSD rally roles admirably while keeping us on our toes mechanically. No Cayenne nightmares have appeared and it has never let us down but we have had to fix a small oil leak, and replace the hatch struts during 2023. We gave it some 17” BRAID wheels and Blizzak winter tires recently and some rust protection from Krown as it’s just so clean. We took the car up the actual Sno*rift rally and also used the car to discover Northern Michigan’s trails on two separate occasions. We also participated in the Son of Sno*Drift TSD rally in what passes for winter these days. We were entered for the Press On Regardless TSD rally in the Fall but a back injury saw us withdraw a couple of days before. We’ll be back to conquer that one in 2024 however.
2015 SPRINTER (RALIVAN): https://teamilluminata.com/blogs/ralivan2
Of all our vehicles that actually drive this might me the one we’ve used the least this year. About the only proper road trip we’ve used it for was when we dragged our 911 up to the Empire Hill Climb again. Before we could do that, we had to address the cooling issues it had exhibited the last time we did this. To be sure we didn’t have any more issues about a month before the event we replaced the radiator and viscous cooling fan and give it some new coolant and a transmission service. Other work on the van involved wiring the heating elements of our amazingly comfortable Scheel-Mann seats and installing a bulkhead to separate the cargo area from the cabin. We also took the van to the Mercedes dealer in Novi for a recall and to have the 70mph governor deleted from the ECU. We now can rip at around 85 if we want to!
teamilluminata
2/22/24 10:13 a.m.
We are running out of things to do again so are picking away at bits an bobs before we send the car out for its wiring harness. Here’s a few little things we managed over the last few weeks:
The shape of the curve on one of the rear arches has always bothered us. We got the body filler out and fixed it.
We want a strut bar in this car so, of course, we are going to try to replicate the works version, as best we can anyway. We don’t have many images of it but it looks and mounts like this.
We’ll need to reinforce those mounting surfaces but otherwise it looks doable. After a bit of trial and error we came up with this.
The uprights are a bit long right now but we want to wait till the wiring harness is in as it comes into the engine bay at about the same height so we don’t want this to be in the way.
One thing we’ve been meaning to fix for a while is the inlet to the intercooler. The inlet hose has always impinged on the bumper bar brace so we needed to alter the angle of the inlet so it would clear. A good a time as any.
Fits. Just tacked for now.
The works cars had windshield retainers so our will. Especially as they were easy to make.
With no glass in the car yet we had to use our other Quattro as a model to get the angle correct.
Next time we’ll make the doors fit and prep the car for its wiring harness installation.
teamilluminata
1/16/25 10:03 a.m.
TEAM ILLUMINATA MOTORSPORT 2024 FLEET REVIEW
83 QUATTRO RALLY BUILD https://teamilluminata.com/blogs/quattro-rally-build
The Quattro rally build was away most of the year getting wired. Wouldn't we all want to do that! It should be back when you read this so, once again, we can say we're going to finish it this year!
84 911 RALLY CAR https://teamilluminata.com/blogs/84-porsche-911
Our little 911 rally car was quite popular this year. Lots of cars and coffee events, M1's Woodward Dream show and American Speed Festival, Northville Concours d'Elegance, and an impromptu hill climb because our 944 got shy at the last minute. The only repairs were a new fan belt and a replacement heater blower.
85 QUATTRO https://teamilluminata.com/blogs/85-ur-quattro
The 85 Quattro continued to keep us busy in the workshop this year. Although it was driving nearly perfectly it still had us fix its handbrake lever boot, window regulator (finally), and a loose dip stick before finally giving up completely in September. We have tried to getting running yet as it never goes out till May but we did send out the passenger seat to be partially re-covered.
89 944 TURBO https://teamilluminata.com/blogs/89-944-turbo
The 944 got a new suit and is now looking like the real race car it always has been. However, that didn't cure its shyness and it has fought us all year with what seemed like fuel starvation issues but clearly wasn't. We finally fixed it in time for the American Speed Festival but it missed the Empire Hill Climb. Towards the end of the year, it got called up for a photoshoot and video with Cruis'in Media. Look for that this spring. Statically speaking it showed well at quite a few events such as Woodward Dream Show, American Speed Festival and a few local cars and coffee events. Mechanically it got new engine mounts, new ECU and plates. Yes, it's now road legal!
2005 CAYENNE https://teamilluminata.com/blogs/timsyberia
Our Cayenne "AKA Timsyberia" has done sterling work as our daily drive and occasional parts hauler but it started 2024 off having fun in the snow. In January, we let it do the Son of Sno*Drift TSD rally then in February it helped feed the workers at the actual Sno*Drift rally disguised as an ice cream truck. Well, it had the chimes anyway. Service-wise it got a new starter (royal PITA) and an oil change (POC).
2015 SPRINTER (RALIVAN) https://teamilluminata.com/blogs/ralivan2
Nothing exciting to report. Just works and continues to drag cars around the mid-west with aplomb.
teamilluminata
1/30/25 10:44 a.m.
WIRING PREP
This feels like one of those Project Binky updates! Been quiet here as a few months ago we took the car over to Racing Tech (https://www.racing-tech.net/) in Grand Rapids, Michigan to get a full wiring harness designed, built and installed. Obviously, this required a bit of prep.
First off, in case Racing Tech wanted to turn the engine over on the key we needed to make sure it actually still turned. You see, we bought this engine so long ago now that we didn't know if it still did that. So, first thing we did was take the plugs out and squirt some lube down the cylinder bores. Then we took the valve cover off and coated the camshaft in assembly lube. Once that was done, we finally turned it over with a big wrench on the crankshaft bolt. Thankfully it turned quite nicely.
Next on the list was to find every bit of electrical equipment that wasn't yet installed on the car and also the old wiring harness in case any of the connectors were needed. Dumping the wiring harness out of the tote box it has been stored in for ten years reminded us why we are not using it.
When we'd finished bolting everything on, we realized the car was now the most complete it had been for probably 20 years. So, we weighed it.
Not bad. It's only really missing glass and wires in this state. Then we showed it the door, the trailer and, finally, the inside of the trailer.
The drive to Grand Rapids took about two hours. We can't tell you how the car drives but it we can report that it tows really well! Here it is in its new, temporary home.
Here are some action shots curtesy of Racing Tech:
The car should be home soon so we'll give you a full review then.
teamilluminata
3/5/25 3:03 p.m.
It's back! Yes, the car is finally back from @racingtech where it received a full racing spec wiring harness. It is technically alive!
It was a bit of a trial getting it home, what with the weather, van troubles and having to drag it into the shop with the 944. It might have brake lights now but it doesn't have brakes; nor does it run.
But now we can push the project towards finishing the dry build and getting the shell painted. That might even happen this year!
First on the agenda: finish mocking up the strut bar. We couldn't finalize the location before as it might have blocked access for the wiring harness but not anymore! It currently sits way too high and needs the mounting brackets fabricating and the existing structure reinforcing. Here's what ours currently looks like what it will look like.
We'll let you know how we did in the next update.
teamilluminata
4/3/25 10:15 a.m.
So, we've been working on the strut bar and finally have it in a form that resembles that of the works cars. It's not fully welded in yet but we'll get to that when we start to strip the car for paint. Here are some shots of the process:
We lowered it a bit to check clearance:
Once we were certain it wouldn't interfere with anything we committed and chopped it down to size:
Then we fabbed up some top brackets and tacked them into place:
Once we get the car apart we'll weld them up and add some reinforcement to the mounts.
5 6 7 8
QceUtkNKHVMshKhJpVHkISezHYIoTc7gYfmK6aqKpBMd97djB2sthEkwVRyLGGfk
