rustysteel
rustysteel Reader
4/12/14 8:29 p.m.
Just found one for sale locally. Looks pretty clean bit of rust on lower rear quarters. What should I look for? Has had lower mileage engine installed. I might try to check it out tomorrow if the rain holds off. Thanks in advance.
BoxheadTim
BoxheadTim PowerDork
4/12/14 10:52 p.m.
N/A or turbo?
What to look for? Mostly the previous owner, IME .
Deferred maintenance can be a problem due to the cost involved if you don't do the wofk yourself. Check for signs of leaks on a T-top car.
gjz30075
gjz30075 Reader
4/13/14 4:46 a.m.
Timing belt is a b*&^%ch to install on the turbo model. They are a whole lot of fun with a Camry V6 installed. Relatively easy to do.
rustysteel
rustysteel Reader
4/13/14 6:45 a.m.
Thanks for the input. It's an NA and I can do some work myself but I have a friend who wrench's on race cars.
racerdave600
racerdave600 Dork
4/13/14 8:45 a.m.
The big thing about the NA is oil leaks....it's the same 2.2 That's in the Camry so parts are very easy to get.
rustysteel
rustysteel Reader
4/15/14 7:50 p.m.
Going to check it out tomorrow night. I'll keep you up to date.
G5x78IyA8UINXdAoqqFWCn3KKJOiJp9T1ISpBSRISc6Y98KwPJnO0oU9pqy4ECUB
