44Dwarf
44Dwarf UberDork
1/29/20 7:51 p.m.
Hello All.
I've got a project I'm working on using a 2017-2019 Fusion back up camera but I can't seem to find the pinout of the camera on-line anywhere.
HS7Z19G490F is the Ford number I bought Dorman's 592-261
The camera has 6 pins in a line not the 2rows like the earlier ones.
Dorman's tech line was ZERO help on the pinout.
Thanks for the help!
44
93gsxturbo
93gsxturbo SuperDork
1/29/20 7:53 p.m.
What are you looking to accomplish?
Some - not all - OEM backup cameras use a weird voltage that prevents them from easily being integrated into an aftermarket solution.
44Dwarf
44Dwarf UberDork
1/30/20 11:47 a.m.
So we upgraded our pick up truck (long story)
We now have a 2016 F250.  It has a camera in the tailgate, we run a fiberglass insert that requires the tailgate to come off.  Ford at some point changed vendors or something ~2 years ago so replacement cameras went from $80 to $290.
I bought the tailgate harness for $34 and have the pinout for it, I've been able to wire a aftermarket unit to it and its working BUT my Co-pilot Wife would like the distance lines and the turn projection that the factory unit has.
So I was able to find the Dorman Fusion camera and it uses the  same connector but the pin out is slightly different i can get video but not the lines. so I know the LIN pin and or the ground is missing or in difrent location.
Saron81
Saron81 Reader
1/30/20 11:48 a.m.
I can look tomorrow when I'm back at work for you.
Saron81
Saron81 Reader
1/31/20 11:18 a.m.
The part number for the connector is at the bottom of the pic if you need that too.
44Dwarf
44Dwarf UberDork
1/31/20 12:02 p.m.
Thanks but thats the older connector and pin out.
I have the connector but it inline 6 pin not the two rows of 3 and my conector fits the camera  the pin out is different for the inline 6 pin sadly.
Saron81
Saron81 Reader
1/31/20 1:54 p.m.
In reply to 44Dwarf :
That's what they show for a 19 Fusion in the wiring diagrams. ???
Focus shows an in-line connector...
44Dwarf
44Dwarf UberDork
1/31/20 4:44 p.m.
Oh thats odd.   when i googled the ford numbers is shows 16-19 but then say late 17 and newer...
link to dorman
44Dwarf
44Dwarf UberDork
2/1/20 7:22 a.m.
Thanks for the help Saron81.
I know three of the pins pin 1 in + power and the two video + and- pins.  and i get video but no line for distance and turn projection. I'm not 100% positive but i believe those come from the LIN pin and the ground those pins ford seams to move around on the cameras I don't want to just haphazardly connect pins for fear of roasting the LIN module.
Saron81
Saron81 Reader
2/1/20 8:37 a.m.
Odd... both the parts catalog and the wiring diagrams from Ford show all Fusions 16- to have the square connector, and nobody in my state stocks the camera for me to look at. Sorry.
44Dwarf
44Dwarf UberDork
2/1/20 9:51 a.m.
Oh well, for now i'm just going to wire up the AfterMarket cheap ass camera i bought last year that was supposed to be wireless and show 4 cameras at once but it worked for only 1 hour... They wanted me to uninstall them and send back to china....
The cameras work if i wire them directly, Have one already on the insert and one on the trailer. now i got to wire the new truck. at some point we'll figure out the dorman camera.
Don't bother with these unless you hardwire to a different monitor I've tested they do work with my 2016 f250 SYNC in the radio
Wish junk wireless unit
WhCtoPQy7BJhVvSh1TMc3s33iRjfugXDuHzET0lGDZSCKeQEpRzDzc9z87S1kPuk
